Error message referring to EventHelpers.lua  [Solved]
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
There is the following error appearing in the log every minute after updating to Domoticz beta v4.11696 - dzVents 3.0.0
Error: EventSystem: in /home/user/domoticz/dzVents/runtime/dzVents.lua: /home/user/domoticz/dzVents/runtime/EventHelpers.lua:462: bad argument #1 to 'for iterator' (table expected, got string)
I have only one dzVents script which was triggered on a time every 10 minutes. I have now changed this to be triggered by a switch but the error persists.
No other dzVents debugging messages are displayed with the error
Just for completeness. If I disable dzVents the error stops.
I have a number of vanilla lua time based scripts.
Edit: Just see another reference to this message, with no further details and perhaps I should have put this in the 'Bugs' section, although I'm not sure if it is. Could just be something I've done, although can't think what.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Re: Error message referring to EventHelpers.lua
alanlsmith wrote: Tuesday 18 February 2020 12:37
Can you please put this as line 461 in <domoticz dir>/dzVents/runtime/EventHelpers.lua ? It will not solve the error but will give some extra information in the logfile. Thx.
        utils.log(timeRules, utils.LOG_ERROR)
Can you also check there a no 'old' scripts left in <domoticz dir>/scripts/dzVents/scripts/ and/or in
<domoticz dir>/scripts/dzVents/generated_scripts/
alanlsmith
Sorry for the delay.
After adding your code line to 'EventHelpers.lua' . The log now shows:
020-02-18 13:20:00.139 Error: dzVents: Error: (3.0.0) {"every 5 minutes"}
2020-02-18 13:20:00.139 Error: dzVents: Error: (3.0.0) every minute
2020-02-18 13:20:00.139 Error:EventSystem:i n/home/user/domoticz/dzVents/runtime/dzVents.lua: /home/user/domoticz/dzVents/runtime/EventHelpers.lua:464: bad argument #1 to 'for iterator' (table expected, got string)
I had 2 scripts in the ~scripts/dzVents/scripts folder one was a "test" which I had forgotten about with a 1 munute timer and the other was the "check_for_intruders.lua" from this forum
If I remove the script with the 1 minute time the original error goes away and only the line in the log remains every minute.
Also, significantly the script does not run at 5 minute intervals, or at all for that matter.
The first part of the script looks okay to me
on      =   {   httpResponses   =   { myHttpResponse },
                    timer           =   { 'every 5 minutes'},
alanlsmith wrote: Tuesday 18 February 2020 14:39 If I remove the script with the 1 minute time the original error goes away and only the line in the log remains every minute.
OK you can remove the extra line now. It served its purpose as it identified the line with the error. ( The one with timer = 'every minute' )
Please show the complete script. and all the loglines. myHttpResponse without any context wil not work. It should be set before.
alanlsmith
@Warren, Thanks for your quick and helpful replies.
The simple problem with the "Every minute" script was that I had not put curly brackets around 'every minute'
The "every 5 minutes script" however still does not run at the specified intervals, it did before the last update.
'myHttpResponse' is defined as myHttpResponse = "getDomoticzErrorLog"
Here is the complete script. there doesn't seem to be any errors in the log related to this.
-- getFailedLogin.lua
                --    devices         =   { "getErrorTrigger"}   -- Only used for development and testing
    logging =   {   level           =   domoticz.LOG_INFO,
                    marker          =   "getFailedLoging"    },
    data    =   {   lastlogtime     =   { initial = 0 }},
    execute = function(dz, trigger)
        local violationMessage = "Failed authentication attempt"          -- Change to reflect the messages you want to catch
        local function askDomoticzForLogLines()
            local lastLogTime = dz.data.lastlogtime            -- get time last logrequest
            local logLevel    = 4                              -- loglevel (1=normal,2=Status,4=error,268435455=all
            local jsonString  = "/json.htm?type=command" ..
                                "&param=getlog" ..
                                "&lastlogtime=" .. tostring(lastLogTime) ..
                                "&loglevel=" .. tostring(logLevel)
            local logURL      =  dz.settings["Domoticz url"] .. jsonString
            dz.openURL  ({ url      = logURL,
                           method   = "GET",
                           callback = myHttpResponse
            dz.data.lastlogtime = os.time(os.date('*t'))        -- store current Time as seconds from epoch
            dz.log(logURL,dz.LOG_DEBUG)
        local function findViolation()
           local violation = ""
           if trigger.json.result ~= nil then               -- Only when there are errormessages in the log
               local resultTable = trigger.json.result
               for i = #resultTable,1,-1 do                 -- traverse backwards to get latest violation first
                    if      string.find(resultTable[i].message,violationMessage) and
                        not(string.find(resultTable[i].message,"dzVents")) then     -- We don't want debug messages to interfere
                            violation = violation .. "\n".. resultTable[i].message
            return violation
        if trigger.isDevice or trigger.isTimer then
            askDomoticzForLogLines()                     -- get the relevant loglines
        elseif trigger.ok then
            local violation = findViolation()
            if violation == "" then
                dz.log("No (new) violations found",dz.LOG_DEBUG)
                dz.log("violation(s) found: " .. violation,dz.LOG_INFO)
                dz.notify("Access violation",violation, dz.PRIORITY_NORMAL,nil,"Alans_Phone",dz.NSS_PUSHOVER)
            dz.log("Access problem to log",dz.LOG_ERROR)
alanlsmith wrote: Tuesday 18 February 2020 18:56 The "every 5 minutes script" however still does not run at the specified intervals, it did before the last update.
I don't know why it does not execute on your system. Could it be that it does but that your setting for showing what dzVents are different then before.
At the bottom of the page you get when you go to [Setup] [Settings] [Other] you can set what dzVents shows.
PLease set that to
Errors + minimal execution info + generic info
I changed the level of some log output in the script below to show some additional info. At my system is shows.
2020-02-18 19:50:00.305  Status: dzVents: Info: getFailedLoging: ------ Start internal script: Script #1:, trigger: "every 5 minutes"
2020-02-18 19:50:00.305  Status: dzVents: Debug: getFailedLoging: OpenURL: url = http://127.0.0.1:8084/json.htm?type=command&param=getlog&lastlogtime=1582051500&loglevel=4
2020-02-18 19:50:00.305  Status: dzVents: Debug: getFailedLoging: OpenURL: method = GET
2020-02-18 19:50:00.305  Status: dzVents: Debug: getFailedLoging: OpenURL: post data = nil
2020-02-18 19:50:00.305  Status: dzVents: Debug: getFailedLoging: OpenURL: headers = nil
2020-02-18 19:50:00.305  Status: dzVents: Debug: getFailedLoging: OpenURL: callback = getDomoticzErrorLog
2020-02-18 19:50:00.305  Status: dzVents: Info: getFailedLoging: ------ Finished Script #1
2020-02-18 19:50:00.368  Status: dzVents: Info: Handling httpResponse-events for: "getDomoticzErrorLog"
2020-02-18 19:50:00.369  Status: dzVents: Info: getFailedLoging: ------ Start internal script: Script #1: HTTPResponse: "getDomoticzErrorLog"
2020-02-18 19:50:00.370  Status: dzVents: Debug: getFailedLoging: No (new) violations found
2020-02-18 19:50:00.371  Status: dzVents: Info: getFailedLoging: ------ Finished Script #1
The script with some minor changes.
local myHttpResponse = 'getDomoticzErrorLog'
return
    on =
        httpResponses =
            myHttpResponse,
        timer =
            'every 5 minutes',
        -- devices = { 'getErrorTrigger' }   -- Only used for development and testing
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_INFO when script is OK
        marker = 'getFailedLoging',
    data =
        lastlogtime =
            initial = 0,
        local violationMessage = 'Failed authentication attempt'          -- Change to reflect the messages you want to catch
            local logLevel = 4                              -- loglevel (1=normal, 2=Status, 4=error, 268435455=all
            local jsonString = '/json.htm?type=command' ..
                                '&param=getlog' ..
                                '&lastlogtime=' .. tostring(lastLogTime) ..
                                '&loglevel=' .. tostring(logLevel)
            local logURL      =  dz.settings['Domoticz url'] .. jsonString
            dz.openURL  (
                url      = logURL,
                method   = 'GET',
            dz.data.lastlogtime = os.time()        -- store current Time as seconds from epoch
           local violation = ''
               for i = #resultTable, 1, -1 do                 -- traverse backwards to get latest violation first
                    if string.find(resultTable[i].message, violationMessage) and
                       not(string.find(resultTable[i].message, 'dzVents')) then     -- We don't want debug messages to interfere
                            violation = violation .. '\n'.. resultTable[i].message
            return violation
            if violation == '' then
                dz.log('No (new) violations found', dz.LOG_DEBUG)
                dz.log('violation(s) found: ' .. violation, dz.LOG_FORCE)
                dz.notify('Access violation', violation,  dz.PRIORITY_NORMAL, nil, 'Alans_Phone', dz.NSS_PUSHOVER)
            dz.log('Access problem to log', dz.LOG_ERROR)
alanlsmith
@waarren Again sorry for the delay in replying.
I had the 'Intruders' script set for every 5 minutes and another script to download "Dark Sky" weather every 10 minutes. Both were working up until 10:00 on Feb 17.
At 10:09 on Feb 17 I updated Domoticz to beta 4.11896.
After that I was getting the error message related to EventHelper.lua and neither script ran at the intervals set by the timer.
At your advice I looked at the dzVents scripts in my system and found the error in one where I had omitted the 'curly brackets' around the timer statement in the script set to run ever minute.
After that the error message related to EventHelpers.lua stopped appearing in the log and both scripts ran on time as expected.
So it seems that dzVents previously tolerated my mistake in the 'every minute' script but the update in v4.11696 it didn't.
At the same time I got sidetracked by the issue with the 'uservariables_lastupdate' table as I had some scripts relying on that. So to be honest I think I got a bit confused trying to see what was and wasn't working.
But
Now problem resolved and thank you for your help.
Re: Error message referring to EventHelpers.lua  [Solved]
alanlsmith wrote: Wednesday 19 February 2020 14:13 ...
Now problem resolved ...
Good to read it's working again.
btw. The issue with 'uservariables_lastupdate' table is fixed in latest Beta (V4.11706)
