Installing Domoticz on OpenElec RPi?
Humanjo
Hello everyone,,
I have no idea where to put my question - 'Installation' might be correct.
I have a Pi3 running OpenElec. OpenElec is a Kodi release which works great on a Pi, but is pretty closed (root access only, but no apt to install stuff). Oh, disclaimer: my *nix knowledge is quite basic, so I may be mixing things up.mobdro.bio/ luckypatcher.tips/ kodi.bio/
Anyway - I would like to monitor the temperature of the OpenElec machine (preferably via Domoticz which I have already installed on another RPi). My first idea was to install Domoticz on the openelec machine - but I cannot do this (curl and apt are not there).
Does anyone have similar setup? I tried searching but most of the results I get are either about controlling Kodi from Domoticz (via web), or just Kodi plugins to view the Domoticz dashboard within Kodi.
Last edited by Humanjo on Wednesday 29 January 2020 22:28, edited 1 time in total.
- Egregius
- Domoticz version: v2024.7
Re: Installing Domoticz on OpenElec RPi?
Run a shell script by cron on your openelec. The script must parse the temperature and sent it to domoticz.
- FireWizard
Humanjo wrote:
Therefore:
Step 1.
Create a virtual Temperature sensor.
- In Domoticz in "Setup" > "Hardware" > Create Dummy (Does nothing, use for virtual switches only).
- Click "Create Virtual Sensors".
- Create a "Temperature sensor". It will appear in the "Temperature" tab.
- Goto "Setup" > "Devices" and look up the newly created "Temperature" device and note down its Idx number. You will need that later.
Step 2
SSH into your OpenElec Raspberry Pi (By default the user is root and the password is openelec).
Create a script or copy the script to your OpenElec Pi, with the following contents:
I called the script "temp2domoticz.py" and make it executable (chmod 700 temp2domoticz.py)
Replace after serverIP = "192.168.10.50" the IP address with the IP address of your Domoticz server.
and replace deviceId =282 with the Idx, you just noted down.
A problem, you may encounter, is that "subprocess" and/or "time" and/or "os" and/or "urllib2" are not installed.
As I do not have OpenElec installed on a Raspberry Pi, I cannot test it. Remember OpenElec and also LibreElec are Just enough OS for Kodi.
Step 3.
Create the cronjob
Give the following command:
and insert the following line:
if you have the script installed in the /storage directory, this will give you an update every 5 minutes.
Humanjo wrote:
and Egregius wrote:Oh, disclaimer: my *nix knowledge is quite basic
I do not believe that this combination will result in a working script.Run a shell script by cron on your openelec. The script must parse the temperature and sent it to domoticz.
Therefore:
Step 1.
Step 2
$ ssh -l root <IP Address of OpenElec>I called the script "temp2domoticz.py" and make it executable (chmod 700 temp2domoticz.py)
#!/usr/bin/python
import subprocess
import time
import os
import urllib2
serverIP = "192.168.10.50:8080"
deviceId = 282
currentTemp = subprocess.check_output(["/usr/bin/vcgencmd","measure_temp"])
currentTemp = float(currentTemp.split("=")[1][:-3])
urllib2.urlopen("http://" + serverIP + "/json.htm?type=command¶m=udevice&idx=" + str(deviceId) + "&nvalue=0&svalue=" + str(currentTemp))and replace deviceId =282 with the Idx, you just noted down.
Step 3.
Create the cronjob
crontab -eCode: Select all
*/5 * * * * python /storage/temp2domoticz.pyRegards
Last edited by FireWizard on Monday 27 January 2020 17:53, edited 1 time in total.
- Egregius
Why would a shell script work? You're using a python script to execute shell commands...
Something simple like this should do:
#!/bin/bash
temp=$(vcgencmd measure_temp | grep -o '[0-9]*\.[0-9]*')
curl -s "http://192.168.2.3:8080/json.htm?type=command¶m=udevice&idx=2007&nvalue=0&svalue=$temp"- FireWizard
@ Egregius,
You said:
I agree with you, that a shell script will work. I had this Python script "on stock", which worked for me for more than a year, until I changed my setup.
What I wanted to say was that, if Humanjo says "Oh, disclaimer: my *nix knowledge is quite basic.", I do not expect that it is easy for him to create and run a shell script by cron on his openelec. The script must parse the temperature and sent it to domoticz. For an experienced user, writing such a script is not difficult, but for a basic user, it might be quite complex. But maybe I'm wrong.
Nevertheless, it is another way of sending the Temperature to Domoticz and maybe the only way of doing it on OpenElec, as for Python, we might miss some components, as I said. I realized that, after I had posted the Python solution, that a shell script would have been better.
At least, it triggered you to publish this shell script.
You said:
You probably mean: Why would a shell script not work?Why would a shell script work?
- Egregius
Yes, I had a typo indeed. I meant "not working"
And yes, because of this I quickly created that little script
