When I import weather data from any Wunderground weather station, Domoticz shows wind speeds that are 3,6 times the value that is indicated on the according weather station in Wunderground. I suppose a conversion error is present in Domoticz ( 1m/s = 3,6km/h). Can this be solved by one of the brains behind Domoticz ?
Greetings,
Luc
scale error windspeeds Wunderground
- Domoticz version: 4.10717
Re: scale error windspeeds Wunderground
I found the answer myself, make a new variable and convert the values trough a lua script.
It looks mine are correct. You set the units in Setup/Settings/Meters/Counters
Hi Luc,
Found the same problem over here. Can you share your Lua script ?
Thx
Thx
Raspberry PI, RFX 433E, Omnik Solar, Vair Co2, 1-wire, Qubino, TTN lora, Velux KF200, Kaku, Luftdaten, Meteo
