I paired with zigate an xiaomi plug but in domoticz it was created only 2 widgets, switch and voltage. Two widgets are missing: live electricity usage and general electricity counter.
After I deleted the device from domoticz and I tried again and is the same result.
I using domoticz beta, zigate firmware 3.1c and plugin beta 4.8.002
Not all widgets are created (Zigate plugin )
Re: Not all widgets are created (Zigate plugin )
Please do provide the logs when doing the pairing.
In addition please attach ( not copy paste) the export of Web admin -> tool -> list of devices raw (json) .
This will help to understand what happens.
Could you also give the reference of the device
Wiki is available here.
Zigbee for Domoticz FAQ
pipiche wrote: ↑Monday 17 February 2020 8:00
This could be related to a new device version/firmware
2020-02-17 12:19:27.629 (Zigate) --> Adding device 37ba in self.DevicesInPairingMode
2020-02-17 12:19:27.629 (Zigate) --> ['b7e5', 'd565', 'a512', '37ba']
2020-02-17 12:19:27.628 Status: (Zigate) Device Announcement Addr: 37ba, IEEE: 00158d0001717a57 Join Flag: 0x00 - join a network through association RSSI: 0
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Active Endpoint Response Ep: 01 RSSI: 48
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Active Endpoint Response Ep: 02 RSSI: 48
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Active Endpoint Response Ep: 03 RSSI: 48
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Request Simple Descriptor for Ep: 01
2020-02-17 12:19:28.264 Status: (Zigate) [-] NEW OBJECT: 37ba Request Simple Descriptor for Ep: 02
2020-02-17 12:19:28.265 Status: (Zigate) [-] NEW OBJECT: 37ba Request Simple Descriptor for Ep: 03
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Simple Descriptor Response EP: 0x01 RSSI: 48
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba ProfileID 0104
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba ZDeviceID 0051
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Application Version 0001
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster IN Count: 09
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 1: 0000 (Basic)
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 2: 0004 (Groups)
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 3: 0003 (Identify)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 4: 0006 (On/Off)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 5: 0010 (Binary Output (Basic))
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 6: 0005 (Scenes)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 7: 000a (Time)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 8: 0001 (Power Configuration)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 9: 0002
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster OUT Count: 02
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 1: 0019 (Over-the-Air Upgrade)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 2: 000a (Time)
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Simple Descriptor Response EP: 0x02 RSSI: 48
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba ProfileID 0104
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba ZDeviceID 0009
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Application Version 0001
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster IN Count: 01
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 1: 000c (Analog Input (basic))
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster OUT Count: 02
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 1: 000c (Analog Input (basic))
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 2: 0004 (Groups)
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba Simple Descriptor Response EP: 0x03 RSSI: 48
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba ProfileID 0104
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba ZDeviceID 0053
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba Application Version 0001
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster IN Count: 01
2020-02-17 12:19:28.577 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 1: 000c (Analog Input (basic))
2020-02-17 12:19:28.577 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster OUT Count: 01
2020-02-17 12:19:28.577 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 1: 000c (Analog Input (basic))
2020-02-17 12:19:29.090 Error: (Zigate) ReadCluster - 0000 - 37ba/01 Attribut ff01 received while device not inDB
2020-02-17 12:19:31.907 Status: (Zigate) [0] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:31.907 Status: (Zigate) [0] NEW OBJECT: 37ba Request Node Descriptor
2020-02-17 12:19:36.878 Status: (Zigate) [1] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:41.922 (Zigate) WARNING - ZigateCmd: 0140 0237ba01010002000000000000FF ZigateQueue: 16
2020-02-17 12:19:41.922 (Zigate) WARNING - ZigateCmd: 0140 0237ba01010019000000000000FF ZigateQueue: 17
2020-02-17 12:19:41.922 (Zigate) WARNING - ZigateCmd: 0140 0237ba0102000c000000000000FF ZigateQueue: 18
2020-02-17 12:19:41.923 (Zigate) WARNING - ZigateCmd: 0140 0237ba01020004000000000000FF ZigateQueue: 19
2020-02-17 12:19:41.923 (Zigate) WARNING - ZigateCmd: 0140 0237ba0103000c000000000000FF ZigateQueue: 20
2020-02-17 12:19:41.900 Status: (Zigate) [2] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:41.901 Status: (Zigate) [2] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:42.825 (Zigate) UpdateDevice - (Zigate - lumi.plug_Voltage-00158d0001717a57-01) 0:217.0;217.0
- export_raw.rar
- (6.96 KiB) Downloaded 17 times
Thanks for thos information. Please kindly update to the latest beta branche ( git pull ), and redo the pairing after having removed the plug related widgets
You're welcome and thank you too for your support! I'll try and i'll return with feed back.
Widgets are created correctly and are functional for now.
Thank you very much!
great
