Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
- Domoticz version: 4.10717
So nothing helped, Controlicz is not working for me. I deleted the Account, I changed the Domoticz User, I only made one switch visible, its in a floorplan, it is not working at all. Controlicz has access, thats working, I see it in the log, but I do not see a log which tries to switch anything. It simply does not work for me. Rediscovered all devices, Deleted all devices, nothing helped, thats sad, but its not working...I deactive the skill.
Was it a Room Plan, or a floor plan?
- Domoticz version: V2020.2
Using it for a month now, very happy! I use it in combination with Hue and Ikea. It's very stable and flexible. Keep up the work, and take my money!
Thank you, it's great to get feedback. Any question or issues, i usually monitor in here, or you can drop us a note from your Controlicz profile
@ magdeni It is in a Roomplan, sorry not Floorplan. It is detected by Alex in the Devices area. So far so good. If I have a look at https://.....duchdns.og:Port xyz I enter my PW and I see the switch in a room. and I can switch it. However, it is not working through Alexa. BTW the same thing happenes with my HA Bridge, I can switch through HA everything works, Alexa finds my HA birdge devices (on Port 80 now) but does not switch.
Meanwhile I think Alexa is the problem, although Yeelight and Hue works...
I was wondering the same, as I have the same issue.
If I say turm the Office lights off all 3 lights go off but the response from Google is that it couldn't connect to 2 of them.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Still ongoing with Google
Working with Google on resolving this, however the workaround is if you remove all but one device from a room (There's no easy way of doing this in Home app, so remove from your controlicz user, sync your devices, then re-add it and sync again), and leave one device in the room, the error goes away.
The issue is with how the request is being formed by Google for their Rooms - this seems to have changed over the last 6 weeks.
Ok, the issue of non-reporting devices should now be fixed. Apologies - any errors still, drop a message in your profile
- Domoticz version: 3.8153
Awesome work
Can confirm the issue is gone for me
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
Hi!
is there a way to get google to tell me when a switch has been turned on?
does controlicz support that?
- DewGew
- Domoticz version: V4.10618
Just ask GA if your device is on.
not what i meant, i mean if you turn a switch on in another room or if you get a notification in domoticz, then google should say, for example, your washing machine is done.
- Target OS: -
Hi. Trying to get it all connected. But what a struggle.
Finally got my https working. But now when I try to connect controlicz in google home app, it says connected but after a few second I get something went wrong try again message. And controlicz doesn’t appear in connected devices.
I have about 9 floorplans like living,kitchen etc.
So this should work...
From google online I can delete connection with controlicz and in the app it asks me again for credentials and to allow. But just nothing happens. I’m stuck at this point
Please help.
Please help.
Make sure you have the devices in a Room Plan not a floor plan.
I'm sorry you've been struggling to set it up, i note you contacted me about https, I wasn't aware of the other issues
- Target OS: -
Hi. Yes I have several roomplans.
So why it’s not recognized by google home?
could this be something with ssl certificate?
i am a noob with pi etc..
i folowed the from controllicz fag to domoticz wiki.(how to create ssl)
but i just dont understand what i read and what to do...?
is there a simple how to or a user guide to fix this?
i thougt that controlicz was just a plug and play out of the box.. but this requiers some more tech than plug and play users..
Greets Marco.
Greets Marco.
I've just sent you an email - you've configured everything correctly, just check the device names don't contain special characters, Google will reject them (and the rest of the payload)
- Target OS: -
just tried a few minutes ago.. nothing..It looks ok, can you try linking your Controlicz account again in the Home app?
i have a video of it what happens but cant upload i think only pictures?
Check you have any devices with special characters in them, change them (details in the email), and then reconnect your account in the Home app
