Zigate - Do not upgrade to Firmware 3.1b Topic is solved
tjabas
Re: Zigate - Do not upgrade to Firmware 3.1b
Post by tjabas »
i have tried this firmware 2 times now, but everytime i get problems with the ikea fyrtur blinds, they just wont work, and i cant re pair them, the log says something about unknown, im sorry but i havent kept the log, i went back to the older firmware.
pipiche
Post by pipiche »
After each restart of the plugin, All devices becomes Unknown and then will move to Live if any messages are received from them.
Not reachable could be after 2 cases:
- You received an APS Failure ( with firmware below 3.1b ) or you receive a NACK after sending a commande. Which basically means communication issue or device off
- A wireless device didn't send a message after a periode of time.
Last you don't need polling as now there is a PingDevice mecanishm (enabled by default) that you can set in the Settings
pfloryann
Domoticz version: 2025.2
Post by pfloryann »
They automatically change their status to offline even after only a few seconds of last use. I know that after restarting the plugin it takes a while but this is not the case here. For example, I stopped the xiaomi socket from domoticzy after a few seconds it is displayed offline. Also for IKEA bulb, aqara relay and some xiaomi motion sensors.
It seems random.
I swiched to stable now to check if the problem is only beta
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
pipiche
Post by pipiche »
Are you on the latest version on beta branch?
pfloryann
Post by pfloryann »
Yes
pfloryann
Post by pfloryann »
The same problem is on stable, some devices auto change the status to offline and get back to online after seconds or minutes but rarer than that on beta branch. I don't know how they check the status. For example 5 minutes ago i had 5 offline devices,now all devices is online.
Domoticz version is 4.11670 - the latest version
pipiche
Post by pipiche »
You might face interferences issues.
What is the Zigate channel ? What is your Wifi 2.4 Channel ?
Do you have Polling enabled ?
pfloryann
Post by pfloryann »
Zigate channel is default, Zigate is tll is not the wifi version, but you want to know what is the router channel...i must to check but i'm away. You suggest that could be some interference between zigbee and wifi? Is strange because always it was the same settings for wifi.
Yes, polling is enabled.
The problem appeared after the latest firmware 3.1c update and latest updates for domoticz and zigate plugin and i tested on 3 different pc's, one tablet and one phone and the issue is there.
For now all devices is connected without 1 which I disconnected for test..and domoticz displays correctly this time - stable branch
Last edited by pfloryann on Monday 03 February 2020 10:09, edited 1 time in total.
pipiche
Post by pipiche »
pfloryann wrote: Monday 03 February 2020 9:53 Zigate channel is default, Zigate is tll is not the wifi version, but you want to know what is the router channel...i must to check but i'm away. You suggest that could be some interference between zigbee and wifi? Is strange because always it was the same settings for wifi.
For now all devices is connected without 1 which I disconnected for test..and domoticz displays correctly this time.
Zigate channel is available in the log when plugin start.
Wifi 2.4 is the wifi you are using (not the Wifi zigate), as Wifi 2.4 and Zigbee are using the same band and that is why I'm thinking of interferences if you have overlap.
pfloryann
Post by pfloryann »
Zigate channel 0b , WiFi 2.4 it was auto channel... I swiched now to channel 1 for wifi
pipiche
Post by pipiche »
pfloryann wrote: Monday 03 February 2020 11:06 Zigate channel 0b , WiFi 2.4 it was auto channel... I swiched now to channel 1 for wifi
Do not put Wifi channel to 1 as it will overlap the Zigbee 0b. better to put Wifi on channel 11 as well
See here after
https://github.com/pipiche38/Domoticz-Z ... -Zigbee.md
