Can't get a easy dzVents Script working  [Solved]
Extremo
Domoticz version: 4.11605
Post by Extremo »
Hi Guys
I just played a bit around with dzVents to be warned, when one of my smokedetectors triggers - but I can't get it working:
-- Check if a SmokeDetector has been triggered.
	active = true,
	on = { "FM *" },                                --
	execute = function(domoticz, SmokeDetector)
    if SmokeDetector.state == "On" then
        domoticz.notify("FIRE ALARM: " .. SmokeDetector.name)
    end -- if SmokeDetector On
	end -- function
The name of my Smoke Detectos are starts always with "FM LocationName". They are set as active devices and set to smokedetector, also I changed the dzVents settings to log all and I get this output:
2020-02-01 12:11:47.372 (RFLink) Light/Switch (FM Erdgeschoss)
2020-02-01 12:11:47.417 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-02-01 12:11:47.452 Status: dzVents: Debug: Processing device-adapter for FM Erdgeschoss: Smoke Detector device adapter
2020-02-01 12:11:47.452 Status: dzVents: Debug: Processing device-adapter for FM Erdgeschoss: Switch device adapter
2020-02-01 12:11:47.452 Status: dzVents: Debug: dzVents version: 2.5.5
2020-02-01 12:11:47.452 Status: dzVents: Debug: Event triggers:
2020-02-01 12:11:47.453 Status: dzVents: Debug: - Device: FM Erdgeschoss
2020-02-01 12:12:00.517 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-02-01 12:12:00.552 Status: dzVents: Debug: Event triggers:
2020-02-01 12:12:00.552 Status: dzVents: Debug: - Timer
Does someone have a idea, what I did wrong?
boum
Domoticz version: 4.10717
Re: Can't get a easy dzVents Script working  [Solved]
Post by boum »
First thing is to change:
on = { "FM *" },
To:
on = { devices = { "FM *" } },
Documentation is here  https://www.domoticz.com/wiki/DzVents:_ ... 8837.2B.29
then there may be some other issues with the script. Add some domoticz.log messages to check values of the things you test.
HTH
Extremo
Post by Extremo »
Can I get a "shame" "shame" "shame" for me? It works now, thanks for pointing me on that dumb mistake!
