Script starts too many times at specific time????
jaisomnmick
Post by jaisomnmick »
I've made a new script to control my outdoor lights (previous was in blockly). My first attempt worked (see an example at First code), but I noticed that when the script triggered at 15 minutes after sunset (or at 05:40), the script started more then 1000 times. The lights were going on and the logging of the lights showed ~2,130 entries (7 days of history). My Domotiz crashed a little later. To prevent that much of On commands, I've changed my script to the current script. Now the On and Off commands are only 1 or 2. But Domoticz is still crashing sometimes and I have the feeling that this is because of this script that starts still a lot of times in one minute (or is it coincidence?). Am I doing something wrong or is this a bug?https://19216811.cam/ https://xender.vip/ https://testmyspeed.onl/
             if domoticz.time.matchesRule(ONEVENING) then
                LOGGING = LOGGING .."\n".."Program On-Evening"
                    OUTDOORHALLWAY.switchOn()
                    OUTDOORSTORAGEROOM.switchOn()
SCRIPT DESCRIPTION:
This script turns on and off the outdoor lights based on time, sunset and sunrise.
DEVICES USED:
Idx 39 = Berging buitenlamp
Idx 43 = Gang buitenlamp
--SET USER INPUT VARIABLES:
local IDOSR = 39
local IDOHW = 43
local SECLLOFF = 60         -- turn off the lights after xx seconds at day time
local ONMORNING = 'at 05:40 on mon,tue,wed,thu,fri'
local OFFMORNING = '15 minutes before sunrise on mon,tue,wed,thu,fri'
local ONEVENING = '15 minutes after sunset'
local OFFEVENING = 'at 23:30'
local LOGGINGON = "Yes"     -- turn logging on or off (values: On = "Yes", Off = "No")
    active = true,
        devices = {
            IDOSR,
            IDOHW,
        timer = {
            ONMORNING,
            OFFMORNING,
            ONEVENING,
            OFFEVENING,
            'at sunset',
            'at sunrise',
            '2 minutes after sunrise',
    execute = function(domoticz, triggeredItem, info)
        --SET VARIABLES:
        local OUTDOORHALLWAY = domoticz.devices(IDOHW)
        local OUTDOORSTORAGEROOM = domoticz.devices(IDOSR)
        local LOGGING = "\n++++++++++++++++++++\n".."SCRIPT LIGHTS OUTDOOR:".."\n...................."
        -- EXECUTE SCRIPT
        LOGGING = LOGGING .."\n".."Outdoor light StorageRoom: "..OUTDOORSTORAGEROOM.state..", Outdoor light Hallway: "..OUTDOORHALLWAY.state
        if (domoticz.time.isNightTime) then
            LOGGING = LOGGING .."\n".."Program Nighttime active"
                if (OUTDOORHALLWAY.state == "Off") or (OUTDOORSTORAGEROOM.state == "Off") then
                    LOGGING = LOGGING .."\n".."Turn on the lights "..ONEVENING
                    LOGGING = LOGGING .."\n".."No action needed, lights "..OUTDOORSTORAGEROOM.state
            elseif domoticz.time.matchesRule(OFFEVENING) then
                LOGGING = LOGGING .."\n".."Program Off-Evening"
                if (OUTDOORHALLWAY.state == "On") or (OUTDOORSTORAGEROOM.state == "On") then
                    LOGGING = LOGGING .."\n".."Turn off the lights "..OFFEVENING
                    OUTDOORHALLWAY.switchOff()
                    OUTDOORSTORAGEROOM.switchOff()
            elseif domoticz.time.matchesRule(ONMORNING) then
                LOGGING = LOGGING .."\n".."Program On-Morning"
                    LOGGING = LOGGING .."\n".."Turn on the lights "..ONMORNING
            elseif domoticz.time.matchesRule(OFFMORNING) then
                LOGGING = LOGGING .."\n".."Program Off-Morning"
                    LOGGING = LOGGING .."\n".."Turn off the lights "..OFFMORNING
                LOGGING = LOGGING .."\n".."No action needed (night time)"
        elseif (domoticz.time.isDayTime) then
            LOGGING = LOGGING .."\n".."Program Daytime active"
                LOGGING = LOGGING .."\n".."Lights are on, turn off the lights in "..SECLLOFF .." seconds"
                OUTDOORHALLWAY.switchOff().afterSec(SECLLOFF)
                OUTDOORSTORAGEROOM.switchOff().afterSec(SECLLOFF)
                LOGGING = LOGGING .."\n".."No action needed (day time)"
            LOGGING = LOGGING .."\n".."No action needed (no night/day time)"
        LOGGING = LOGGING .."\n++++++++++++++++++++"
        --LOGGING:
        if (LOGGINGON == "Yes") then
            domoticz.log(LOGGING)
Last edited by jaisomnmick on Sunday 26 January 2020 6:29, edited 1 time in total.
boum
Domoticz version: 4.10717
Re: Script starts too many times at specific time????
Post by boum »
You set your script to be triggered by devices too. IDOSR is OUTDOORSTORAGEROOM so when you do OUTDOORSTORAGEROOM.switchOn(), the script will be triggered again. Inside the execute function, it will go through the same path.
You should remove the devices ={...} triggers, and add .silent() to your switchOn(), switchOff() calls to stop any other scripts to be triggered, or at least add checkFirst() if you want other script to be triggered on those devices.
(Maybe both if that's what you want.)
                    OUTDOORHALLWAY.switchOn().checkFirst().silent()
                    OUTDOORSTORAGEROOM.switchOn().checkFirst().silent()
If you want your script to react to the devices, you should test triggeredItem.isTimer and triggeredItem.isDevice to differentiate the source of the trigger.
