NEST Account migration
Ptje
- Domoticz version: 2020.2
Re: NEST Account migration
Does someone has any idea what my problem is. I have tried for days, but I can't get it work. I only get this.
2020-01-16 00:14:53.597 (Schaijk) Pushing 'onHeartbeatCallback' on to queue
2020-01-16 00:14:53.637 (Schaijk) Processing 'onHeartbeatCallback' message
2020-01-16 00:14:53.637 (Schaijk) Calling message handler 'onHeartbeat'.
2020-01-16 00:14:53.637 (Schaijk) onHeartbeat called
2020-01-16 00:14:53.637 (Schaijk) onHeartbeat called, run again in 28 heartbeats
I have read this topic several times, but I don's see what I'm doing wrong. Can somebody help ?
Greetings,
Peter
Greetings,
Peter
- rolandbreedveld
- Domoticz version: 2021.1
can't get the plugin working, Domoticz hangs after some minutes.
So waiting for official Domoticz Nest-Google support, I used the original php code from https://github.com/gboudreau/nest-api
created some virtual devices: switches, temp, Humidity and setpoind, build a unix cron-script arround it to update the device via the Domoticz json api.
also a a trigger script to enter eco-mode if no one is at home, and a dzVents event to change the setpoint
works pretty fine!
if you'r like it, code is below
works pretty fine!
- nest-api.tgz
- (241.96 KiB) Downloaded 112 times
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
- heggink
- Domoticz version: 12451
Hi Roland,
You missed one hardcoded idx in your script for setting the setpoint.
Since I needed the Eco mode switch, this is very helpful! Many thanks as well.
H
H
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- rolandbreedveld
Hi Heggink, which one are you missing?heggink wrote: Thursday 16 January 2020 23:59 Hi Roland,
H
both setpoint and eco-mode are there, I both use them,
set-point will trigger a dzvents script, which calls a phpfile to set the set-point, see the readme
the eco-mode switch self starts the enable/disable scripts, see the pictures and the readme
rmoria
- Domoticz version: 4.10717
I get the following:
Got $issue_token and $cookies as instructed
PHP Fatal error: Uncaught Error: Call to undefined function curl_init() in /home/pi/domoticz/scripts/nest-api/nest.class.php:1256
Stack trace:
#0 /home/pi/domoticz/scripts/nest-api/nest.class.php(1224): Nest->doRequest('GET', 'https://accoun...', NULL, true, Array)
#1 /home/pi/domoticz/scripts/nest-api/nest.class.php(1089): Nest->doGET('https://accoun...', Array)
#2 /home/pi/domoticz/scripts/nest-api/nest.class.php(124): Nest->login()
#3 /home/pi/domoticz/scripts/nest-api/get_nest.php(19): Nest->__construct(NULL, NULL, 'https://accoun...', 'OCAK=YXe7kE9rdi...')
#4 {main}
thrown in /home/pi/domoticz/scripts/nest-api/nest.class.php on line 1256
$issue_token = 'https://accounts.google.com/o/oauth2/iframerpc?action=issueToken&response_type=token%20id_token&login_hint=AJDLjxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxHgtbA&client_id=733xxxxxxxxxxxxxxxxxxxxxxxxxxxxxrq.apps.googleusercontent.com&origin=https%3A%2F%2Fhome.nest.com&scope=openid%20profile%20email%20https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fnest-account&ss_domain=https%3A%2F%2Fhome.nest.com';
$cookies = 'OCAK=YXe7kE9rdiP1V-x_xxxxxxxxxxxxxxxxxxu4; SID=swfHHHpxxxxxxx-YSCLMxxxxxxxxxxxxxxxxxXy_mkWvjbFxxxxxxxxxxxxxxxxxxRQ.; __Secure-3PSID=swfHHHpVxxxxxxxxxxxxxxxxxiXy_mkWvjqY4a8e3Zxxxxxxxxxxxxw.; HSID=AOALvZYoUgVo4O9Rn; SSID=AEQ4aQav4D8mO411a; APISID=VNxxxxxxxxxxTPf-/AZkdHXik_9Pvtk6zr; SAPISID=K_jXxxxxxxxxxxxxxxxxxxxxxxxxxxvwp; __Secure-HSID=AOALxxxxxxxxxxn; __Secure-SSID=AExxxxxxxx411a; __Secure-APISID=VNP6xxxxxxxxx/AZkdHXik_9Pvtk6zr; __Secure-3PAPISID=K_jXOxxxxxxxxxxxxxxvwp; NID=196=HbxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxWQg72jBnkJv_bGcxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxW2kFNyvogI1S-ZCn909xxxxxxxxx5_WnWXxxxxxxxxxxxxxxxxxrV8bNXwlcWM; CONSENT=YES+NL.nl+20151207-13-0; user_id=1xxxxxxxxxxxxxxxx; GAPS=1:o_PHSGxxxxxxxxxxxxxxxxxxxxxxxxxx3ILcqVdTQzxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxR0tOx_gS_AsU6xNveg:piJKoQwjcracw3k3; LSID=lso|s.NL|s.youtube:swfHHJIb6z6QvkV67CuOcxC1Z66EPAd-Z__UqXWMT9LKlokAI98tdshtXSGWwuRz2K3dlQ.; __Host-3PLSID=lso|s.NL|s.youtube:swfHHJIb6z6QvkV67CuOcxC1Z66EPAd-Z__UqXWMT9LKlokAJ1_PfLszcR9CrfLaB3WvHA.; ACCOUNT_CHOOSER=AFx_qI7n2OqzzcEcE-phsvO7ghFkIk0hoVwuU9MW6DuOkqshnryjnXG-giJg3iGnEccVcWgon0xB9qY059UF91qv0-7tdB3ikkcse_sElraYXBWkxqtFH3juy8ul23Qo3AylAOnPmcKO; SIDCC=AN0-TYsiA3N-V6jep5oxxxxxxxxxxxxxxxxxxxxxxxxxxxxDu0wh5A';- rolandbreedveld
@rmoria
Dit you create your own token and cookie, as instructed on: https://github.com/FilipDem/Domoticz-NE ... ree/master ?
the ones in the delivered file are fake.
- heggink
The last device update in your shell script still used your hardcoded device ID (462?). I changed it myself to ${IDX}.rolandbreedveld wrote:Hi Heggink, which one are you missing?heggink wrote: Thursday 16 January 2020 23:59 Hi Roland,
H
Sent from phone.
DASHTICZ 🙃
DASHTICZ 🙃
rmoria
Yes, I did. I just x-ed uit some stuff so I could post it.
Tried the keys from unrelated laptop and generated on my domoticz-pi3. All seem to have the same issue.
Is it possible to runwith just the google username/password ?
- rolandbreedveld
Thanxzz heggink
I understand, changed it together with some minor details.
- nest-api.tgz
- (241.99 KiB) Downloaded 101 times
- rolandbreedveld
username and password is not possible, perhaps you missed a part of it, don't forget it is between quotes and ending with ;rmoria wrote: Friday 17 January 2020 16:45 Yes, I did. I just x-ed uit some stuff so I could post it.
$issue_token = 'xxxx';
But, looking at your error, I see you are missing some php packages, like php5-curl, If you install these, it should work:
apt-get install libapache2-mod-php5 libphp-adodb php-pear php5 php5-cli php5-common php5-curl php5-gd php5-json php5-mysql php5-readline curl
rmoria
Does it work with a newer version ? The sudo apt-get ... says there are no candidates for installation.
php -v gives :PHP 7.0.33-0+deb9u6 (cli) (built: Oct 24 2019 18:50:20)
Standard raspbian strech
tinushigh
My PkuginMgr keeps crashing, right now your plugin is the only plugin I have installed. What do I do wrong?tinushigh wrote: Wednesday 15 January 2020 16:29 Ok, in the First Place, Filip, thanks for all the work, both developping and supporting! Upvote/like/+1
Please, I am quite new to SSH / linux / python and Domoticz so I made a mistake and cant figure out what.
Symptom: about 2 minutes after roboot / restart, my Domoticz crashes with these 2 error messages:
Question, where to start troubleshooting? How to solve this fatal error?Code: Select all
2020-01-15 16:24:12.654 Error: Domoticz(pid:1135, tid:1275('PluginMgr')) received fatal signal 6 (Aborted) 2020-01-15 16:24:12.655 Error: siginfo address=0x46f, address=(nil)
thanks in advance! A newbe
- rolandbreedveld
try php7.0-curl , think this is enoughrmoria wrote: Friday 17 January 2020 20:51 Does it work with a newer version ? The sudo apt-get ... says there are no candidates for installation.
tinushigh
Dear Roland, I would love to get this working and copy your setup, unfortunately I'm so new to Domoticz that I need some explanation on how to install your setup. Do I use SSH? WinSCP? Where to put the files? I need some help with the first step.rolandbreedveld wrote: Thursday 16 January 2020 12:25 can't get the plugin working, Domoticz hangs after some minutes.
works pretty fine!
Thanks in advance!
rmoria
Yes, It works fine now ( after sudo apt-get install php7.0-curl)
- rolandbreedveld
pretty simple:tinushigh wrote: Saturday 18 January 2020 21:11 Dear Roland, I would love to get this working and copy your setup, unfortunately I'm so new to Domoticz that I need some explanation on how to install your setup. Do I use SSH? WinSCP? Where to put the files? I need some help with the first step.
Thanks in advance!
(on raspberry pi)
use winscp to copy the file to /home/pi
ssh to it
cd /home/pi
extract the file: tar xzvf nest-api.tgz
cd /home/pi/nest-api
be shure you have curl and php-curl:
look which php version you have: dpkg -l|grep php
sudo apt-get install php7.0-curl curl
or if you have php5:
sudo apt-get install php5-curl curl
follow the instructions from the README, and enclosed images
to create the Virtual Sensors, create in the Hardware menu "Dummy (Does nothing, use for virtual switches only)", after creating, via the button, add all Virtual devices, they will show up on devices, see README and images which ones.
suc6!
Marcello1970
Thank you for your effort, it works perfectly.
Only one question, is it difficult to also get the status Away / Home and to controle it?
- heggink
That function is tied to the eco switch. Switch that on and it switched to away as well.
Sent from phone.
Sent from phone.
DASHTICZ 🙃
DASHTICZ 🙃
- rolandbreedveld
I will add it and post a new versionMarcello1970 wrote: Friday 24 January 2020 18:19 Thank you for your effort, it works perfectly.
Marcello1970
Thank you in advance!
