Updating devices of a scene Topic is solved
Hesitated
Domoticz version: V4.11665
Post by Hesitated »
In my living room I have a table with up to 5 (not yet installed all) Hue lights above it.
Now I have made a group and I can turn the group on or off, but I would like to update the colour and brightness for all the devices belonging to that scene.
The Domoticz interface doesn't have that option :?: and the API-documentation is lacking this too, although the parameter updatescenedevice is mentioned.
With the API-call:
/json.htm?type=command&param=getscenedevices&idx=2&isscene=true
you'll get a list with all the devices of a certain device.
"result" : [
"Color" : "{\"b\":255,\"cw\":0,\"g\":255,\"m\":3,\"r\":255,\"t\":0,\"ww\":0}",
"Command" : "On",
"DevID" : "374",
"DevRealIdx" : "374",
"ID" : "5",
"Level" : 24,
"Name" : "Lamp eettafel 2",
"OffDelay" : 0,
"OnDelay" : 0,
"Order" : 5,
"SubType" : "RGBWW",
"Type" : "Color Switch"
"Command" : "On",
"DevID" : "375",
"DevRealIdx" : "375",
"ID" : "6",
"Level" : 24,
"Name" : "Lamp eettafel 4",
"OffDelay" : 0,
"OnDelay" : 0,
"Order" : 6,
"status" : "OK",
"title" : "GetSceneDevices"
To set an individual device you can use the API-call:
/json.htm?type=command&param=setcolbrightnessvalue&idx=130&color={"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}&brightness=100
Does this mean that:
/json.htm?type=command&param=updatescenedevice&idx=XYZ&color={"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}&brightness=100
is the correct API-call to set the color and brightness for a device in a scene?
But which idx should i use? The DevID's or the ID's of the scenedevices?
Domoticz 2020.2 - RPi3B+ - RFXtrx433XL - P1 - CC2531 - Somfy - Xiaomi - Hue - Omron - MQTT
Re: Updating devices of a scene
Hesitated wrote: Monday 30 December 2019 14:50
No. just use the setcolbrightnessvalue JSON
The device ID as seen on the devices tab
Hesitated wrote: Monday 30 December 2019 14:50 In my living room I have a table with up to 5 (not yet installed all) Hue lights above it.
Can you try this ?
Send these to update existing domoticz uservariable type string. First to set color / brightness of all lights in a group
Send these to update existing domoticz uservariable type string. 2nd to switchOff all devices in a group
Send these to update existing domoticz uservariable type string. 3rd to switchOn all devices in a group
<domoticz ip:domoticz port>/json.htm?type=command&param=updateuservariable&vname=setGroupLights&vtype=2&vvalue=groupName;{"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0};31'
<domoticz ip:domoticz port>/json.htm?type=command&param=updateuservariable&vname=setGroupLights&vtype=2&vvalue=groupName;Off
<domoticz ip:domoticz port>/json.htm?type=command&param=updateuservariable&vname=setGroupLights&vtype=2&vvalue=groupName;On
dz.utils.stringSplit require dzVents >= 2.4.19 (domoticz V4.10728)
dz.utils.dumpTable require dzVents >= 2.4.17 (domoticz V4.10602)
dz.utils.groupExists require dzVents >= 2.4.28 (domoticz V4.11079)
see https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's#Set_a_light_to_a_certain_color_or_color_temperature
return
    on =
        variables =
            'setGroupLights',              -- change to your variable name
       logging =
        level = domoticz.LOG_DEBUG -- set to LOG_ERROR when all working as expected
    execute = function(dz, item)
        _G.logMarker =  _G.moduleLabel
        local function setColor(id, color, brightness)
            local url = dz.settings['Domoticz url'] ..
                        '/json.htm?type=command&param=setcolbrightnessvalue' ..
                        '&idx=' .. id   ..
                        '&brightness=' .. brightness ..
                        '&color=' .. color
            return dz.openURL(url)
        -- @parm group      [required]; domoticz.group object
        -- @parm action     [optional]; domoticz color object, 'On' or 'Off' ; default = 'Off'
        -- @parm brightness [optional]; brightness (0-100)  ; default 100
        local function setDevices(group, action , brightness)
            local action = action or 'Off'
            local brightness = brightness or 100
            group.devices().forEach(function(dv)
                if action == 'Off' then dv.switchOff()
                elseif action == 'On' then dv.switchOn()
                else setColor(dv.id, action, brightness)
            end)
        -- Main
        local parms = dz.utils.stringSplit(item.value, ';') -- 1: groupName or groupID, 2: On, Off or colorJSON, 3: brightness or empty
        if _G.logLevel == dz.LOG_DEBUG then dz.utils.dumpTable(parms) end -- Only on debug
		if dz.utils.groupExists(parms[1])) then
			object = dz.groups(parms[1])
			object = dz.scenes(parms[1])
        setDevices(object,parms[2],parms[3])
Hesitated
Post by Hesitated »
waaren wrote: Sunday 05 January 2020 10:40 Can you try this ?
It worked. :D
Although I had to change it a bit as I'm still on version V4.10717, instead of dz.utils.stringSplit, I had to use:
        local parms = {}
        local index1 = string.find(item.value, ';', 1, true) - 1
        parms[1] = string.sub(item.value, 1,index1)
        dz.log('parms[1] = ' .. parms[1], dz.LOG_INFO)
        index1 = index1 + 2
        local index2 = string.find(item.value, ';', index1, true) - 1
        parms[2] = string.sub(item.value, index1, index2)
        dz.log('parms[2] = ' .. parms[2], dz.LOG_INFO)
        index2 = index2 + 2
        local index3 = string.len(item.value)
        parms[3] = string.sub(item.value, index2, index3)
        dz.log('parms[3] = ' .. parms[3], dz.LOG_INFO)
But that is just a matter of coding and maintainability... ;)
Thanxs again!
Hesitated wrote: Sunday 05 January 2020 18:31 It worked. :D
Nice
If you look in dzVents/runtime/Utils.lua of a recent Beta and search for stringSplit you will find the function self.stringSplit
You can copy that function and merge it into the script as
function stringSplit(text, sep)
	if not(text) then return {} end
	local sep = sep or '%s'
	local t = {}
	for str in string.gmatch(text, "([^"..sep.."]+)") do
		table.insert(t, str)
	return t
Same approach could be used for groupExists and dumpTable. No magic involved here.. Just plain Lua.
Hesitated
Post by Hesitated »
waaren wrote: Sunday 05 January 2020 19:09 If you look in dzVents/runtime/Utils.lua of a recent Beta and search for stringSplit you will find the function self.stringSplit
At first it did not work.... Until I saw that ds.utils.stringSplit was not correct... :o
waaren wrote: Sunday 05 January 2020 19:09 Same approach could be used for groupExists and dumpTable. No magic involved here.. Just plain Lua.
Now first back to work, maybe I'll look into this later...
Thnxs again!
