Switch off some switches depending on power usage  [Solved]
salvacalatayud
Post by salvacalatayud »
Hello friends, first of all sorry but I'm not programer and I have no idea of what I'm doing wrong.
I'm having problems with my energy usage, if too many things are On the electric company switches off the entire home. So I want to switch off some switches depending on power usage.
I've tried with this code but nothing happens:
    	timer = { 'every minute' }
        devices = {
            'contador',
            'calefaccion_Bernat',
            'calefaccion_papis',
            'calentador'
        local contador = domoticz.devices(92)
        local calefaccion_Bernat = domoticz.devices(11)
        local calefaccion_papis = domoticz.devices(137)
        local calentador = domoticz.devices(6)
        if (contador.actualWatt > 3250 and calefaccion_Bernat.state == 'On') then
                calefaccion_Bernat.switchOff().forMin(10)
                domoticz.notify ('Consumo alto, apago calefaccion','Consumo alto, apago calefaccion')
    if (contador.actualWatt > 3350 and calefaccion_papis.state == 'On') then
                calefaccion_papis.switchOff().forMin(9)
    if (contador.actualWatt > 3450 and calentador.state == 'On') then
                calentador.switchOff().forMin(11)
                domoticz.notify ('Consumo alto, apago calentador','Consumo alto, apago calentador')
If someone can tell me what is wrong I would appreciate
Last edited by salvacalatayud on Saturday 25 January 2020 16:03, edited 1 time in total.
Re: Switch off some switches depending on power usage
salvacalatayud wrote: Saturday 25 January 2020 11:22 I'm having problems with my energy usage, if too many things are On the electric company switches off the entire home. So I want to switch off some switches depending on power usage.
Please state your OS, your domoticz-version (is it really 3.8072 mentioned in your profile ?) and dzVents version and show us what you see in the log first. Without that information it's very hard to find any issues.
salvacalatayud
waaren wrote: Saturday 25 January 2020 14:21
Sorry, I thought it was a coding matter.
I'm running latest beta
OS raspbian stretch (updated)
dzVents Version: 2.5.7
Log errors found:
2020-01-25 15:58:54.829 Error: dzVents: Error: (2.5.7) error loading module 'apaga_todos_potencia' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/apaga_todos_potencia.lua':
2020-01-25 15:58:54.829 ...ripts/dzVents/generated_scripts/apaga_todos_potencia.lua:4: '}' expected (to close '{' at line 2) near 'devices'
[\code]
It is but with the log it is so much easyer to find.
You missed a comma behind
It must be
timer = { 'every minute' },
salvacalatayud
waaren wrote:It is but with the log it is so much easyer to find.
It must be
Thanks, it looks like working now, no log errors. But the .forMin() doesn't work, it switches off but never switch on after the desired time.
Enviado desde mi Mi A2 mediante Tapatalk
salvacalatayud wrote: Saturday 25 January 2020 23:14 The .forMin() doesn't work, it switches off but never switch on after the desired time.
I am not a big fan of the forXXX() approach myself. What I normally do is something like
                calefaccion_Bernat.cancelQueuedCommands()
                calefaccion_Bernat.switchOn().afterMin(10)
salvacalatayud
Re: Switch off some switches depending on power usage  [Solved]
Done, now is working perfect
