I've tried several command and lights which are controlled through the Zigbee2MQTT plugin and I found that the zigbee dimmer is
responding to the dimTo() command, but the Ikea Tradfri E27 bulb and the Tradfri GU10 bulb don't respond to that command. But I can
dim the Ikea lights with the slider.
I also made a blockly to switch on the Voordeur - Lamp to 80% and that works like a charm.
Below are the logs with loglevel enabled for Zigbee2MQTT plugin.
Domoticz log for the Ikea Tradfri Bulb through Zigbee2MQTT with Blocky (set level to 80%):
- Spoiler: show
2020-01-05 14:01:48.073 EventSystem: Event triggered: Test_1
2020-01-05 14:01:48.132 (Zigbee2MQTT) onCommand: Set Level, level (80) Color:
2020-01-05 14:01:48.134 (Zigbee2MQTT) MqttClient::publish zigbee2mqtt/0xec1bbdfffea8ae64/set ({"brightness": 204, "state": "ON"})
2020-01-05 14:01:48.345 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0xec1bbdfffea8ae64 {'brightness': 204, 'state': 'ON'}
Domoticz log for the Ikea Tradfri Bulb through Zigbee2MQTT with the dimTo(100) command:
- Spoiler: show
2020-01-05 13:39:59.485 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0x00158d000290465b {'voltage': 3115, 'linkquality': 47, 'click': 'single', 'battery': 100}
2020-01-05 13:40:00.543 (Zigbee2MQTT) onCommand: Off, level (0) Color:
2020-01-05 13:40:00.556 (Zigbee2MQTT) MqttClient::publish zigbee2mqtt/0xec1bbdfffea8ae64/set ({"state": "OFF"})
2020-01-05 13:40:00.745 (Zigbee2MQTT) onCommand: Off, level (0) Color:
2020-01-05 13:40:00.750 (Zigbee2MQTT) Command "Off (0)" from device "Voordeur - Bel"
2020-01-05 13:40:00.352 Status: dzVents: Info: Handling events for: "Voordeur - Bel", value: "Click"
2020-01-05 13:40:00.352 Status: dzVents: Info: ------ Start internal script: Deurbel: Device: "Voordeur - Bel (Zigbee2MQTT)", Index: 112
2020-01-05 13:40:00.372 Status: dzVents: Info: ------ Finished Deurbel
2020-01-05 13:40:00.486 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-01-05 13:40:01.113 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0xec1bbdfffea8ae64 {'brightness': 51, 'state': 'OFF'}
Domoticz log for the Ikea Tradfri Bulb through Zigbee2MQTT with the switchOn() command:
- Spoiler: show
2020-01-05 13:48:09.875 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0x00158d000290465b {'voltage': 3115, 'linkquality': 39, 'click': 'single', 'battery': 100}
2020-01-05 13:48:10.691 (Zigbee2MQTT) onCommand: On, level (0) Color:
2020-01-05 13:48:10.694 (Zigbee2MQTT) MqttClient::publish zigbee2mqtt/0xec1bbdfffea8ae64/set ({"state": "ON"})
2020-01-05 13:48:10.695 (Zigbee2MQTT) onCommand: Off, level (0) Color:
2020-01-05 13:48:10.697 (Zigbee2MQTT) Command "Off (0)" from device "Voordeur - Bel"
2020-01-05 13:48:10.632 Status: dzVents: Info: Handling events for: "Voordeur - Bel", value: "Click"
2020-01-05 13:48:10.633 Status: dzVents: Info: ------ Start internal script: Deurbel: Device: "Voordeur - Bel (Zigbee2MQTT)", Index: 112
2020-01-05 13:48:10.643 Status: dzVents: Info: ------ Finished Deurbel
2020-01-05 13:48:10.651 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-01-05 13:48:11.390 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0xec1bbdfffea8ae64 {'brightness': 51, 'state': 'ON'}
Domoticz log for the Robbshop Zigbee dimmer through Zigbee2MQTT:
- Spoiler: show
2020-01-05 13:43:02.964 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0x00158d000290465b {'voltage': 3115, 'linkquality': 42, 'click': 'single', 'battery': 100}
2020-01-05 13:43:03.724 (Zigbee2MQTT) onCommand: Set Level, level (100) Color:
2020-01-05 13:43:03.728 (Zigbee2MQTT) MqttClient::publish zigbee2mqtt/0x000d6f0013e899d0/set ({"brightness": 255, "state": "ON"})
2020-01-05 13:43:03.788 (Zigbee2MQTT) onCommand: Off, level (0) Color:
2020-01-05 13:43:03.790 (Zigbee2MQTT) Command "Off (0)" from device "Voordeur - Bel"
2020-01-05 13:43:03.690 Status: dzVents: Info: Handling events for: "Voordeur - Bel", value: "Click"
2020-01-05 13:43:03.690 Status: dzVents: Info: ------ Start internal script: Deurbel: Device: "Voordeur - Bel (Zigbee2MQTT)", Index: 112
2020-01-05 13:43:03.700 Status: dzVents: Info: ------ Finished Deurbel
2020-01-05 13:43:03.710 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-01-05 13:43:04.071 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0x000d6f0013e899d0 {'brightness': 255, 'linkquality': 49, 'state': 'ON'}
2020-01-05 13:43:04.414 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0x000d6f0013e899d0 {'brightness': 255, 'linkquality': 47, 'state': 'ON'}
2020-01-05 13:43:05.937 (Zigbee2MQTT) MQTT message: zigbee2mqtt/0x000d6f0013e899d0 {'brightness': 255, 'linkquality': 47, 'state': 'ON'}
