SOLVED - Plugin does not create devices for Sonoff Zigbee switch
Westcott
Post by Westcott »
I've got zigbee2mqtt and the plugin running and creating devices for other units.
The plugin docs say that the "ITEAD SONOFF ZigBee DIY Smart Switch" is already supported.
Zigbee2mqtt recognises it correctly, but the plugin does not create any devices for it.
Do I have to create a new adapter?
If so, is there a basic how-to guide, rather than it "can be added (fairly) easy by creating device adapter"
UPDATE
After restarting Domoticz it added correctly.
I think the plugin had stopped.
tukestolo
Re: SOLVED - Plugin does not create devices for Sonoff Zigbee switch
Post by tukestolo »
hii mate I am facing the same problem :/
I don't know what to do.
11:37:20.900 ZIG: {"ZbEZSPReceived":"45000004010204010100010000AFC0CC975DFFFF0818190A0000291A08"}
11:37:20.902 ZIG: {"ZbZCLReceived":{"groupid":0,"clusterid":"0x0402","srcaddr":"0x5D97","srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"LinkQuality":92,"securityuse":0,"seqnumber":175,"fc":"0x18","frametype":0,"direction":1,"disableresp":1,"manuf":"0x0000","transact":25,"cmdid":"0x0A","payload":"0000291A08"}}
11:37:20.904 ZIG: ZbZCLRawReceived: {"0x5D97":{"0402/0000":2074,"Endpoint":1,"LinkQuality":92}}
11:37:20.909 ZIG: {"ZbEZSPReceived":"45000004010504010100010000B0C0CC975DFFFF08181A0A0000213719"}
11:37:20.911 ZIG: {"ZbZCLReceived":{"groupid":0,"clusterid":"0x0405","srcaddr":"0x5D97","srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"LinkQuality":92,"securityuse":0,"seqnumber":176,"fc":"0x18","frametype":0,"direction":1,"disableresp":1,"manuf":"0x0000","transact":26,"cmdid":"0x0A","payload":"0000213719"}}
11:37:20.914 ZIG: ZbZCLRawReceived: {"0x5D97":{"0405/0000":6455,"Endpoint":1,"LinkQuality":92}}
11:37:21.312 MQT: tele/tasmota_A9EFE7/SENSOR = {"ZbReceived":{"0x5D97":{"Device":"0x5D97","Name":" Sala De Estar","Temperature":20.74,"Humidity":64.55,"Endpoint":1,"LinkQuality":92}}}
11:37:55.436 MQT: tele/tasmota_A9EFE7/STATE = {"Time":"2021-03-03T11:37:55","Uptime":"0T00:05:09","UptimeSec":309,"Vcc":3.448,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"GetoffmyLAN","BSSId":"CC:19:A8:AF:1B:50","Channel":6,"RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:42:55.462 MQT: tele/tasmota_A9EFE7/STATE = {"Time":"2021-03-03T11:42:55","Uptime":"0T00:10:09","UptimeSec":609,"Vcc":3.448,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"GetoffmyLAN","BSSId":"CC:19:A8:AF:1B:50","Channel":6,"RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
I can see all this information o Tasmota ZBBrigde, but in Domoticz I only see this strange logs :/
2021-03-03 10:45:47.186 (Zigbee) MqttClient::ping
2021-03-03 10:45:47.186 (Zigbee) Sending 2 bytes of data
2021-03-03 10:45:47.186 (Zigbee) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2021-03-03 10:45:47.237 (Zigbee) Received 2 bytes of data
2021-03-03 10:45:47.237 (Zigbee) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
Can you please help me.
