I need to change my file sync script.
I made a dashboard with webcams and push the images to my nest hub.
My sync script sometimes moves files that are to be published.
So i gave my files to be published names like: xxx<name> . I like to exclude them from the mv command from the sync script
I found out that this works:
find /media/pi/motionfiles/ -type f ! -name "xxx*" -exec mv {} /home/pi/test2/ \;
-- so i tadjust the original script below and changed the move command with
osCommand('sudo find ' .. sourceDir .. '/ -type f ! -name "xxx*" -exec mv {} ' .. targetDir .. '/ \;')
/DZ_service_filecopy.lua':
2020-02-11 17:46:27.444 ...cripts/dzVents/generated_scripts/DZ_service_filecopy.lua:53: invalid escape sequence near ''/ \;'
2020-02-11 17:46:27.635 Error: dzVents: Error: (2.5.7) error loading module 'DZ_service_filecopy' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/DZ_service_filecopy.lua':
2020-02-11 17:46:27.635 ...cripts/dzVents/generated_scripts/DZ_service_filecopy.lua:53: invalid escape sequence near ''/ \;'
2020-02-11 17:46:27.763 Error: dzVents: Error: (2.5.7) error loading module 'DZ_service_filecopy' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/DZ_service_filecopy.lua':
2020-02-11 17:46:27.763 ...cripts/dzVents/generated_scripts/DZ_service_filecopy.lua:53: invalid escape sequence near ''/ \;'
2020-02-11 17:46:28.039 (zwavepluspvk) Current (Unknown)
20
original script
return
timer = {timer_overdag,timer_nacht},
devices = {'filecopy'},
logging = {
level = domoticz.LOG_ERROR,
execute = function(dz,item,info)
_G.logMarker = _G.moduleLabel -- marker wordt scriptnaam, _G.logMarker = info.scriptName is idem
if (item.isDevice and item.name == 'filecopy' and item.state == 'On') or item.isTimer then
local messageTable = {}
local sourceDir = '/media/pi/motionfiles'
local targetDir = '/mnt/mntnas'
local function osCommand(cmd)
local fileHandle = assert(io.popen(cmd, 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if returnTable[3] ~= 0 then
dz.helpers.globalMessage2(dz,item,info,messageTable,'add', '\nCommand: ' .. cmd .. '\nReturnCode: ' .. returnTable[3] .. '\ncommandOutput: ' .. commandOutput)
return commandOutput
local function fileCount(dir)
return tonumber(osCommand('ls ' .. dir .. ' | wc -l'))
if fileCount(sourceDir) > 0 then
dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' NAS: Er zijn bestanden op de SHARE aanwezig...')
dz.devices('motion files aanwezig').switchOn().checkFirst()
if (item.isDevice and item.name == 'filecopy' and item.state == 'On') or (item.isTimer and item.trigger == timer_overdag) then
--osCommand('sudo mv ' .. sourceDir .. '/* ' .. targetDir .. '/')
-- alles wat met xxx begint laten staan (worden gebruikt en later gerenamed zodat ze alsnog worden verplaatst)
-- dit werkt mv `find /home/pi/test '!' -type d | fgrep -v xxx*` /home/pi/test2
--find /media/pi/motionfiles/ -type f ! -name "xxx*" -exec mv {} /home/pi/test2/ \;
dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' NAS: Er zijn bestanden verplaatst...')
dz.devices('motion files aanwezig').switchOff().checkFirst()
--dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' NAS: Er zijn geen bestanden op de SHARE aanwezig...') -- teveel berichten
if item.isDevice and item.name == 'filecopy' and item.state == 'On' then
item.switchOff().afterSec(5)
dz.helpers.globalMessage2(dz,item,info,messageTable,'chg') -- dump
