checkfirst and selectorswitches  [Solved]
pvklink
Domoticz version: latest b
Post by pvklink »
I have a selector switch that contains all sort of alarms (fire/smoke, panic, door, pir etc.)
When you select one, a aalrmtype is executed.
These alarmtypes can also be activated by sensors.
My latest sensor are PIR's, so i made an alarmtype Pir. Pir's go off x-times so i added .checkFirst() to the selector switch, and getting an error...
dz.devices('Alarm').switchSelector('Pir').checkFirst()
Isnt this supported?
Jablotron connection, Ikea
Re: checkfirst and selectorswitches
pvklink wrote: Friday 24 January 2020 18:20 dz.devices('Alarm').switchSelector('Pir').checkFirst()
Not yet but I am testing a modification to the code that will allow this. Should not take too long..
snellejellep
Post by snellejellep »
ah that's why that is causing errors for me... not yet supported. waiting for this feature!
pvklink
Post by pvklink »
great..
i see two scenarios....
1. check on switch on or off
2. more complex: check on switch on with the same option...
i am happy with every action...
pvklink wrote: Friday 24 January 2020 21:44 I see two scenarios....
Implemented in dzVents 2.5.7 (domoticz V4.11649). You should now be able to do something like
dz.devices('selectorName').switchSelector('levelName').afterSec(10).checkFirst().silent()
domoticz.devices(345).switchSelector(30).checkFirst()
or the likes...
Re: checkfirst and selectorswitches  [Solved]
waaren wrote: Saturday 25 January 2020 1:05
Implemented in dzVents 2.5.7 (domoticz V4.11650). You should now be able to do something like
or the likes...
pvklink
Post by pvklink »
Great!
will try it imm.
pvklink
Post by pvklink »
And it works!
Thanks @waaren
