I have an error when activating the 'permit join time', Error: (Zigate) LQI:LQIresp - Status: c1 for 1fc10100000000
Also, It is not possible to connect Ikea lamps. Is this the cause of the error?
I tried different methods of linking, but the lamp does not connect. Have anyone a suggestion?
System: Synology DS413 with domoticz 4.11597
Regards,
Ton
Zigate - Error: (Zigate) LQI:LQIresp Topic is solved
Re: Zigate - Error: (Zigate) LQI:LQIresp
Do not worry of this error, that is not an issue .
Haijes
Pipiche, thank you for the quick reply.
pfloryann
- Domoticz version: 2025.2
I have an error in domoticz logs...but i don't know were it come from
How to fix it?2020-02-03 19:53:39.560 (Zigate) Request for IEEE for short address: b82c
2020-02-03 19:53:39.560 Error: (Zigate) Decode8102 - Receiving a message from unknown device : b82c with Data : c3b82c020001002100200001c8
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
This error is telling you that you have a device which is paired with Zigate but is not known from the plugin.pfloryann wrote: Monday 03 February 2020 18:59 I have an error in domoticz logs...but i don't know were it come fromHow to fix it?2020-02-03 19:53:39.560 (Zigate) Request for IEEE for short address: b82c
Spo to fix it you need to find which one it is and repair it
Everything works fine, but this was my log:
2020-02-08 08:10:46.531 Error: (Zigate) 'onMessage' failed 'ValueError':'invalid literal for int() with base 10: 'f4''.
2020-02-08 08:10:46.531 Error: (Zigate) ----> Line 797 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-02-08 08:10:46.531 Error: (Zigate) ----> Line 482 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-02-08 08:10:46.531 Error: (Zigate) ----> Line 254 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 387 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 486 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 98 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 1271 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8102
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 190 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function ReadCluster
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 425 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function Cluster0000
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 969 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function MajDomoDeviceDomoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
Please try to update to latest version. Not sure if it will fix that problem.
Could you let me know if you have a water leak detector ?
Yes i have a water leak detector. It's not leakingpipiche wrote: Sunday 09 February 2020 20:59 Please try to update to latest version. Not sure if it will fix that problem.
Update of the plugin, done!
Haijes
Problem solved. Use another USB port to connect ZigateHaijes wrote: Wednesday 29 January 2020 17:56 Also, It is not possible to connect Ikea lamps. Is this the cause of the error?
