Controlling Toon [HACKED] from Domoticz
annesdomotic
Domoticz version: 4.9700
Re: Controlling Toon [HACKED] from Domoticz
Post by annesdomotic »
EdwinK wrote: Saturday 14 December 2019 10:07 Thanks for this. Luckily, for me it's working since a few weeks.
Did you know that if you put your scripts in [c o d e] and [/ c o d e] (remove spaces) it will make it more readable, and easier to copy/paste.
i didnt know, thnxs
* raspberry pi3b+
* rooted toon 2
maikelvds
Post by maikelvds »
After a day working to Domoticz and Toon I think i'm almost done with the script to read out the Toon values.
I have 1 error left:
2019-12-30 23:54:00.715 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-12-30 23:54:00.714 Error: dzVents: Error: (2.5.3) -=# P1 Toon #=-: An error occurred when calling event handler Toon_script
2019-12-30 23:54:00.714 Error: dzVents: Error: (2.5.3) -=# P1 Toon #=-: /home/pi/domoticz/dzVents/runtime/Utils.lua:83: attempt to perform arithmetic on a nil value (local 'x')
The room temperature is also not actual. I can set Toon, by the setpoint switch and with the scenes switch.
The temperature from the Boiler is working, in and out.
I have add the user variables as on the last page, from Patrick.
Anybody an idea?
maikelvds
Post by maikelvds »
maikelvds wrote: Monday 30 December 2019 23:59 After a day working to Domoticz and Toon I think i'm almost done with the script to read out the Toon values.
Anybody an idea?
Fixed it. My boiler is quite old so he is not passing trough al info the script wants. In that case a nill value appears.
Delete the parts of the script that get a nil value and everything works.
maikelvds
Post by maikelvds »
Is it also possible to get the humidity values out of Toon2?
LeonS
Domoticz version: 4.10717
Post by LeonS »
First I was trying some other scripts, UV's and devices settings from domoticaforum.eu and ehoco.nl ( they appeared first on google ;) ) Unfortunately they caused my Domoticz to crash in such a way that restoring was necessary.
So this week I tried the @madpatrick method.
using the UV's and devicenames he mentioned in the last 4 pages of this forum
The first win: Setting the Toon Thermostaat Switch results in a change on the rooted Toon, instead of crashing domoticz
Unfortunately in the Toon-script script it seems like the script doing nothing from the start, and quits somewhere in one of the first lines of the script.
2020-01-08 22:31:00.583 Status: dzVents: Info: ------ Start internal script: Toon_script:, trigger: every minute
2020-01-08 22:31:00.714 Status: dzVents: Error (2.4.19): An error occured when calling event handler Toon_script
2020-01-08 22:31:00.714 Status: dzVents: Error (2.4.19): /home/pi/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2020-01-08 22:31:00.714 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2020-01-08 22:31:00.714 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2020-01-08 22:31:00.714 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2020-01-08 22:31:00.714 <head>
2020-01-08 22:31:00.714 <title>404 - Not Found</title>
2020-01-08 22:31:00.714 </head>
2020-01-08 22:31:00.714 <body>
2020-01-08 22:31:00.714 <h1>404 - Not Found</h1>
2020-01-08 22:31:00.714 </body>
2020-01-08 22:31:00.714 </html>
2020-01-08 22:31:00.714 Status: dzVents: Info: ------ Finished Toon_script
Checking the values in Domoticz Devices shows me that none of them are updated.
Can someone please advise me?
Kind regards, LeonS
OedzesG
Post by OedzesG »
i have tryd manny scripts but for my it was the same.. lots of errors and not working or craching my domoticz.
So i made a verry simple script witch downloads the data from toon to update my devices in Domoticz with only 3 UserVariable
if you want i can share it?
LeonS
Post by LeonS »
Oooh Yes please 8-)
OedzesG
Post by OedzesG »
oké, here we go...
first lets make the dummy devices, you have to create:
(hope youre Dutch! :D )
* selector switch: TOON scene
* selector switch: TOON programma
* selector switch: TOON huidige activiteit
* temperature sensor: TOON kamer temperatuur
* customsensor: TOON modulatie niveau (as-label = % )
* Thermostaat setpoint: TOON thermostaat
now we need to change te level names and level actions in the selector switches we just created.
Its important you call the level names exactly!:
* TOON scene
* level 0: Handmatige temp. instelling
* level 10: Comfort
* level 20: Thuis
* level 30: Slapen
* level 40: Weg
* level 50: Vakantie
* also activate: Verberg uit niveau!
level actions:
level 0: leave empty (its updating by the script when changing setpoint manualy!)
level 10: http://TOON_IP/happ_thermstat?action=changeSchemeState&state=2&temperatureState=0
level 20: http://TOON_IP/happ_thermstat?action=changeSchemeState&state=2&temperatureState=1
level 30: http://TOON_IP/happ_thermstat?action=changeSchemeState&state=2&temperatureState=2
level 40: http://TOON_IP/happ_thermstat?action=changeSchemeState&state=2&temperatureState=3
level 50: http://TOON_IP/happ_thermstat?action=setSetpoint&Setpoint=60
now it look like this:
TOON scene.PNG (50.23 KiB) Viewed 2510 times
now open the selector switch TOON programma:
level 0: Uit
level 10: Aan
level 20: Aan / afwijkend
level actions:
level 0: http://TOON_IP/happ_thermstat?action=changeSchemeState&state=0
level 10: http://TOON_IP/happ_thermstat?action=changeSchemeState&state=1
level 20: leave empty
should look like this:
TOON programma.PNG (25.7 KiB) Viewed 2510 times
now the final selector switch TOON huidige activiteit:
heren we only have to change the level names:
* level 0: Geen
* level 10: Verwarm. CV
* level 20: Verwarm. water
* level 30: Voor verwarm.
* also activate Verberg uit niveau
TOON activiteit.PNG (25.1 KiB) Viewed 2510 times
now you can go to youre devices menu en note the IDX numbers of the switches you just created, you need to set them in the in the script.
here comes the script:
	local ToonIpAdres             					= '192.168.1.61'      	-- IP adres rooted TOON thermostaat
	local IDX_ToonActieveScene 				= 56 				-- IDX nummer van TOON scene / selector switch
	local IDX_ToonProgrammaVerloop			= 57 				-- IDX nummer van TOON programma / selector switch
	local IDX_ToonDoelTemperatuurThermostaat 	= 58 				-- IDX nummer van TOON thermostaat setpoint
	local IDX_ToonHuidigeKamerTemperatuur 		= 59 				-- IDX nummer van TOON kamer temperatuur
	local IDX_ToonHuidigeModulatieNiveau 		= 60 				-- IDX nummer van TOON modulatie niveau / custom sensor
	local IDX_ToonHuidigieActiviteit 			= 61 				-- IDX nummer van TOON huidige activiteit / slector switch
	local   UV_ThermostaatHelper 				= 'toon_thermostaat_helper'   -- als het goed is niet veranderen
	local scriptVersion = 'Versie 1.3'
	local scriptVar = 'TOON Thermostaat ' .. scriptVersion
	return
		{ on = {
        httpResponses = { scriptVar },
       		 timer = {'every minute'},},
	    		logging = { level = domoticz.LOG_INFO,
       		 	marker = scriptVar },
	if (item.isTimer) then
	domoticz.openURL({
        url = 'http://' .. ToonIpAdres .. '/happ_thermstat?action=getThermostatInfo',
        method = 'GET',
        callback = scriptVar,})
	if (item.isHTTPResponse) then
	domoticz.utils.dumpTable(item.headers)
	if item.ok then
	local   rawJSON = domoticz.utils.fromJSON(item.data)
	local   myData  = rawJSON
	local   ToonActieveScene = myData.activeState
	if 		ToonActieveScene ==  '-1' then ToonActieveSceneUpdateWaarde = 'Handmatige temp. instelling'
	elseif 	ToonActieveScene ==  '0' then ToonActieveSceneUpdateWaarde = 'Comfort'
	elseif 	ToonActieveScene ==  '1' then ToonActieveSceneUpdateWaarde = 'Thuis'
	elseif 	ToonActieveScene ==  '2' then ToonActieveSceneUpdateWaarde = 'Slapen'
	elseif 	ToonActieveScene ==  '3' then ToonActieveSceneUpdateWaarde = 'Weg'
	elseif 	ToonActieveScene ==  '4' then ToonActieveSceneUpdateWaarde = 'Vakantie'
    	domoticz.log( '----- Toon actieve scéne = ' .. tostring(ToonActieveSceneUpdateWaarde))
	domoticz.devices(IDX_ToonActieveScene).switchSelector(ToonActieveSceneUpdateWaarde).silent()
	local ToonProgrammaVerloop = myData.programState
	if ToonProgrammaVerloop == '0' then ToonProgrammaVerloopUpdateWaarde = 'Uit'
	elseif ToonProgrammaVerloop == '1' then ToonProgrammaVerloopUpdateWaarde = 'Aan'
	elseif ToonProgrammaVerloop == '2' then ToonProgrammaVerloopUpdateWaarde = 'Aan / afwijkend'
	elseif ToonProgrammaVerloop == '8' then ToonProgrammaVerloopUpdateWaarde = 'Aan / afwijkend'
    	domoticz.log( '----- Toon automatisch programma verloop = ' .. tostring(ToonProgrammaVerloopUpdateWaarde))
	domoticz.devices(IDX_ToonProgrammaVerloop).switchSelector(ToonProgrammaVerloopUpdateWaarde).silent()
	local ToonDoelTemperatuurThermostaat = myData.currentSetpoint / 100
	domoticz.log( '----- Doel temperatuur voor thermostaat: '.. tostring(ToonDoelTemperatuurThermostaat))
	domoticz.variables(UV_ThermostaatHelper).set(1)
	domoticz.devices(IDX_ToonDoelTemperatuurThermostaat).updateSetPoint(ToonDoelTemperatuurThermostaat).silent()
	local ToonHuidigeKamerTemperatuur =   domoticz.utils.round((myData.currentTemp / 100),1)
    domoticz.log( '----- Huidige woonkamer temp. = ' .. tostring(ToonHuidigeKamerTemperatuur))
	domoticz.devices(IDX_ToonHuidigeKamerTemperatuur).updateTemperature(ToonHuidigeKamerTemperatuur).silent()
	local ToonHuidigeModulatieNiveau  =   myData.currentModulationLevel
    domoticz.log( '----- Huidige modulatie niveau = ' .. tostring(ToonHuidigeModulatieNiveau))
	domoticz.devices(IDX_ToonHuidigeModulatieNiveau).updateCustomSensor(ToonHuidigeModulatieNiveau).silent()
	local ToonHuidigieActiviteit = myData.burnerInfo
	if ToonHuidigieActiviteit == '0'  then ToonHuidigieActiviteitUpdateWaarde = 'Geen'
	elseif ToonHuidigieActiviteit == '1' then ToonHuidigieActiviteitUpdateWaarde = 'Verwarm. CV'
	elseif ToonHuidigieActiviteit == '2' then ToonHuidigieActiviteitUpdateWaarde = 'Verwarm. water'
	elseif ToonHuidigieActiviteit == '3' then ToonHuidigieActiviteitUpdateWaarde = 'Voor verwarm.'
    domoticz.log( '----- Huidige activiteit = ' .. tostring(ToonHuidigieActiviteitUpdateWaarde))
	domoticz.devices(IDX_ToonHuidigieActiviteit).switchSelector(ToonHuidigieActiviteitUpdateWaarde).silent()
if everything is oke, you see something like this in youre logs:
2020-01-09 19:41:00.668 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ----- Toon actieve scéne = Thuis
2020-01-09 19:41:00.672 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ----- Toon automatisch programma verloop = Uit
2020-01-09 19:41:00.672 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ----- Doel temperatuur voor thermostaat: 20.0
2020-01-09 19:41:00.672 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ----- Huidige woonkamer temp. = 20.1
2020-01-09 19:41:00.673 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ----- Huidige modulatie niveau = 5
2020-01-09 19:41:00.673 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ----- Huidige activiteit = Geen
2020-01-09 19:41:00.673 Status: dzVents: Info: TOON Thermostaat Versie 1.3: ------ Finished Toon (Thermostaat data naar Domoticz)
OedzesG
Post by OedzesG »
To update youre setpoint from Domoticz to TOON you need to use this LUA script! (NOT DzVents!)
its important you select Device at the trigger settings!
like this:
the script:
	ToonThermostatSensorName = uservariables['toon_thermostaat_naam'] -- Sensor showing current setpoint
	ToonIP = uservariables['toon_ip']
	for deviceName,deviceValue in pairs(devicechanged) do
	if (deviceName == ToonThermostatSensorName) then
	if uservariables['toon_thermostaat_helper'] == 1 then
	commandArray['Variable:toon_thermostaat_helper'] = '0'
	SetPoint = otherdevices_svalues[ToonThermostatSensorName]
	ToonCommand = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
	print('Setting Toon setpoint to '.. SetPoint)
	commandArray['OpenURL'] = ToonCommand
no changes or settings needed in this script!
I hope everything is working now!!
Goodluck..
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
LeonS wrote: Wednesday 08 January 2020 22:38 Hi all,
Kind regards, LeonS
It looks like there is an error in the scipt
If you can share more information, i can maybe check for you where it is going wrong.
What is the logfile saying ? Put the logging on debug
LeonS
Post by LeonS »
OedzesG wrote: Thursday 09 January 2020 19:55 To update youre setpoint from Domoticz to TOON you need to use this LUA script! (NOT DzVents!)
----Edited----
Goodluck..
Thanks for your examples, OedzesG.
Let me first try to fix things using the advice of Madpatrick. If that doesn't work, I'll restore and try using your solution.
madpatrick
Check-double check (triple-check) your settings, names and Uservariables.
The most problems a those related.
LeonS
Post by LeonS »
It's just like a jigsaw puzzel :) I have a lot of fun tying to read the script and disabling lines:
Results till now::
  • Dev_27 (Dev_2.7) Is for power delivery from solar panels, I don't have them so I disabled every line containing it and containg formulas with it.
  • boilerstatus/boilervalues.txt doesn't exist in my Toon, So i think there's someting with my Toon configuration or My Remeha just doesn't deliver those values.
Some more values are updated now in the domoticz devices list. The only one missing except the ketel related devices is P1 elektra. Will check that one now.
OedzesG
Post by OedzesG »
@LeonS
Im using also the std. TOON P1 SlimmeMeter.
Here's my script for downloading the data en updating the Domoticz Devices.
you can verry quicly test by turning the script you now using off en just set the 2 IDX numbers en TOON ip adres..
local IDX_DomoticzSlimmeMeterGas = 53
local IDX_DomoticzSlimmeMeterStroom = 54
local scriptVersion = 'Script 1.1'
local scriptVar = 'P1 SlimmeMeter ' .. scriptVersion
return
{ on = {
logging = { level = domoticz.LOG_ERROR,
domoticz.openURL({
url = 'http://'.. ToonIpAdres ..'/hdrv_zwave?action=getDevices.json',
method = 'GET',
callback = scriptVar, })
if item.ok then
local mijnSlimmeMeterGas = rawJSON['dev_2.1']
local mijnSlimmeMeterElectrischHoog = rawJSON['dev_2.4']
local mijnSlimmeMeterElectrischDal = rawJSON['dev_2.6']
local mijnMeterStandGas = mijnSlimmeMeterGas.CurrentGasQuantity
local mijnHuidigeGasVerbruik = mijnSlimmeMeterGas.CurrentGasFlow
local mijnMeterStandElectrischHoog = mijnSlimmeMeterElectrischHoog.CurrentElectricityQuantity
local mijnHuidigeElectrischeVerbruikHoog = mijnSlimmeMeterElectrischHoog.CurrentElectricityFlow
local mijnMeterStandElectrischDal = mijnSlimmeMeterElectrischDal.CurrentElectricityQuantity
local mijnHuidigeElectrischeVerbruikDal = mijnSlimmeMeterElectrischDal.CurrentElectricityFlow
local mijnHuidigeElectrischeVerbruikTotaal = mijnHuidigeElectrischeVerbruikHoog + mijnHuidigeElectrischeVerbruikDal
local DataTerugLevering = '0'
local mijnMeterStandGasInM3 = mijnMeterStandGas / 1000
domoticz.devices(IDX_DomoticzSlimmeMeterGas).updateGas(mijnMeterStandGas)
domoticz.devices(IDX_DomoticzSlimmeMeterStroom).updateP1(mijnMeterStandElectrischHoog, mijnMeterStandElectrischDal,
DataTerugLevering, DataTerugLevering, mijnHuidigeElectrischeVerbruikTotaal, DataTerugLevering).silent()
domoticz.log( '********** DOMOTICZ SLIMME METER GAS EN ELECTRISCH UPDATED' )
domoticz.log( '********** NIEUWE METERSTAND GAS = '.. domoticz.utils.round(mijnMeterStandGasInM3,3).. ' m3')
if mijnHuidigeElectrischeVerbruikHoog >= '1' then
domoticz.log( '********** ELECTRISCH MOMENTEEL LEVERING TEGEN HOOG TARIEF!!' )
domoticz.log( '********** HUIDIGE VERBRUIK ELECTRISCH = ' .. domoticz.utils.round(mijnHuidigeElectrischeVerbruikTotaal,2)..' Watt' )
elseif mijnHuidigeElectrischeVerbruikDal >= '1' then
domoticz.log( '********** ELECTRISCH MOMENTEEL LEVERING TEGEN LAAG TARIEF!!' )
OedzesG
Post by OedzesG »
sorry use it like this..
	return
	{ 	on = {
	domoticz.openURL({
		method 	= 'GET',
	if item.ok then
	domoticz.devices(IDX_DomoticzSlimmeMeterStroom).updateP1(mijnMeterStandElectrischHoog, mijnMeterStandElectrischDal, DataTerugLevering, DataTerugLevering, mijnHuidigeElectrischeVerbruikTotaal, DataTerugLevering).silent()
    domoticz.devices(IDX_DomoticzStatusText).updateText('Status SlimmeMeter : ' .. (mijnSlimmeMeterStatus))
LeonS
Post by LeonS »
I've got a double electricity meter
http://[toon ip address]/hdrv_zwave?action=getDevices.json gives met the result below: (added some CR's for better readability)
{"dev_settings_device": {"uuid": "ccef439a-3e4c-4b0c-b9eb-0dbb48bc433f", "name": "settings_device", "internalAddress": "settings_device", "type": "settings_device"},
"dev_2": {"uuid": "e4e84c12-1533-432e-a8db-fd24b609c10f", "name": "HAE_METER_v2", "internalAddress": "2", "type": "HAE_METER_v2", "supportsCrc": "1",
"ccList": "22 3c 3d 3e 56 60 70 72 7a 86 8b 73", "supportedCC": "22 3c 3d 3e 56 60 70 72 7a 86 8b 73", "nodeFlags": [], "IsConnected": "1", "HealthValue": "10",
"DeviceName": "HAE_METER_v2", "CurrentSensorStatus": "UNKNOWN"},
"dev_2.1": {"uuid": "c555bd27-b34a-476b-ac1f-378de4275767", "name": "HAE_METER_v2_1", "internalAddress": "2.1", "type": "HAE_METER_v2_1", "supportsCrc": "0",
"ccList": "3c 3d 3e 72 86", "supportedCC": "3c 3d 3e 72 86", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "CurrentGasFlow": "0.00",
"CurrentGasQuantity": "6895449.00", "DeviceName": ""},
"dev_2.2": {"uuid": "ed5a2742-99b1-47a5-935f-f523d5cd0e8b", "name": "HAE_METER_v2_2", "internalAddress": "2.2", "type": "HAE_METER_v2_2", "supportsCrc": "0",
"ccList": "3c 3d 3e 72 86", "supportedCC": "3c 3d 3e 72 86", "nodeFlags": [], "CurrentSensorStatus": "DISABLED", "DeviceName": "", "CurrentElectricityFlow": "NaN",
"CurrentElectricityQuantity": "NaN"},
"dev_2.3": {"uuid": "74f9a385-aaa5-450e-8e11-317f852fc806", "name": "HAE_METER_v2_3", "internalAddress": "2.3", "type": "HAE_METER_v2_3", "supportsCrc": "0",
"ccList": "3c 3d 3e 72 86", "supportedCC": "3c 3d 3e 72 86", "nodeFlags": [], "CurrentSensorStatus": "OPERATIONAL", "DeviceName": "", "CurrentElectricityFlow": "674.00",
"CurrentElectricityQuantity": "10366284.00"},
"dev_2.4": {"uuid": "bdda3dbe-4867-4ca0-9229-c921f8685174", "name": "HAE_METER_v2_4", "internalAddress": "2.4", "type": "HAE_METER_v2_4", "supportsCrc": "0",
"ccList": "3c 3d 3e 72 86", "supportedCC": "3c 3d 3e 72 86", "nodeFlags": [], "CurrentSensorStatus": "UNKNOWN", "DeviceName": "", "CurrentElectricityFlow": "0.00",
"CurrentElectricityQuantity": "0.00"},
"dev_2.5": {"uuid": "29702fb4-159e-4e16-8a27-e85a0240f94b", "name": "HAE_METER_v2_5", "internalAddress": "2.5", "type": "HAE_METER_v2_5", "supportsCrc": "0",
"CurrentElectricityQuantity": "8881204.00"},
"dev_2.6": {"uuid": "50724e13-156e-42e1-bfad-5cb9317f2317", "name": "HAE_METER_v2_6", "internalAddress": "2.6", "type": "HAE_METER_v2_6", "supportsCrc": "0",
"CurrentElectricityQuantity": "0.00"}}
I think dev_2.3 and dev_2.5 are my current electricity meter values, so I think I have to do some extra dev_xx tweaking in Madpatrick's script :)
OedzesG
Post by OedzesG »
i think youre right.. 2_3 is low cost and 2_5 looks like high cost..
if youre using googe chrome you can install JSONview.
output is like this:
dev_settings_device: {
uuid: "4deaa88d-3121-4af6-b8cc-1417058486e4",
internalAddress: "settings_device",
type: "settings_device"
dev_2: {
uuid: "f59f1644-dd40-40b4-91c6-03efc85c931a",
internalAddress: "2",
type: "HAE_METER_v3",
supportsCrc: "1",
ccList: "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
supportedCC: "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
nodeFlags: [ ],
IsConnected: "0",
HealthValue: "1",
DeviceName: "P1",
CurrentSensorStatus: "UNKNOWN"
dev_2.1: {
uuid: "0a854722-adf3-4eef-8c15-5d40e7286859",
internalAddress: "2.1",
type: "HAE_METER_v3_1",
supportsCrc: "0",
ccList: "5e 59 85 8e 3c 3d 3e",
supportedCC: "5e 59 85 8e 3c 3d 3e",
nodeFlags: [ ],
CurrentSensorStatus: "OPERATIONAL",
CurrentGasFlow: "60.00",
CurrentGasQuantity: "4761692.00",
DeviceName: "HAE_METER_v3_1"
dev_2.2: {
uuid: "7220d93d-5fc4-4a96-a475-f43bf5ed4361",
internalAddress: "2.2",
type: "HAE_METER_v3_2",
supportsCrc: "0",
nodeFlags: [ ],
CurrentSensorStatus: "UNKNOWN",
DeviceName: "HAE_METER_v3_2",
CurrentElectricityFlow: "NaN",
CurrentElectricityQuantity: "NaN"
dev_2.3: {
uuid: "00fa5693-5d13-47b4-9830-849d3048af05",
internalAddress: "2.3",
type: "HAE_METER_v3_3",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_3",
dev_2.4: {
uuid: "f5cedc5f-465b-42fe-9bd2-3428a3543fc3",
internalAddress: "2.4",
type: "HAE_METER_v3_4",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_4",
CurrentElectricityFlow: "455.00",
CurrentElectricityQuantity: "1456849.00"
dev_2.5: {
uuid: "bb418508-33cd-4e52-ab01-ce4c3783873c",
internalAddress: "2.5",
type: "HAE_METER_v3_5",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_5",
CurrentElectricityFlow: "0.00",
CurrentElectricityQuantity: "0.00"
dev_2.6: {
uuid: "14b74689-8cce-43fd-9cef-58cc176abaf6",
internalAddress: "2.6",
type: "HAE_METER_v3_6",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_6",
CurrentElectricityQuantity: "1118510.00"
dev_2.7: {
uuid: "f35da869-8344-45c0-9f1a-e60c3907c2fd",
internalAddress: "2.7",
type: "HAE_METER_v3_7",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_7",
dev_2.8: {
uuid: "f5bddf0e-1c0d-41f6-8dfc-0e89bfcc72d4",
internalAddress: "2.8",
type: "HAE_METER_v3_8",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_8",
CurrentHeatQuantity: "NaN"
George
Domoticz version: V4.10717
Post by George »
After trying the Dzvent script as explained in: https://ehoco.nl/geroote-toon-bedienen-met-domoticz/, Domoticz is verry slow and/or hangs.
So I tried the scripts from OedzesG.
Don't know what I did wrong but I get no Values.
Here what I did:
Created dummy devices
Changed the level names and level actions in the selector switches (called the level names exactly)
So far so Good :D
Using: Domoticz V4.10717, Raspberry 3B+, Z-wave plus, Wemos
George
Post by George »
Search for Idx:
Then created Lua script (Copy past, just edit IP adres Toon and IDX)
also use this LUA script To update setpoint from Domoticz to TOON:
But finally I can not read/change values.... at least there is no change in domoticz.
What went wrong?
Is the first scrip LUA? (what I did) or is it dzVents?
George
Post by George »
Update:
Created first script (Toon Script) as dzVents.
And las one - as mentioned - as LUA and set trigger as device.
Log file:
This works:
And this not:
No reaction when i change set point for temp.
No temp. reading.
:roll: Take some Beer for now.... maybe that helps :lol:
