Node ID 0x0000 and Type 0x0000 on working Zwave nodes
mchangsp
Domoticz version: 3.4834
Post by mchangsp »
Since a week I have Zwave nodes with Node ID 0x0000 and Type 0x0000 in the zwave list .
I find this very strange because the setup has been working for 5+ years without a problem
Example screenshot: https://www.flickr.com/gp/mchangsp/3C09A3
I can find the original IDs in the Domoticz definitions of the devices
I alreay tried this a few times:
- stop domoticz
- delete zw_cfg_*.xml file (containing the cache)
- reboot raspberry pi
- start domoticz
The Node ID and Type still stay on zero.
The domoticz log shows no zwave errors.
Any tips which I can try so the zwave list displays the correct IDs?
What I find most strange is that the zwave USB stick has no Node ID
Platform details
Raspberry Pi 3
Aeon Z-Stick Gen5
Domoticz:
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.4.2 (default, Oct 19 2014, 14:03:53) [GCC 4.9.1]
hestia
Domoticz version: 2022.1
Re: Node ID 0x0000 and Type 0x0000 on working Zwave nodes
Post by hestia »
Try this: On the Node tab do a device refresh on the node
if it's a "sleeping device", use the wake-up button (after the refresh I think)
If still ko, try:
- delete ozwcache.... file in /domoticz/Conf
- restart domoticz and let it finish z-wave initialization (takes longer as usual)
- on the Node tab do a device refresh on the node
see also
https://www.domoticz.com/forum/viewtopi ... 15#p225812
viewtopic.php?f=24&t=20999
mchangsp
Post by mchangsp »
OK thanks I will try and keep you posted
Superdeboer
Domoticz version: 2021.1
Post by Superdeboer »
I encountered this same problem after adding a Qubino dimmer to the network.
Immediately after, the entire list of nodes was empty when I viewed the Setup of my Aeon Z-Stick. This was fixed by rebooting Raspbian, restarting Domoticz and removing and readding the Z-Stick (I really don't know in what order...).
Then the nodes showed up, but most of them with the Node ID 0x0000 and Type 0x0000.
I found this topic, and solved the problem by:
cd /home/pi/domoticz/
sudo service domoticz.sh stop
sudo cp ozwcp.poll.XXXXXX.xml ozwcp.poll.XXXXXX.xml.bak
sudo rm ozwcp.poll.XXXXXX.xml
sudo service domoticz.sh start
Then all the nodes displayed with right ID and Type again, but all my PIR's had a generic discription in red italics. To get that fixed, I had to wake all said PIR's individually by pressing the inclusion button on the device.
Thanks for the help.
