Bosch EasyControl (Nefit Easy's Big Brother)
edwin1234
Domoticz version: 2021.1
Re: Bosch EasyControl (Nefit Easy's Big Brother)
Post by edwin1234 »
Im missing :
What temperature is it now?
Set temperature 20 degrees
What is the pressure?
What is suply or return temperature?
If its possible, can you explain how to do that?
Egregius
Domoticz version: v2024.7
Post by Egregius »
I guess you'll have to wait for the developer api for those details.
I ment that the main usage things are possible.
New temperatures you could get whit a easycontrol -> webhooks applet, but only per 0,5° change.
Set temperature can be done, and also home/away.
edwin1234
Post by edwin1234 »
Thanks for your answer,
Yes i know,
But cant wait ;)
Egregius
Post by Egregius »
Well, we've been waiting 2 years for IFTTT integration... Maybe another 2 years for the API? :lol:
You could mail them at [email protected]
Maybe it'll speed things up if lots of people ask for it...
I don't know what they mean with "This offer is only addressed to commercial customers including freelancers and entrepreneurs.". Could be that the API won't be accessible for normal users. There's also a page "Plans and Pricing" wich could indicate that it won't be free.
edwin1234
Post by edwin1234 »
I will try that,
I work as a service engineer for heating systems
Maybe if i sent a mail as a service dealer for nefit/bosch it will help a bit. 😁
But dont think so.
Think we must be patience.
petkli
Post by petkli »
i did sent them an email too
petkli
Post by petkli »
email from Bosch:
Thank you for your interest and for contacting Bosch.
We do have a way to pair/register easy control device on our website.
Please refer to https://developer.bosch.com/web/bosch-t ... i/overview
Unfortunately, we do not have a way you can create your own client for a standalone app. We hope to add this in the future, but there is no standard timeline.
Currently you can control your device only on the website.
ceesjan
Post by ceesjan »
Has anyone managed to connect the Bosch easyconnect for a Nefit proline to Domoticz? my OS Ubuntu 20.04
Domoticz version: 2024.7
No one yet managed to access the EasyControl outside the Bosch app. Follow the search for access here: https://github.com/robertklep/bosch-xmpp/issues/4
zandhaas
Domoticz version: V3.8805
Post by zandhaas »
Robert Klep managed to get access to the CT200 (Easycontrol) with the Bosch-xmpp tool.
The easy control option is added to the bosch-xmpp tool.
Perhaps someone is able to build a new plugin for this. 8-) 8-)
Perhaps the Nefit easy http server can be modified to also use the Bosch EasyControl, then no major changes to the integration are needed.
I asked it in https://github.com/robertklep/nefit-eas ... /issues/51
I have no Bosch EasyControl so have no real interest here. Perhaps you can add your thoughts to the github issue...
Perhaps lean on https://github.com/doudz/bosch-thermost ... tree/ct200 and make a python plugin
Edit: also already some work done here in HA: https://github.com/bosch-thermostat/hom ... /issues/64
petkli
Post by petkli »
IFTTT and the Bosch EasyControl workz.
And you can control this in Domoticz.
I know, it is not the real thing, but it workz.
There is now a python library able to work with the Bosch Easycontrol: https://github.com/bosch-thermostat/bos ... ent-python
gggr
Post by gggr »
I am a bit late to the party, but I built a plugin for Domoticz that reads data from the Bosch Easycontrol using the bosch-xmpp tool. It is very simple and provides you with some devices that are updated every minute.
You can check it out here: https://github.com/ggraat/domoticz-easycontrol-plugin
gggr wrote: Monday 06 February 2023 23:49 I am a bit late to the party, but I built a plugin for Domoticz that reads data from the Bosch Easycontrol using the bosch-xmpp tool. It is very simple and provides you with some devices that are updated every minute.
This is great! Thanks. I have added it to the python plugin page. https://www.domoticz.com/wiki/Plugins
Domoberry
Post by Domoberry »
I have succesfully used the bosch-xmpp gateway and the plugin as mentioned above. Some 6 values of the Easycontrol CT200 are now available in Domoticz.To start the bosch-xmpp service I'm using a systemd script. Bit more information here: https://domoticz.com/forum/posting.php? ... ly&t=22726
janpep
Domoticz version: 2025.1
Post by janpep »
At the moment I am using Domoticz as an interface bewteen a Calendar (imported and parsed ics with a script) and a remote location where Honeywell EVOhome installation is used. In the morning I get the events for the day and set setpoint timers for the needed zones.
This system will probably be replaced by Bosch Easycontrol. I am reading here and I saw the references to github.
But I still don't get a good idea of ​​how it works and what is needed. Can someone explain it to me? What runs where? Which devices are used? Does it only read the data or can the thermostat also be set per room from Domoticz? And last but not least: Does it work reliably?
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
