I have a dzventz-script with the command "domoticz.devices('xxx').switchOff().afterMin(180)".
I want to know how many minutes have been passed after the device is called for switchOff.
Can anyone help me with a piece of script?
Paul
passed time after switchOff().afterMin(180)
- waaren
Re: passed time after switchOff().afterMin(180)
Where do you want to show this countdown value ? In the log, a variable or in another device ?
If you can share the script as it is now I might be able to help
Waaren,
see code below.
The first intention was to show it in the log-file, but may be a 'variable' or in 'another device' opens some new possibilities.
thanks
Paul
see code below.
thanks
Paul
active = true, -- set to false to disable this script
devices = {
110, --ADC1 schakelaar afzuiginstallatie
5560, -- Motion MotionBadk
5549, --Motion-wc-hal
5555, --Motion-wc-etage
5449 --Dummy afzuiginstallatie
local Afzuiging = domoticz.devices('Afzuiginstallatie - ADC1')
MotionBadk = domoticz.devices('Motion-badkamer')
MotionWcHal = domoticz.devices('Motion-wc-hal')
MotionWcEtage = domoticz.devices('Motion-wc-etage')
DummyAfzuig = domoticz.devices('Dummy afzuiginstallatie')
--currentTime = domoticz.time.raw -- format 2017-12-31 22:19:15'
currentTime = domoticz.time.rawTime -- format 00:00:00
currentHours = domoticz.time.hour
currentMinutes = domoticz.time.minutes
PRINT_MODE = false --true
if PRINT_MODE == true then
print ('============================================================================================ ')
print('======currentTime==== ' ..currentTime)
print('======current Hours=== ' ..currentHours)
print('======current minutes=== ' ..currentMinutes)
if (MotionWcHal.state) == 'On' then
print ('===========Motion-wc-hal is on =========== ')
print ('===========Motion-wc-hal is off =========== ')
if (MotionBadk.state) == 'On' then
print ('===========MotionBadk is on =========== ')
print ('===========MotionBadk is off =========== ')
if (MotionWcEtage.state) == 'On' then
print ('===========Motion-wc-etage is on =========== ')
print ('===========Motion-wc-etage is off =========== ')
if (Afzuiging.state) == 'Off' then
print ('===========afzuiginstallatie uit =========== ')
print ('===========afzuiginstallatie aan =========== ')
if (DummyAfzuig.state) == 'Off' then
print ('===========DummyAfzuig is off =========== ')
print ('===========DummyAfzuig is on =========== ')
--if (DummyAfzuig.state) == 'On' then
-- print ('===========DummyAfzuig 2 is on =========== ')
-- return
--end
--print ('===========afzuigscript loopt door =========== ')
if
(MotionWcHal.state == 'On') and (DummyAfzuig.state == 'Off') then
domoticz.devices('Afzuiginstallatie - ADC1').switchOn().checkFirst().repeatAfterSec(10,2)
domoticz.devices('Afzuiginstallatie - ADC1').switchOff().checkFirst().afterMin(15).repeatAfterSec(10,2)
print ('===========return motion wc-hal===== ')
return
if (MotionWcEtage.state == 'On') and (DummyAfzuig.state == 'Off') then --and (currentTime >= "13:14:00") and (currentTime < "13:22:00") then
--domoticz.devices('SchakelaarSL2- zolderstelling').switchOn() --.repeatAfterSec(3,2)Afzuiging.switchOn()
print ('===========return motion wc-etage==== ')
return
if (MotionBadk.state == 'On') and (DummyAfzuig.state == 'Off') and (currentTime >= "21:45:00") and (currentTime < "23:00:00") then
--domoticz.devices('Dummy afzuiginstallatie').switchOn().repeatAfterSec(10,2)
--domoticz.devices('Dummy afzuiginstallatie').switchOff().afterMin(120)repeatAfterSec(10,2)
print ('===========return motion badk obv tijdslot===== ')
return
if (MotionBadk.state == 'On') and (DummyAfzuig.state == 'Off') then
domoticz.devices('Afzuiginstallatie - ADC1').switchOn().repeatAfterSec(10,2)
domoticz.devices('Afzuiginstallatie - ADC1').switchOff().afterMin(180).repeatAfterSec(10,2)
domoticz.devices('Dummy afzuiginstallatie').switchOff().afterMin(179)repeatAfterSec(10,2)
print ('===========return motion badk===== ')
return
- waaren
Script could look like
return
on =
devices =
timer =
'every minute'
logging =
level = domoticz.LOG_DEBUG
data = { countdown = { initial = {} }},
execute = function(dz, item)
_G.logMarker = _G.moduleLabel
local Afzuiging = dz.devices('Afzuiginstallatie - ADC1')
local MotionBadk = dz.devices('Motion-badkamer')
local MotionWcHal = dz.devices('Motion-wc-hal')
local MotionWcEtage = dz.devices('Motion-wc-etage')
local DummyAfzuig = dz.devices('Dummy afzuiginstallatie')
local Zolder = dz.devices('SchakelaarSL2- zolderstelling')
local countdownVar = dz.variables('countdown') -- define this variable as type string
local function managedSwitchOff(device, delay, repeatDelay, repeatTimes)
delay = delay or 0
device.cancelQueuedCommands() -- remove previous scheduled commands for this device
if delay > 0 then dz.data.countdown[device.name] = delay end
repeatDelay = repeatDelay or 10
repeatTimes = repeatTimes or 2
device.switchOff().afterMin(delay).repeatAfterSec(repeatDelay, repeatTimes)
local function managedSwitchOn(device, delay, repeatDelay, repeatTimes)
delay = delay or 0
device.switchOn().checkFirst().afterMin(delay).repeatAfterSec(repeatDelay, repeatTimes)
if item.isTimer then
local countdownString, countdownLogString = ''
for name, countdown in pairs(dz.data.countdown) do
if countdown > 0 then
dz.data.countdown[name] = countdown - 1
countdownLogString = 'Remaining on time for ' .. name .. ': ' .. countdown .. ' minutes.'
dz.log('Remaining on time for ' .. name .. ': ' .. countdown .. ' minutes.', dz.LOG_DEBUG)
countdownString = countdownString .. countdownLogString .. '\n'
if countdownVar.value ~= countdownString then countdownVar.set(countdownString) end
dz.log ('============================================================================================ ',dz.LOG_DEBUG)
dz.log('======currentTime==== ' .. dz.time.raw,dz.LOG_DEBUG)
dz.log('======current Hours=== ' .. dz.time.hour,dz.LOG_DEBUG)
dz.log('======current minutes=== ' ..dz.time,minutes,dz.LOG_DEBUG)
dz.log('===========MotionWcHal is ' .. MotionWcHal.state ..' =========== ',dz.LOG_DEBUG)
dz.log('===========MotionBadk is ' .. MotionBadk.state ..' =========== ',dz.LOG_DEBUG)
dz.log('===========MotionWcEtage is ' .. MotionWcEtage.state ..' =========== ',dz.LOG_DEBUG)
dz.log('===========Afzuiging is ' .. Afzuiging.state ..' =========== ',dz.LOG_DEBUG)
dz.log('===========DummyAfzuig is ' .. DummyAfzuig.state ..' =========== ',dz.LOG_DEBUG)
--dz.log ('===========afzuigscript loopt door =========== ',dz.LOG_DEBUG)
if MotionWcHal.state == 'On' and DummyAfzuig.state == 'Off' then
managedSwitchOn(Afzuiging)
managedSwitchOff(Afzuiging, 15)
dz.log ('===========return motion wc-hal===== ' ,dz.LOG_DEBUG)
elseif MotionWcEtage.state == 'On' and DummyAfzuig.state == 'Off' then --and (currentTime >= "13:14:00") and (currentTime < "13:22:00") then
-- zolder.switchOn() --.repeatAfterSec(3,2)Afzuiging.switchOn()
dz.log ('===========return motion wc-etage==== ',dz.LOG_DEBUG)
elseif MotionBadk.state == 'On' and DummyAfzuig.state == 'Off' and dz.time.matchesRule('at 22:45-23:00') then
-- managedSwitchOn(DummyAfzuig)
-- managedSwitchOff(DummyAfzuig, 120)
dz.log ('===========return motion badk obv tijdslot===== ',dz.LOG_DEBUG)
elseif MotionBadk.state == 'On' and DummyAfzuig.state == 'Off' then
managedSwitchOff(Afzuiging, 180)
managedSwitchOff(DummyAfzuig, 179)
dz.log ('===========return motion badk===== ',dz.LOG_DEBUG)
Waaren,
Quite some additions and changes. I never could create this myself!
Thanks, in the next comming days i will try your script and let you know.
Thanks again.
Paul
Thanks again.
Paul
Hi Waaren,
regret to say, but the script does not work:
a motion:
does not switch on the device "afzuiging"
in de debug logfile the result of the lines "the dz.time.raw and hour" .
Also a manual switch(On) of the "DummyAfzuig"-switch does not result in debug-output.
I also replaced the managedSwitch(on) with the orginal command
"domoticz.devices('Afzuiginstallatie - ADC1').switchOn().checkFirst().repeatAfterSec(10,2)", but no Switch(On) of "Afzuiging" anymore.
I cannot find the operation of command managedSwitch(On) and (Off) c.q. the difference with Switch(On) or (Off). I looked for it in Domoticz-wiki.
Hope you can help once more?
regards
Paul
a motion:
regards
Paul
- waaren
These are local functions. Constructed for use in this script and not available for other scripts.
Sure, did you define the domoticz uservariable countdown as string ?Hope you can help once more?
Can you please share the log ? Via DM is OK
