I use: SDM 630 https://github.com/MFxMF/SDM630-Modbus - connected domoticz OK.
import energy measurement day and night
when day domoticz idx 108 off
when night domoticz idx 108 on
when idx(27) --OWL !!! other meter Type: General,kWh !!! OK
when idx(341) --OWL !!! meter SDM 630 Type: RFXMeter, RFXMeter, Counter !!! does not work
log domoticz:
2020-01-29 17:12:43.021 Error: EventSystem: in day_night: [string "function log(p_message)..."]:25: attempt to concatenate a nil value (global 'consEnergy')
I need:
change the script to read the value RFXMeter,Counter
or:
or convert RFXMeter, Counter to the value General, kWh
I use this solution:
-- print("[HPHC] " .. p_message)
function getdevname4idx(deviceIDX)
for i, v in pairs(otherdevices_idx) do
if v == deviceIDX then
return i
return 0
DEBUG = false
local nomCompteurPrincipal = getdevname4idx(341) --OWL
local idxCompteurIntelligent = 363
local nomCompteurIntelligent = getdevname4idx(idxCompteurIntelligent)--HPHC
local nomHeureCreuse = getdevname4idx(108) -- Switch Heures Creuses
for deviceName,deviceValue in pairs(devicechanged) do
if (deviceName==nomCompteurPrincipal) then
-- On récupère la valeur du compteur unique => consEnergy
ConsPower, consEnergy = string.match(otherdevices_svalues[nomCompteurPrincipal], "(%d+%.*%d*);(%d+%.*%d*)")
log(ConsPower.."-"..consEnergy)
--on somme les compteurs HP et HC => EnergyImport
--http://www.domoticz.com/wiki/Upload_energy_data_to_PVoutput
EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[nomCompteurIntelligent]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
-- For the first time, the value are not initilize in the smart counter, we set 0 by default.
if(EnergyImportLow == nil)then
EnergyImportLow = 0
EnergyImportHigh = 0
EnergyExportLow = 0
EnergyExportHigh = 0
PowerImport = 0
PowerExport = 0
-- Lors du changement de pile du compteur unique, consEnergy a été réinitialisé, faussant complémtement les valeurs de EnergyImportLow/EnergyImportHigh
if((EnergyImportLow+0) < 0 or (EnergyImportHigh+0) < 0) then
EnergyImportLow =0
EnergyImportHigh =0
log(" ----- Reinit de EnergyImportLow/EnergyImportHigh");
EnergyImport = EnergyImportLow + EnergyImportHigh
EnergyExport = EnergyExportLow + EnergyExportHigh
log(" ----- PowerImport = " .. PowerImport .. " W");
log(" ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
log(" ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
log(" ----- EnergyImport = " .. EnergyImport .. " Wh");
log(" ----- PowerExport = " .. PowerExport .. " W");
log(" ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
log(" ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
log(" ----- EnergyExport = " .. EnergyExport .. " Wh");
--On calcule le delta avec le compteur actuel
delta = consEnergy - EnergyImport
--On ajoute le delta sur le bon tarif
if (otherdevices[nomHeureCreuse] == 'On') then
EnergyImportLow = EnergyImportLow + delta
EnergyImportHigh = EnergyImportHigh + delta
--On modifie le compteur intelligent
commandArray['UpdateDevice'] = idxCompteurIntelligent.."|0|"..EnergyImportLow..";"..EnergyImportHigh..";0;0;"..ConsPower..";0"
