Check variable value (if changed)  [Solved]
TheCondor
Post by TheCondor »
Hi, i want to do some actions when the content of a variable is changed.
Currently i have this script (the script is more articulated but i put the essential part) that do some actions according the value of two variable (Tag_Andrea - Tag_Ilaria) which is controlled by BLE presence script. These variable could have two string content: Out when someone is away from the house, Home when someone is back:
	       variables = {
		                    'Tag_Andrea',
		                    'Tag_Ilaria'
execute = function(domoticz, Tag)
if domoticz.variables('Tag_Andrea').value == 'Out' and domoticz.variables('Tag_Ilaria').value == 'Out' then
-------------- TURN ON THE ALARM AND DO MUCH MORE
elseif domoticz.variables('Tag_Andrea').value == 'Home' or domoticz.variables('Tag_Ilaria').value == 'Home' then
-------------- TURN OFF THE ALARM AND DO MUCH MORE
Now the problem is that often BLE plugin retest the value and write again the variables with the same content, but updating the 'last update' value.
How can i edit this script to be triggered only on variable content changed?
Thanks since now for your help!
Re: Check variable value (if changed)
TheCondor wrote: Tuesday 28 January 2020 13:11 Hi, i want to do some actions when the content of a variable is changed.
domoticz does not keep the value before the update anywhere so you wil have to do that in dzVents. That is why the script need to start but can stop immediate when the updated value is equal to the value before the update.
local tagAndrea = 'Tag_Andrea'
local tagIlaria = 'Tag_Ilaria'
return
    on =
        variables =
            tagAndrea,
            tagIlaria,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'vars with condition',
    data =
            tagAndrea ,
            tagIlaria
    execute = function(dz, item)
        if item.value == dz.data[item.name] then return end
        dz.data[item.name] = item.value
        local tagAndrea = dz.variables(tagAndrea).value
        local tagIlaria = dz.variables(tagIlaria).value
        if tagAndrea == 'Out' and tagIlaria == 'Out' then
            dz.log('Andrea and Ilaria out',dz.LOG_DEBUG)
        elseif tagAndrea == 'Home' or tagIlaria == 'Home' then
            dz.log('Andrea and / or Ilaria home ',dz.LOG_DEBUG)
            -- ----------- TURN OFF THE ALARM AND DO MUCH MORE
            dz.log('Does anyone know where Andrea and / or Ilaria is ? ',dz.LOG_DEBUG)
TheCondor
Re: Check variable value (if changed)  [Solved]
Post by TheCondor »
Perfect!!! Thank you so much!
Users browsing this forum: iw2fag and 1 guest
