Add device type to manufacturer_specific.xml?
jslettengren
Post by jslettengren »
I'm running Domoticz latest stable version. I have recently installed a few Qubino Dimmers, specifically Qubino Mini Dimmer (ZMNHHD). They work perfectly, but since the specific model is not in the manufacturer_specific.xml, I cannot set any configuration parameters.
My question is: Can I add it myself (along with the OZW config file ZMNHHDx.xml), or do I have to upgrade Domoticz (and OZW) to the latest Beta? I suppose the answer to this question is answered in numerous threads, but somehow I cannot seem to find them.
Thanks in advance.
hvoorend
Domoticz version: 2024.2
Re: Add device type to manufacturer_specific.xml?
Post by hvoorend »
I do have the same problem with the Qubino mini dimmer: I do not see any configuration options after include (so cannot change any). Will there be any solution expected soon?
Raspberry Pi 2
Raspbian Bookworm
Aeon zStick Gen5 fw 1.0
RFXCOM USB
Domoticz 2024.2
felix63
Domoticz version: 2020.1
Post by felix63 »
The latest beta has support for the Qubino Mini Dimmer (ZMNHHD). So it's coming. Perhaps you can add the necessary info manually to your current configuration. Always make a backup before fiddling...
See https://github.com/OpenZWave/open-zwave ... ng-Devices
Or just have some patience...
hvoorend
Post by hvoorend »
Thanks for your reply Felix. Since the previous update they are recognized as they should.
One problem since that lastest update (2020.2) is that the KWh and Watt devices turn red after a while.
No clue why. Any tips where to look or how to correct this?
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
