Hi everyone,
I am struggling with the lastUpdate object of dzVents. I often use it in combination with the minutesAgo() function in my scripts, but now I want to use the time itself, rather than the comparison to the current time, which I want to show in the log (I want to show the time that my door sensor was triggered in the log, but the script itself is not triggered by the door sensor so I can't use the current time of the system as a proxy).
When I want to ouput dz.device("door").lastUpdate to the log, it gives me an error. Can anyone help me with the correct method to show the time a device was last triggered in the log?
Many thanks and happy holidays
lastUpdate object [Solved]
- waaren
Re: lastUpdate object [Solved]
lastUpdate is a domoticz / dzVents timeobject.TimTimTim wrote: Thursday 26 December 2019 16:52 I am struggling with the lastUpdate object of dzVents.
Hope below script will help you understand the the difference between a time and a time object.
devices = {
'lastUpdateTrigger' -- change to a name used on your system or any other trigger
execute = function(dz)
door = dz.devices('door')
lastUpdated = door.lastUpdate -- This is a dz.time object
dz.log ('all attributes of the lastUpdated time object below --------------------' )
dz.utils.dumpTable(lastUpdated)
dz.log('Last update date / time of ' .. door.name .. ' was ' .. lastUpdated.rawDate .. ' at ' .. lastUpdated.rawTime , dz.LOG_INFO)
}Debian buster, bullseye on RPI-4, Intel NUC.
Thanks for your answer, definately helps! Finally made it work
