RFLink <=> Livolo support (ON/OFF mode instead of Toogle mode)
433Mhz opensource Receiver & Transmitter.
shalwia
Post by shalwia »
I'm using Domoticz & RFLink set to control some of my home appliances (blinds etc.). Some time ago I bought a few Livolo wall switches supporting 433 Mhz communication (mainly due to the fact that it was stated on RFLink official website it's supporting Livolo).
After installation of the wall switches I have a problem to synchronize it properly with the Domoticz. The problem is that I can't set a different codes for ON and OFF switch mode. The switch is working just in the toggle mode, which makes controlling the devices quite confusing (e.g. it may appear that I switch on light instead of switching it off etc.). I have reviewed the threads on this forum and look for some help in the Google but seems nobody discovered if (and how) it's possible to solve it somehow.
DEN1304
Re: RFLink <=> Livolo support (ON/OFF mode instead of Toogle mode)
Post by DEN1304 »
I have exactly the same issue, the only difference is that I’m using RFcom Tx/Rx transmitter.
I had no issue with previous Domoticz version.
Shalwia did you receive any solution?
Cheers
DEN1304
