Sharing : Afval kalendar in text sensor
- jvdz
- Domoticz version: 4.107
Re: Sharing : Afval kalendar in text sensor
I have updated the github version to fix the error checking for the returning of an empty string by the curl execution so the description of the issue is better reflected in the domoticz log.
Jos
Jos
Derik
- Domoticz version: BETA
Did replace the last beta.. I check if this is works
- jvdz
Doubt that will help. Did you try running the posted command from a terminal.session?
Jos
Jos
Derik
Jos, hope this is oke.....jvdz wrote: Wednesday 18 December 2019 20:54 Pretty sure it can't find/run curl.exe which causes this error.
Try running curl from a putty session to see if that really works:JosCode: Select all
pi@PI2BT ~/domoticz/scripts/lua $ curl "https://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=fout" NOK pi@PI2BT ~/domoticz/scripts/lua $
pi@cubieboard2:~$ curl "https://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=fout"
NOK
pi@cubieboard2:~$ NOK
edit:
Other strange part in a other system..
And i did update the code:
-- MijnAfvalWijzer huisvuil script: script_time_afvalwijzer.lua
ver="20191218-2100"
-- curl in os required!!
-- create dummy text device from dummy hardware with the name defined for: myAfvalDevice
-- Check the timing when to get a notification for each Afvaltype in the afvaltype_cfg table
-- Check forumtopic: https://www.domoticz.com/forum/viewtopic.php?f=61&t=17963
-- Check source updates: https://github.com/jvanderzande/mijnafvalwijzer
-- Link to WebSite: http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=6137LP&street=&huisnummer=15&toevoeging
myAfvalDevice = 'D.M.: Afval' -- The Text devicename in Domoticz
ShowNextEvents = 3 -- indicate the next x events to show in the TEXT Sensor in Domoticz
Postcode = '6668AW' -- Your postalcode
Huisnummer = '9' -- Your housnr
NotificationEmailAdress = "[email protected]" -- Specify your Email Address for the notifications. Leave empty to skip email notification
--NotificationEmailAdress = {"",""} -- Specify multiple Email Addresses for the notifications. Leave empty to skip email notification
Notificationsystem = "" -- Specify notification system eg "telegram/pushover/gcm/http/kodi/lms/nma/prowl/pushalot/pushbullet/pushsafer" leave empty to skip
-- Switch on Debugging in case of issues => set to true/false=======
debug = false
-- ### define format for text device
-- date options:
-- wd = weekday in 3 characters eg Zon;Maa;Din
-- dd = day in 2 digits eg 31
-- mm = month in 2 digits eg 01
-- mmm = month abbreviation in 3 characters eg : jan
-- yy = year in 2 digits eg 19
-- yyyy = year in 4 digits eg 2019
-- Afvaltype description options
-- sdesc = short afvaltype description from Website eg pmd
-- ldesc = Long afvaltype description from Website eg Plastic, Metalen en Drankkartons
textformat = "dd mmm sdesc"
-- ### define a line for each afvaltype_cfg retuned by the webrequest:
-- hour & min ==> the time the check needs to be performed and notification send when daysbefore is true
-- daysbefore ==> 0 means that the notification is send on the day of the planned garbage collection
-- daysbefore ==> X means that the notification is send X day(s) before the day of the planned garbage collection
-- reminder ==> Will send a second reminder after x hours. 0=no reminder (needs to be in the same day!)
-- text ==> define the text for the notification.
afvaltype_cfg = {
["restafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Grijze Container met Restafval"},
["gft"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Groene Container met Tuinafval"},
["pmd"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Oranje Container met Plastic en Metalen"},
["kca"] ={hour=19,min=01,daysbefore=1,reminder=0,text="kca"},
["kerstbomen"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Kerstbomen"},
["takken"] ={hour=19,min=01,daysbefore=1,reminder=0,text="snoeiafval"},
["papier"] ={hour=12,min=05,daysbefore=0,reminder=0,text="Blauwe Container met Oud papier"},
["plastic"] ={hour=19,min=01,daysbefore=1,reminder=0,text="plastic en drankenkartons"},
["grofvuil"] ={hour=19,min=01,daysbefore=1,reminder=0,text="grofvuil/oud ijzer"},
["tuinafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="tuinafval"},
-- Add any missing records above this line
["dummy1"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update for testing"},
["dummy2"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update of text sensor at night"}}
-- Define the Notification Title and body text. there are 3 variables you can include:
-- @DAG@ = Will be replaced by (vandaag/morgen/over x dagen)
-- @AFVALTYPE@ = Will be replaced by the AfvalType found on the internet
-- @AFVALTEXT@ = Will be replaced by the content of the text field for the specific AfvalType in afvaltype_cfg
-- @AFVALDATE@ = Will be replaced by the pickup date found on the internet
notificationtitle = '@AFW: @DAG@ de @AFVALTEXT@ aan de weg zetten!'
notificationtext = '@DAG@ wordt de @AFVALTEXT@ opgehaald!'
--==== end of config ========================================================================================================================
-- General conversion tables
local nMON={"jan","feb","maa","apr","mei","jun","jul","aug","sep","okt","nov","dec"}
-- debug print
function dprint(text)
if debug then print("@AFW:"..text) end
-- try to load JSON default library
function loaddefaultjson()
if unexpected_condition then error() end
JSON = require "JSON" -- use generic JSON.lua
-- try to load JSON.lua from the domoticz setup
function loaddomoticzjson()
JSON = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- Use default Domoticz JSON.lua
-- Load JSON.lua
if pcall(loaddefaultjson) then
dprint('Loaded default JSON.lua.' )
dprint('Failed loading default JSON.lua... trying /home/pi/domoticz/scripts/lua/JSON.lua' )
if pcall(loaddomoticzjson) then
dprint('Loaded JSON.lua.' )
print('@AFW Error: failed loading default JSON.lua and /home/pi/domoticz/scripts/lua/JSON.lua.')
print('@AFW Error: Please check your setup and try again.' )
return
-- round function
function Round(num, idp)
return tonumber(string.format("%." ..(idp or 0).. "f", num))
-- run program and return captured output
function os.capture(cmd, rep) -- execute command to get site
-- rep is nr of repeats if result is empty
local r = rep or 1
local s = ""
while ( s == "" and r > 0) do
r = r-1
local f = assert(io.popen(cmd, 'r'))
s = assert(f:read('*a'))
f:close()
if ( rep - r > 1 ) then
print("os.capture needed more than 1 call: " .. rep-r)
return s
-- get days between today and provided date
function getdaysdiff(i_afvaltype_date, stextformat)
local curTime = os.time{day=timenow.day,month=timenow.month,year=timenow.year}
-- check if date in variable i_afvaltype_date contains "vandaag" in stead of a valid date -> use today's date
afvalyear,afvalmonth,afvalday=i_afvaltype_date:match("(%d-)-(%d-)-(%d-)$")
if (afvalday == nil or afvalmonth == nil or afvalyear == nil) then
print ('@AFW Error: No valid date found in i_afvaltype_date: ' .. i_afvaltype_date)
return
local afvalTime = os.time{day=afvalday,month=afvalmonth,year=afvalyear}
local daysoftheweek={"Zon","Maa","Din","Woe","Don","Vri","Zat"}
local wday=daysoftheweek[os.date("*t", afvalTime).wday]
stextformat = stextformat:gsub('wd',wday)
stextformat = stextformat:gsub('dd',afvalday)
stextformat = stextformat:gsub('mmm',nMON[tonumber(afvalmonth)])
stextformat = stextformat:gsub('mm',afvalmonth)
stextformat = stextformat:gsub('yyyy',afvalyear)
stextformat = stextformat:gsub('yy',afvalyear:sub(3,4))
dprint("...gerd-> diff:"..Round(os.difftime(afvalTime, curTime)/86400,0).. " afvalyear:"..tostring(afvalyear).." afvalmonth:"..tostring(afvalmonth).." afvalday:"..tostring(afvalday)) --
-- return number of days diff
return stextformat, Round(os.difftime(afvalTime, curTime)/86400,0) -- 1 day = 86400 seconds
function notification(s_afvaltype,s_afvaltype_date,i_daysdifference)
dprint("...Noti-> i_daysdifference:"..tostring(i_daysdifference).." afvaltype_cfg[s_afvaltype].daysbefore:"..tostring(afvaltype_cfg[s_afvaltype].daysbefore).." hour:"..tostring(afvaltype_cfg[s_afvaltype].hour).." min:"..tostring(afvaltype_cfg[s_afvaltype].min))
if afvaltype_cfg[s_afvaltype] ~= nil
and (timenow.hour==afvaltype_cfg[s_afvaltype].hour or timenow.hour==afvaltype_cfg[s_afvaltype].hour+afvaltype_cfg[s_afvaltype].reminder)
and timenow.min==afvaltype_cfg[s_afvaltype].min
and i_daysdifference == afvaltype_cfg[s_afvaltype].daysbefore then
local dag = ""
if afvaltype_cfg[s_afvaltype].daysbefore == 0 then
dag = "vandaag"
elseif afvaltype_cfg[s_afvaltype].daysbefore == 1 then
dag = "morgen"
dag = "over " .. tostring(afvaltype_cfg[s_afvaltype].daysbefore) .. " dagen"
notificationtitle = notificationtitle:gsub('@DAG@',dag)
notificationtitle = notificationtitle:gsub('@AFVALTYPE@',s_afvaltype)
notificationtitle = notificationtitle:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtitle = notificationtitle:gsub('@AFVALDATE@',s_afvaltype_date)
notificationtext = notificationtext:gsub('@DAG@',dag)
notificationtext = notificationtext:gsub('@AFVALTYPE@',s_afvaltype)
notificationtext = notificationtext:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtext = notificationtext:gsub('@AFVALDATE@',s_afvaltype_date)
if type(NotificationEmailAdress) == 'table' then
for x,emailaddress in pairs(NotificationEmailAdress) do
if emailaddress ~= "" then
commandArray[x] = {['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. emailaddress}
dprint ('Notification Email send for ' .. s_afvaltype.. " |"..notificationtitle .. '#' .. notificationtext .. '#' .. emailaddress.."|")
if NotificationEmailAdress ~= "" then
commandArray['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress
dprint ('Notification Email send for ' .. s_afvaltype.. " |"..notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress.."|")
if Notificationsystem ~= "" then
commandArray['SendNotification']=notificationtitle .. '#' .. notificationtext .. '####'..Notificationsystem
dprint ('Notification send for '.. s_afvaltype.. " |"..notificationtitle .. '#' .. notificationtext .. '####'..Notificationsystem)
-- Do the actual update retrieving data from the website and processing it
function Perform_Update()
print('AfvalWijzer module start update (v'..ver..')')
dprint('=== web update ================================')
local sQuery = 'curl "https://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode='..Postcode..'&street=&huisnummer='..Huisnummer..'&toevoeging" 2>nul'
local handle=assert(io.popen(sQuery))
local jresponse = handle:read('*all')
handle:close()
if ( jresponse == "" ) then
print("@AFW Error: Empty result from curl command. Please check whether curl.exe is installed.")
return
if ( jresponse:sub(1,3) == "NOK" ) then
print("@AFW Error: Check your Postcode and Huisnummer as we get an NOK response.")
return
-- strip bulk data from "ophaaldagenNext" till the end, because this is causing some errors for some gemeentes
if ( jresponse:find('ophaaldagenNext') == nil ) then
print("@AFW Error: returned information does not contain the ophaaldagenNext section. stopping process.")
return
jresponse=jresponse:match('(.-),\"ophaaldagenNext\":')
jresponse=jresponse.."}}"
-- Decode JSON table
decoded_response = JSON:decode(jresponse)
rdata = decoded_response["data"]
if type(rdata) ~= "table" then
print("@AFW: Empty data table in JSON data... stopping execution.")
return
-- get the description records into rdesc to retrieve the long description
rdesc = rdata["langs"]
rdesc = rdesc["data"]
-- get the ophaaldagen tabel for the coming scheduled pickups
rdata = rdata["ophaaldagen"]
print("@AFW: Empty data.ophaaldagen table in JSON data... stopping execution.")
return
rdata = rdata["data"]
print("@AFW: Empty data.ophaaldagen.data table in JSON data... stopping execution.")
return
-- get the next number of ShowNextEvents
dprint("- start looping through received data -----------------------------------------------------------")
--~ for i = 1, ShowNextEvents do
local missingrecords=""
local txt=""
local txtcnt = 0
for i = 1, #rdata-1 do
record = rdata[i]
if type(record) == "table" then
wnameType = record["nameType"]
web_afvaltype = record["type"]
web_afvaldate = record["date"]
-- first match for each Type we save the date to capture the first next dates
if afvaltype_cfg[web_afvaltype] == nil then
print ('@AFW Error: Afvalsoort not defined in the "afvaltype_cfg" table for found Afvalsoort : ' .. web_afvaltype.." desc:"..wnameType)
missingrecords = missingrecords .. ' ["' .. web_afvaltype..'"] ={hour=19,min=22,daysbefore=1,reminder=0,text="'..wnameType..'"},\n'
afvaltype_cfg[web_afvaltype] = {hour=0,min=0,daysbefore=0,reminder=0,text="dummy"}
-- check whether the first nextdate for this afvaltype is already found to get only one next date per AfvalType
if afvaltype_cfg[web_afvaltype].nextdate == nil and txtcnt < ShowNextEvents then
-- get the long description from the JSON data
dprint("web_afvaltype:"..tostring(web_afvaltype).." web_afvaldate:"..tostring (web_afvaldate))
local stextformat = textformat
-- Get days diff
stextformat, daysdiffdev = getdaysdiff(web_afvaldate, stextformat)
-- When days is 0 or greater the date is today or in the future. Ignore any date in the past
if daysdiffdev == nil then
dprint ('Invalid date from web for : ' .. web_afvaltype..' date:'..web_afvaldate)
elseif daysdiffdev >= 0 then
-- Set the nextdate for this afvaltype
afvaltype_cfg[web_afvaltype].nextdate = web_afvaldate
-- fill the text with the next defined number of events
if txtcnt < ShowNextEvents then
stextformat = stextformat:gsub('ldesc',rdesc[web_afvaltype:upper().."_L"])
stextformat = stextformat:gsub('sdesc',web_afvaltype)
txt = txt..stextformat.."\r\n"
txtcnt = txtcnt + 1
notification(web_afvaltype,web_afvaldate,daysdiffdev) -- check notification for new found info
dprint("-End --------------------------------------------------------------------------------------------")
if missingrecords ~= "" then
print('#### -- start -- Add these records to local afvaltype_cfg = {')
print(missingrecords)
print('#### -- end ----------------------------')
if (cnt==0) then
print ('@AFW Error: No valid data found in returned webdata. skipping the rest of the logic.')
return
-- always update the domoticz device so one can see it is updating and when it was ran last.
print ('@AFW: Found:'..txt:gsub('\r\n', ' ; '))
if otherdevices_idx == nil or otherdevices_idx[myAfvalDevice] == nil then
print ("@AFW Error: Couldn't get the current data from Domoticz text device "..myAfvalDevice )
commandArray['UpdateDevice'] = otherdevices_idx[myAfvalDevice] .. '|0|' .. txt
if (otherdevices[myAfvalDevice] ~= txt) then
print ('@AFW: Update device from: \n'.. otherdevices[myAfvalDevice] .. '\n replace with:\n' .. txt)
print ('@AFW: No updated text for TxtDevice.')
-- End Functions =========================================================================
-- Start of logic ========================================================================
timenow = os.date("*t")
-- check for notification times and run update only when we are at one of these defined times
dprint('AfvalWijzer module start check')
local needupdate = false
for avtype,get in pairs(afvaltype_cfg) do
dprint("afvaltype_cfg :"..tostring(avtype)..";"..tostring(afvaltype_cfg[avtype].hour)..";"..tostring(afvaltype_cfg[avtype].min))
if (timenow.hour==afvaltype_cfg[avtype].hour
or timenow.hour==afvaltype_cfg[avtype].hour+afvaltype_cfg[avtype].reminder)
and timenow.min==afvaltype_cfg[avtype].min then
needupdate = true
-- Always update when debugging
if debug then needupdate = true end
-- get information from website, update device and send notification when required
if needupdate then
Perform_Update()
dprint("Scheduled time(s) not reached yet, so nothing to do!")
So where do i wrong..
in the other script?
- jvdz
That code looks fine and work when I test it.
Your test proves that curl is at least installed.
Jos
Do you get any errors in the logfile at the time it does the actual updates for the text device?Other strange part in a other system..
Jos
Derik
I cannot see the log in domoticz @ that/this moment....jvdz wrote: Saturday 21 December 2019 20:21 That code looks fine and work when I test it.
Your test proves that curl is at least installed.Do you get any errors in the logfile at the time it does the actual updates for the text device?Other strange part in a other system..
Jos
- jvdz
Just uploaded a fix for script_time_afvalwijzer.lua to github fixing the issue not showing upcoming entries for mijnafvalwijzer:
- Fixed bug not processing the last entry of the current year
- Added logic to process next year data at the end of the year.
- jvdz
Just uploaded a fix for script_time_huisvuil_opzet.lua to github fixing the issue not showing upcoming entries for january because it assumed they were still 2019.
Jos
Jos
JuanUil
- Domoticz version: 4.11083
In the moment I don't get an update for the coming weeks.
Is this because of the year change?
- jvdz
Correct.... Just found your info again and tested and found there is another issue with OPZET. Will post back soon when it's fixed/tested and uploaded to github.JuanUil wrote: Monday 23 December 2019 17:31 In the moment I don't get an update for the coming weeks.
Jos
- jvdz
Just uploaded another fix for script_time_huisvuil_opzet.lua fixing an issue when all next dates are in the new year causing an empty text device.
Jos
Jos
JuanUil
Thanx Jos,
I will implement it today.
Jan
Jan
Derik
I replace my old version with the latest..
Hope this great script is going to work again...
nice days to all
nice days to all
Roedii66
Yes, it is working for me again, Thanks for your effort in this!
Gr Ruud
Gr Ruud
Derik
for me not yet
- Freakandel
It is working briliantly for me, thanks for sharing this code.
One question: how often the script should get new data? I see in my Logs that the script is fetching data many times a hour, can it be set to once a day of even week?
With regards and happy holidays!
PS. I mean that the dummy device is updated with text many times per hour, I don't see the script active in the Domotics logs. Just to make it clear.
- jvdz
Understood as you have an issue retrieving the data from the website with curl for some reason, which requires some debugging/testing from your side.
... but i guess the "other system" you mentioned that suddenly had a empty text devices will work again after the update?
The script will run each minute when implemented as timescript, but It will only retrieve the data at the set times in the Table unless you have debug still set to TRUE, which will make it retrieve the data each minute!Freakandel wrote: Tuesday 24 December 2019 12:22 It is working briliantly for me, thanks for sharing this code.![]()
So normally it will only retrieve the data a couple of times a day unless you have set different times for each AfvalType.
Jos
freijn
- Domoticz version: Stable
Jos, specially with the season holidays the script is very helpfull !!
THanks for the effort in this !
Frank
Frank
- jvdz
You are all welcome and wish you all a merry Christmas and a prosperous & healthy 2020.
Jos
Jos
JuanUil
Hi Jos,
also for you the best wishes for 2020.
I implemented the new code but I get this error:
Any idea?
thnx in advance
Jan
2019-12-26 09:56:00.311 Status: LUA: @AFOpzet:afvaltype_cfg :PMD Zak;8;34
2019-12-26 09:56:00.311 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_huisvuil2.lua: /home/pi/domoticz/scripts/lua/script_time_huisvuil2.lua:242: attempt to perform arithmetic on a nil value (field 'reminder')
thnx in advance
Jan
