DZvents unble to update text sensor with local value Topic is solved
Kranendijk
Domoticz version: 4.10717
Post by Kranendijk »
All,
I want to extract the numbers only from my "Weerstation" device's BMP280 so I have only the numbers and feed that to a local variable to have it in a new Text device called "Barometer". Reason? I need the numbers to be fed to an OLED. Numbers only.
To accomplish this I have created a DZvents time script "Barometer ding" which first does a device dump, then sets the barometer value into a local and then (according to the device dump) set this local value into the "Barometer" device so I can use it later on. I confirm there is data in the local by sending it to the Domoticz log.
Although I think I am doing all fine, Domoticz tells me there's something wrong as I cannot update the "Barometer" device. Tried custom sensor, baometer sensor, all the same. What am I missing here?
The script:
          on   = { timer    = { "every 1 minutes"}},
  execute = function(dz)
        dz.devices('Barometer').dump()
        local BAROMETER = dz.devices('Luchtdruk').barometer
        dz.log(' ### Luchtdruk ' .. BAROMETER .. ' ### ')
        dz.devices('Barometer').updateCustomSensor("BAROMETER")
And the log:
2020-02-16 18:44:00.394 Status: dzVents: > name: Barometer
2020-02-16 18:44:00.394 Status: dzVents: > rawData:
2020-02-16 18:44:00.394 Status: dzVents: > 1: Hello World
2020-02-16 18:44:00.394 Status: dzVents: > timedOut: false
2020-02-16 18:44:00.395 Status: dzVents: > lastUpdate: 2020-02-16 17:48:39
2020-02-16 18:44:00.395 Status: dzVents: > description:
2020-02-16 18:44:00.395 Status: dzVents: > deviceType: General
2020-02-16 18:44:00.395 Status: dzVents: > subType: Text
2020-02-16 18:44:00.395 Status: dzVents: > deviceID: 00082204
2020-02-16 18:44:00.395 Status: dzVents: > signalLevel: 12
2020-02-16 18:44:00.395 Status: dzVents: > baseType: device
2020-02-16 18:44:00.395 Status: dzVents: > kodiStop()
2020-02-16 18:44:00.395 Status: dzVents: > updateMode()
2020-02-16 18:44:00.395 Status: dzVents: > updateWind()
2020-02-16 18:44:00.395 Status: dzVents: > unit: 1
2020-02-16 18:44:00.395 Status: dzVents: > updateAlertSensor()
2020-02-16 18:44:00.395 Status: dzVents: > nValue: 0
2020-02-16 18:44:00.395 Status: dzVents: > updateYouless()
2020-02-16 18:44:00.395 Status: dzVents: > disarm()
2020-02-16 18:44:00.395 Status: dzVents: > cancelQueuedCommands()
2020-02-16 18:44:00.395 Status: dzVents: > open()
2020-02-16 18:44:00.395 Status: dzVents: > updateVoltage()
2020-02-16 18:44:00.395 Status: dzVents: > volumeUp()
2020-02-16 18:44:00.395 Status: dzVents: > updateVisibility()
2020-02-16 18:44:00.395 Status: dzVents: > play()
2020-02-16 18:44:00.395 Status: dzVents: > updateUV()
2020-02-16 18:44:00.395 Status: dzVents: > updateTempHumBaro()
2020-02-16 18:44:00.395 Status: dzVents: > setHotWater()
2020-02-16 18:44:00.395 Status: dzVents: > switchSelector()
2020-02-16 18:44:00.395 Status: dzVents: > armAway()
2020-02-16 18:44:00.395 Status: dzVents: > updateWaterflow()
2020-02-16 18:44:00.395 Status: dzVents: > toggleSwitch()
2020-02-16 18:44:00.395 Status: dzVents: > updateTempHum()
2020-02-16 18:44:00.395 Status: dzVents: > armHome()
2020-02-16 18:44:00.395 Status: dzVents: > switchOff()
2020-02-16 18:44:00.395 Status: dzVents: > close()
2020-02-16 18:44:00.395 Status: dzVents: > state: Hello World
2020-02-16 18:44:00.395 Status: dzVents: > setDescription()
2020-02-16 18:44:00.395 Status: dzVents: > isVariable: false
2020-02-16 18:44:00.395 Status: dzVents: > changed: false
2020-02-16 18:44:00.395 Status: dzVents: > update()
2020-02-16 18:44:00.395 Status: dzVents: > updateP1()
2020-02-16 18:44:00.395 Status: dzVents: > playFavorites()
2020-02-16 18:44:00.395 Status: dzVents: > volumeDown()
2020-02-16 18:44:00.395 Status: dzVents: > updateText()
2020-02-16 18:44:00.395 Status: dzVents: > updateSoilMoisture()
2020-02-16 18:44:00.395 Status: dzVents: > switchTypeValue: 0
2020-02-16 18:44:00.396 Status: dzVents: > isSecurity: false
2020-02-16 18:44:00.396 Status: dzVents: > icon: text
2020-02-16 18:44:00.396 Status: dzVents: > setKelvin()
2020-02-16 18:44:00.396 Status: dzVents: > _nValue: 0
2020-02-16 18:44:00.396 Status: dzVents: > deviceSubType: Text
2020-02-16 18:44:00.396 Status: dzVents: > bState: false
2020-02-16 18:44:00.396 Status: dzVents: > updateRadiation()
2020-02-16 18:44:00.396 Status: dzVents: > updateTempBaro()
2020-02-16 18:44:00.396 Status: dzVents: > updateCounter()
2020-02-16 18:44:00.396 Status: dzVents: > updateWeight()
2020-02-16 18:44:00.396 Status: dzVents: > description:
2020-02-16 18:44:00.396 Status: dzVents: > setState()
2020-02-16 18:44:00.396 Status: dzVents: > isDevice: true
2020-02-16 18:44:00.396 Status: dzVents: > decreaseBrightness()
2020-02-16 18:44:00.396 Status: dzVents: > setDiscoMode()
2020-02-16 18:44:00.396 Status: dzVents: > increaseBrightness()
2020-02-16 18:44:00.396 Status: dzVents: > dump()
2020-02-16 18:44:00.396 Status: dzVents: > updateWetness()
2020-02-16 18:44:00.396 Status: dzVents: > deviceId: 00082204
2020-02-16 18:44:00.396 Status: dzVents: > switchType: On/Off
2020-02-16 18:44:00.396 Status: dzVents: > kodiExecuteAddOn()
2020-02-16 18:44:00.396 Status: dzVents: > setColor()
2020-02-16 18:44:00.396 Status: dzVents: > updateSoundLevel()
2020-02-16 18:44:00.396 Status: dzVents: > updateRain()
2020-02-16 18:44:00.396 Status: dzVents: > getColor()
2020-02-16 18:44:00.396 Status: dzVents: > setWhiteMode()
2020-02-16 18:44:00.396 Status: dzVents: > startPlaylist()
2020-02-16 18:44:00.396 Status: dzVents: > hardwareID: 16
2020-02-16 18:44:00.396 Status: dzVents: > onkyoEISCPCommand()
2020-02-16 18:44:00.396 Status: dzVents: > text: Hello World
2020-02-16 18:44:00.396 Status: dzVents: > updatePercentage()
2020-02-16 18:44:00.396 Status: dzVents: > updateSetPoint()
2020-02-16 18:44:00.396 Status: dzVents: > name: Barometer
2020-02-16 18:44:00.396 Status: dzVents: > kodiPause()
2020-02-16 18:44:00.396 Status: dzVents: > hardwareTypeValue: 15
2020-02-16 18:44:00.396 Status: dzVents: > hardwareType: Dummy (Does nothing, use for virtual switches only)
2020-02-16 18:44:00.396 Status: dzVents: > updateLux()
2020-02-16 18:44:00.396 Status: dzVents: > timedOut: false
2020-02-16 18:44:00.396 Status: dzVents: > isGroup: false
2020-02-16 18:44:00.396 Status: dzVents: > updateElectricity()
2020-02-16 18:44:00.396 Status: dzVents: > stop()
2020-02-16 18:44:00.396 Status: dzVents: > isHTTPResponse: false
2020-02-16 18:44:00.396 Status: dzVents: > updateBarometer()
2020-02-16 18:44:00.397 Status: dzVents: > protected: false
2020-02-16 18:44:00.397 Status: dzVents: > deviceType: General
2020-02-16 18:44:00.397 Status: dzVents: > updateHumidity()
2020-02-16 18:44:00.397 Status: dzVents: > updateTemperature()
2020-02-16 18:44:00.397 Status: dzVents: > updateCustomSensor()
2020-02-16 18:44:00.397 Status: dzVents: > signalLevel: 12
2020-02-16 18:44:00.397 Status: dzVents: > switchOn()
2020-02-16 18:44:00.398 Status: dzVents: Info: ### Luchtdruk 995 ###
2020-02-16 18:44:00.398 Status: dzVents: Error (2.4.19): Method updateCustomSensor is not available for device "Barometer" (deviceType=General, deviceSubType=Text). If you believe this is not correct, please report.
2020-02-16 18:44:00.398 Status: dzVents: Info: ------ Finished Barometer ding
xury
Re: DZvents unble to update text sensor with local value
Post by xury »
You have to send two arguments separated by comma to custom sensor.
Make sure it's really custom sensor.
Take a look my working example:
return  {
    timer = { 'every minute' },
    devices = { 'Stan_kotla' }
	if (item.isTimer) then
		if (domoticz.devices('Stan_kotla').nValue == 3) then
			domoticz.devices('Stankot').updateCustomSensor(1,1)
	    	elseif
			(domoticz.devices('Stan_kotla').nValue == 1) then
			domoticz.devices('Stankot').updateCustomSensor(0,0)
Kranendijk
That did the trick, thanks!
This is what I needed to change:
dz.devices('Barometer').updateCustomSensor(BAROMETER,1)
