waaren wrote: Monday 17 December 2018 22:15
Evertjob89 wrote: Monday 17 December 2018 16:37
Currently i'm running an setup with a NPN watermeter sensors and this works fine.
I'm looking for a script that could help me but because i don't get DzVents as everyone else (maybe i'm thinking to difficult?) but the idea should be The idea is very simple, but i'm not getting it working (And i would like to not test it for 17 minutes)
Modified the calculation of current flow. Can you try this ? and please check the log for a couple of hours to see if factor is set right for your meter.
on = { devices = { "Watermeter" }},
data = { watermeter = { history = true, maxHours = 2 }},
logging = {
level = domoticz.LOG_DEBUG,
marker = "watermeter"
execute = function(dz,item)
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
-- JSON call to emulate waterflow
-- http://192.168.192.51:8084/json.htm?type=command¶m=udevice&idx=1242&svalue=0
dz.data.watermeter.add(item.counter)
local minutes = 17
local maxLitersPerMinute = 5.5
local factor = 100
local max = dz.data.watermeter.maxSince('00:'.. minutes .. ':00')
local min = dz.data.watermeter.minSince('00:'.. minutes .. ':00')
local litersPerMinuteNotify = (max - min) / minutes * factor
local current = dz.data.watermeter.get(1).data
local previous, previousTime, litersPerMinuteNow
if dz.data.watermeter.get(2) ~= nil then
previous = dz.data.watermeter.get(2).data
previousTime = dz.data.watermeter.get(2).time.msAgo
litersPerMinuteNow = (( current - previous ) / (previousTime / 60000 )) * factor -- 60000 = msecs in a minute
logWrite("Current water usage: " .. dz.utils.round(litersPerMinuteNow,1) .. " liter a minute")
logWrite("Current water usage cannot be determined (not enough data in history)")
if litersPerMinuteNotify > maxLitersPerMinute then
dz.notify (
'Water usage high!!',
'The waterusage is ' .. dz.utils.round(litersPerMinuteNotify,1) .. ' liter a minute!',
dz.PRIORITY_HIGH
I've tried it and it works, only not as i thought: I've want an average (Usage / Time = Result) for the last 17 minutes, right know it's giving me the result for every minute:
2018-12-18 15:53:40.529 Status: dzVents: Info: Handling events for: "Watermeter", value: "0.00"
2018-12-18 15:53:40.529 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:53:40.560 Status: dzVents: Debug: watermeter: Current water usage: 0 liter a minute
2018-12-18 15:53:40.568 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:54:40.490 Status: dzVents: Info: Handling events for: "Watermeter", value: "6.00"
2018-12-18 15:54:40.490 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:54:40.520 Status: dzVents: Debug: watermeter: Current water usage: 0.6 liter a minute
2018-12-18 15:54:40.527 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:55:01.324 Status: dzVents: Info: Handling events for: "Watermeter", value: "4.00"
2018-12-18 15:55:01.326 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:55:01.355 Status: dzVents: Debug: watermeter: Current water usage: 1.2 liter a minute
2018-12-18 15:55:01.362 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:55:52.990 Status: dzVents: Info: Handling events for: "Watermeter", value: "14.00"
2018-12-18 15:55:52.990 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:55:53.019 Status: dzVents: Debug: watermeter: Current water usage: 1.6 liter a minute
2018-12-18 15:55:53.026 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:56:44.405 Status: dzVents: Info: Handling events for: "Watermeter", value: "11.00"
2018-12-18 15:56:44.405 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:56:44.434 Status: dzVents: Debug: watermeter: Current water usage: 1.3 liter a minute
2018-12-18 15:56:44.442 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:57:35.673 Status: dzVents: Info: Handling events for: "Watermeter", value: "8.00"
2018-12-18 15:57:35.673 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:57:35.702 Status: dzVents: Debug: watermeter: Current water usage: 0.9 liter a minute
2018-12-18 15:57:35.709 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:58:27.354 Status: dzVents: Info: Handling events for: "Watermeter", value: "8.00"
2018-12-18 15:58:27.354 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:58:27.383 Status: dzVents: Debug: watermeter: Current water usage: 0.9 liter a minute
2018-12-18 15:58:27.390 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 15:59:08.583 Status: dzVents: Info: Handling events for: "Watermeter", value: "5.00"
2018-12-18 15:59:08.583 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 15:59:08.612 Status: dzVents: Debug: watermeter: Current water usage: 0.7 liter a minute
2018-12-18 15:59:08.619 Status: dzVents: Info: watermeter: ------ Finished Test
2018-12-18 16:00:01.630 Status: dzVents: Info: Handling events for: "Watermeter", value: "0.00"
2018-12-18 16:00:01.630 Status: dzVents: Info: watermeter: ------ Start internal script: Test: Device: "Watermeter (Virtuale sensoren)", Index: 30
2018-12-18 16:00:01.662 Status: dzVents: Debug: watermeter: Current water usage: 0 liter a minute
2018-12-18 16:00:01.669 Status: dzVents: Info: watermeter: ------ Finished Test
Ive used 56 liters in 8 minutes so the result should be 56 / 8 = 7.25
2018-12-18 16:00:01.662 Status: dzVents: Debug: watermeter: Current water usage: 7.25 liter a minute
