wild-char  [Solved]
yazul
Domoticz version: 4.10717
wild-char
Post by yazul »
Hi, everybody !
i don't understand why this sample script fails : user variable "presence_globale" doesn't matches the pattern "presence-*" ?
	active= true,
		variables= {
			"presence-*"
	logging= {
		level= domoticz.LOG_DEBUG
	execute = function(domoticz, variable)
		domoticz.log("trigger variable "..variable.name.." = "..tostring(variable.value).." changed "..tostring(variable.changedalue));
here is the log :
2020-01-13 07:56:32.830 Status: dzVents: Info: Handling variable-events for: "presence_globale", value: "1"
2020-01-13 07:56:32.830 Status: dzVents: Info: ------ Start external script: essai.lua: Variable: "presence_globale" Index: 29
2020-01-13 07:56:32.830 Status: dzVents: Info: trigger variable presence_globale = 1 changed nil
2020-01-13 07:56:32.830 Status: dzVents: Info: ------ Finished essai.lua
My version :
Version: 4.10717
Build Hash: b38b49e
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Re: wild-char
yazul wrote: Monday 13 January 2020 19:45 i don't understand why this sample script fails : user variable "presence_globale" doesn't matches the pattern "presence-*" ?
From the script I cannot determine what it should print but changedalue does not exist as a valid method or attribute of an object of type variable. That is why you see nil.
See below script and some output of it. It might point you in the right direction.
dz Essai
	active= true,
		variables= {
			"presence-*"
	logging= {
	    -- changedalue does not exist as a valid method or attribute of an objkect of type variable
	    -- domoticz.log("trigger variable "..variable.name.." = "..tostring(variable.value).." changed " .. tostring(variable.changedalue));
		domoticz.utils.dumpTable(variable)
		domoticz.log("trigger variable "..variable.name.." = ".. tostring(variable.value).." changed ",domoticz.LOG_DEBUG)
log when triggered by setting variable to integer 6
2020-01-13 09:19:19.808  Status: dzVents: Info: Handling variable-events for: "presence-test", value: "6"
2020-01-13 09:19:19.808  Status: dzVents: Info: ------ Start internal script: dz Essai : Variable: "presence-test" Index: 2
2020-01-13 09:19:19.808  Status: dzVents: > nValue: 6
2020-01-13 09:19:19.808  Status: dzVents: > set()
2020-01-13 09:19:19.808  Status: dzVents: > isHTTPResponse: false
2020-01-13 09:19:19.808  Status: dzVents: > isGroup: false
2020-01-13 09:19:19.808  Status: dzVents: > lastUpdate:
2020-01-13 09:19:19.810  Status: dzVents: > name: presence-test
2020-01-13 09:19:19.810  Status: dzVents: > value: 6
2020-01-13 09:19:19.810  Status: dzVents: > isVariable: true
2020-01-13 09:19:19.810  Status: dzVents: > rename()
2020-01-13 09:19:19.810  Status: dzVents: > isTimer: false
2020-01-13 09:19:19.810  Status: dzVents: > type: integer
2020-01-13 09:19:19.810  Status: dzVents: > id: 2
2020-01-13 09:19:19.810  Status: dzVents: > isSecurity: false
2020-01-13 09:19:19.810  Status: dzVents: > changed: true
2020-01-13 09:19:19.810  Status: dzVents: > isScene: false
2020-01-13 09:19:19.810  Status: dzVents: > baseType: variable
2020-01-13 09:19:19.810  Status: dzVents: > isDevice: false
2020-01-13 09:19:19.810  Status: dzVents: Debug: trigger variable presence-test = 6 changed
2020-01-13 09:19:19.810  Status: dzVents: Info: ------ Finished dz Essai
log when triggered by setting variable to string 'present'
2020-01-13 09:22:19.358  Status: dzVents: Info: Handling variable-events for: "presence-test string", value: "present"
2020-01-13 09:22:19.358  Status: dzVents: Info: ------ Start internal script: dz Essai: Variable: "presence-test string" Index: 3
2020-01-13 09:22:19.358  Status: dzVents: > value: present
2020-01-13 09:22:19.359  Status: dzVents: > isSecurity: false
2020-01-13 09:22:19.359  Status: dzVents: > id: 3
2020-01-13 09:22:19.359  Status: dzVents: > type: string
2020-01-13 09:22:19.359  Status: dzVents: > isTimer: false
2020-01-13 09:22:19.359  Status: dzVents: > isVariable: true
2020-01-13 09:22:19.361  Status: dzVents: > set()
2020-01-13 09:22:19.361  Status: dzVents: > isDevice: false
2020-01-13 09:22:19.361  Status: dzVents: > isScene: false
2020-01-13 09:22:19.361  Status: dzVents: > isHTTPResponse: false
2020-01-13 09:22:19.361  Status: dzVents: > isGroup: false
2020-01-13 09:22:19.361  Status: dzVents: > rename()
2020-01-13 09:22:19.361  Status: dzVents: > name: presence-test string
2020-01-13 09:22:19.361  Status: dzVents: > baseType: variable
2020-01-13 09:22:19.361  Status: dzVents: > changed: true
2020-01-13 09:22:19.361  Status: dzVents: Debug: trigger variable presence-test string = present changed
2020-01-13 09:22:19.361  Status: dzVents: Info: ------ Finished dz Essai
yazul
Re: wild-char
Post by yazul »
waaren wrote: Monday 13 January 2020 20:05
Thanks for your answer...
The problem (except changedalue, sorry for that) is :
i want to select only variables beginning with "presence-".
But the script is triggered for "presence_globale" wich doesn't begin with the search pattern...
hyphen is not underscore !
what did i missed ?
Re: wild-char
yazul wrote: Wednesday 15 January 2020 17:21 The problem (except changedalue, sorry for that) is : i want to select only variables beginning with "presence-".
But the script is triggered for "presence_globale" wich doesn't begin with the search pattern... what did i missed ?
You did not miss anything. This is a bug that existed in the code until some months ago. It was corrected in a recent beta
yazul
Re: wild-char  [Solved]
Post by yazul »
