Issue with Fibaro Dimmer2 / commands
stuiow
Domoticz version: 3.6857
Post by stuiow »
I inadvertently deleted a node the other day for my bedroom light.
To fix this, i did a factory reset on the relay and then re-included it as a new node into domoticz (i use a aeotec gen5 stick).
The issue now is nothing is working, commands to switch on/off, 5% 99% etc....
I also have an issue with the fact that the physical switch attached to the relay is a switch, rather than button.
So i have gone into the settings and tried setting the option for button to switch.
This setting is not getting through to the relay.
I excluded the relay again and reincluded it, (with a factory reset inbetween), still no luck.
After looking into this more, i am seeing its not being assigned to the "lifeline" group, 1.
I've tried doing this manually but again, this isn't working.
Looking at OZW control panel, the node is being fully recognised as being a LBR+, manufacturer, model etc...
Any ideas how i can gain control of this relay again?
Domoticz Beta, v4.11674
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
