Zigbee2MQTT Python plugin
geraldFS
Post by geraldFS »
Hello!
I'm experimenting with Domoticz and ZigBee2MQTT and the corresponding Python plugin.
1) Zigbee2MQTT works and recognizes the devices
2) Local MosquittoBroker runs and receives the data
3) zigbee2MQTT plug does not run, as soon as the hardware is added the Domoticz is no longer accessible or the entire hardware setup is gone.
I import my security and everything works again except for the zigbee-python plugin?
It seems to me that the database is simply being shot :shock:
What can I do?
Gerald
Domoticz Version: 4.10717
dzVents version: 2.4.19
Python version: 3.7.3
Hardware:
OrangePi PC2 with Armbian Buster
32GB MicroSD
CC2531 UBS (ZigBee)
pmalvino
Re: Zigbee2MQTT Python plugin
Post by pmalvino »
Hello. Need some help. I have Xiaomi Honeywell smoke detector that published smoke alarm when density is higher than 1, but the sensor alarm sound doesn’t go on.
 2019-12-25 15:40:47: MQTT publish: topic 'zigbee2mqtt/0x00158d0002f37604', payload '{"smoke":true,"linkquality":13,"battery":100,"voltage":3155,"smoke_density":1}'
The “smoke”:true when “smoke_density”:1, this is a problem that could be solved in Domoticz if the value smoke_density was created as a device. How can I add smoke_density value to Domoticz, is there a way to do that? Thank tou
