one command to multiple devices..
OedzesG
Post by OedzesG »
hallo,
is there a way to send one command to multiple devices?
for example: one light-setting command to 3 diverent bulbs? instead of writing 3 times olmost the same code with diverent IDX numbers.
		active = true,
		    on = { devices = {38}
		logging = { level = domoticz.LOG_DEBUG
	execute = function(dz, item)
		if item.state == 'On' then
			dz.devices(12).setColor(0,0,0, item.level, 0, 255, 2, 255).silent()
			dz.devices(14).setColor(0,0,0, item.level, 0, 255, 2, 255).silent()
			dz.devices(16).setColor(0,0,0, item.level, 0, 255, 2, 255).silent()
			dz.devices(12).switchOff().silent()
			dz.devices(14).switchOff().silent()
			dz.devices(16).switchOff().silent()
i try to do something like this:
dz.devices(12, 14, 16).setColor(0,0,0, item.level, 0, 255, 2, 255).silent()
but its not working.. :(
OedzesG
Re: one command to multiple devices..
Post by OedzesG »
Found solutuion....
    	--	**		Group livingRoom Lights 	**	--
	local group_dimmer = 38
	local group_devices = {12, 14, 16}
		active = true,
		    on = { devices = {group_dimmer}
		logging = { level = domoticz.LOG_ERROR
	local group = dz.devices().filter(group_devices)
                	group.forEach(function(myGroup)
	            	myGroup.setColor(0,0,0, item.level, 0, 255, 2, 255).silent() end)
	        	myGroup.switchOff().silent() end)
OedzesG
Post by OedzesG »
@ waaren ( I think I have the best chance with you :D )
in some cases i use the function openURL to update devices, you know how to handel with .foreach?
OedzesG wrote: Monday 10 February 2020 10:16 in some cases i use the function openURL to update devices, you know how to handle?
Can you please explain why you are not using native dzVents commands and show an example ?
OedzesG
Post by OedzesG »
some devices are on another domoticz installation inside the network.
OedzesG wrote: Monday 10 February 2020 10:56
Can you show the script you are using now as an example ?
OedzesG
Post by OedzesG »
this is one of them...
	--	scéne zolder lampen
	local zolder_scene_switch = 43 -- idx scéne pushOnn button
	local zolder_spot_1 = 88 -- idx zolder lamp 1
	local zolder_spot_2 = 89 -- idx zolder lamp 2
	local zolder_spot_3 = 90 -- idx zolder lamp 3
		active = true,
		    on = { devices = {zolder_scene_switch} },
	    	red_level		= '200'
        	green_level		= '25'
		blue_level		= '68'
		dim_level 		= '15'
        dz.openURL (
        'http://192.168.1.5:8085/json.htm?type=command&param=setcolbrightnessvalue&idx='..
        zolder_spot_1 ..
        '&color={"m":3,"r":' ..
        red_level ..
	',"g":' ..
	green_level ..
	',"b":' ..
	blue_level ..
        '}&brightness=' ..
        dim_level
	dz.openURL (
        zolder_spot_2 ..
        red_level ..
	',"g":' ..
	green_level ..
	',"b":' ..
	blue_level ..
        '}&brightness=' ..
        dim_level
	dz.openURL (
        zolder_spot_3 ..
        red_level ..
	',"g":' ..
	green_level ..
	',"b":' ..
	blue_level ..
        '}&brightness=' ..
        dim_level
OedzesG wrote: Monday 10 February 2020 11:27 this is one of them...
I would use something like below (I have not checked the syntax of the API call)
        active = true,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'send Color',
        local spots = {88, 89, 90}
        local function sendColor(idx)
            local red_level    = '200'
            local green_level = '25'
            local blue_level = '68'
            local dim_level    = '15'
            local color = '&color={"m":3' .. ',r":' .. red_level .. ',"g":' .. green_level ..',"b":' .. blue_level .. '}' .. '&brightness=' .. dim_level
            dz.openURL('http://192.168.1.5:8085/json.htm?type=command&param=setcolbrightnessvalue&idx=' .. idx .. color )
        for _, idx in ipairs(spots) do
            sendColor(idx)
OedzesG
Post by OedzesG »
Thnx again waaren!
works great.. now i simply can manage a group, i had some idea to make a pusch button with a diverent scene every time i hit the button..
for start i did some test with diverent brighness level... ( first time working with data :D )
	--     test puschOnn button with multi brightness level - color wamrWhite 	--
    local scene_switch = 48
    local group_test = {30, 10, 32}
		active = true,
	    		on = { devices = {scene_switch}
		logging = { level = domoticz.LOG_DEBUG,
		data = { brightness 	= { initial = 0 },
			 counter 	= { initial = 0 }
		if dz.data.counter == 5 then dz.data.counter = 0 else
			dz.data.counter = dz.data.counter + 1
		if dz.data.counter == 1 then dz.data.brightness = 1 else
			dz.data.brightness = dz.data.counter * 20
	local function updateGroup(idx)
	        dz.devices(idx).setColor(0,0,0, dz.data.brightness, 0, 255, 2, 255).silent() end
		for _, idx in ipairs(group_test) do
		updateGroup(idx) end
just to share, maybee the ideaa can fit to some of youre needs...
