"Ghost" events Blockly? Topic is solved
Xavier82
- Domoticz version: 2023.2
I moved my Domoticz setup/installation from Synology to Raspberry Pi 3B. (Both Stable release)
Everything went ok on 1 strange thing....
I hope somebody knows how to fix this because it's driving me crazy.
In the new installation I created 4 new events:
1. Event to show doorcam on my Toon Thermostat
2. Event for my Sonos
3. Event for Toon to update switches in Domoticz
4. Event to set Toon setpoint (temperature)
Event 1 I created with the export function in Domoticz on my Synology and used Import in Domoticz on my Rpi3B.
Event 2,3 and 4 I just copied the LUA code and pasted into the new events on Rpi3B.
Event 2,3 and 4 are just working fine, event 1 is also working but there is something strange.
Event 1 seems to be triggered by a "Ghost" event:
2019-12-12 22:21:31.519 EventSystem: Event triggered: ShowDoorCamToon_1
This Event(name) doesn't exist in my created events.
My created event is called "ShowDoorCamToon" (without the _1).
When disabling the event, there is no issue/no trigger of the event ShowDoorCamToon_1.
I already deleted this event and recreated it manually in blockly, when saving this manually created event the "ghost" event comes up again.
I monitored the logging and I can see that the "ghost" event is triggered every 5 minutes.
Renaming the event from "ShowDoorCamToon" to "ShowDoorCamToon_1" results in the ghost event:
2019-12-12 22:26:32.303 EventSystem: Event triggered: ShowDoorCamToon_1_1
As seen an extra "_1" has been added.
I hope somebody can explain me why this happens and what to do to fix this issue.
Kind Regards,
Xavier
Kind Regards,
Xavier
- waaren
Re: "Ghost" events Blockly?
Can you give below command from the CLI and inspect the file /tmp/events.sql when you have done that ?Xavier82 wrote: Thursday 12 December 2019 22:43 Event 1 seems to be triggered by a "Ghost" event:
Maybe something will show up there.
sudo sqlite3 /home/pi/domoticz/domoticz.db ".out /tmp/events.sql" ".dump eventMaster" ".dump eventRules"
# change path if your domoticz is installed in a none default locationCode: Select all
sudo apt install sqlite3Debian buster, bullseye on RPI-4, Intel NUC.
Xavier82
Hi Waaren,
I did that, but also in this dump I can't find any clues why the Blobky script is triggered
Xavier82
So when dumping domoticz log and collecting the data I see this:
2019-12-13 13:58:08.071 EventSystem: Event triggered: ShowDoorCamToon_1
2019-12-13 13:58:09.224 Status: dzVents: Debug: Event triggers:
2019-12-13 13:58:09.224 Status: dzVents: Debug: - Variable: ShowDoorCamToon
2019-12-13 13:58:38.087 Status: Set UserVariable ShowDoorCamToon = 100
2019-12-13 13:58:38.087 Status: Set UserVariable SendtoToon = 0
So this "EventSystem: Event triggered: ShowDoorCamToon_1" I can't figure out.
Something is triggering the blockly script and this each 5 minutes
Xavier82
mmm, after some more investigation….
When in hardware tab disabling Darksky Waether lookup the ghost trigger for the event is not coming.
So seems a relation between Darksy and the Blockly…..
- waaren
Assuming there are no "left behind" scripts in <domoticz dir>/scripts/ subdirectories.Xavier82 wrote: Saturday 14 December 2019 10:16 mmm, after some more investigation….
If you share the sqldump from one of the previous posts and the devicenames / id's from devices in Darksky 'hardware' we might be able to help.
Xavier82
Hi Waaren,Assuming there are no "left behind" scripts in <domoticz dir>/scripts/ subdirectories.
Nop no other left behind scripts, directory only contains these scripts.
Output of sql dump:
PRAGMA foreign_keys=OFF;
BEGIN TRANSACTION;
CREATE TABLE [EventMaster] ([ID] INTEGER PRIMARY KEY, [Name] VARCHAR(200) NOT NULL, [Interpreter] VARCHAR(10) DEFAULT 'Blockly', [Type] VARCHAR(10) DEFAULT 'All', [XMLStatement] TEXT NOT NULL, [Status] INTEGER DEFAULT 0);
INSERT INTO EventMaster VALUES(1,'Sonos','Lua','Device',replace('json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()\n\nlocal sonos=assert(io.popen(''curl http://192.168.0.30:5005/Sonos/state''))\nlocal status = sonos:read(''*all'')\nsonos:close()\nlocal jsonStatus = json:decode(status)\nlocal sonos = ''Sonos''\n\n--print("Eerste JSON stappen met LUA")\n--print(status)\nprint(jsonStatus)\n\nplaybackState = jsonStatus[''playbackState'']\nartist = jsonStatus[''currentTrack''][''artist'']\ntitle = jsonStatus[''currentTrack''][''title'']\nalbum = jsonStatus[''currentTrack''][''album'']\ntype = jsonStatus[''currentTrack''][''type'']\n--streaminfo = jsonStatus[''currentTrack''][''streamInfo'']\n \ncommandArray = {}\n\nif (playbackState == "STOPPED" or playbackState == "PAUSED_PLAYBACK" or playbackState == "PLAYING") then\n if (playbackState == "PLAYING") then\n if type == "radio" then\n print(''Sonos status: '' ..playbackState.. '' '' ..type.. '' Titel: ''..title)\n else\n if artist ~= nil then\n print(''Sonos status: '' ..playbackState.. '' Artiest: '' ..artist.. '' Titel: ''..title)\n else\n print(''Sonos status: '' ..playbackState.. '' Titel: ''..title)\n end \n end\n if (uservariables["Sonos"] == "PAUSED") then\n commandArray[''Variable:SonosStatus'']=''PLAYING''\n print("Uservar Sonos updated to PLAYING")\n end\n end\n if (playbackState == "STOPPED" or playbackState == "PAUSED_PLAYBACK") then\n print(''Sonos Status: '' ..playbackState)\n if (uservariables["SonosStatus"] == "PLAYING") then\n commandArray[''Variable:SonosStatus'']=''PAUSED''\n print("Uservar Sonos updated to PAUSED")\n end \n end\nelse\n --print("2")\n print(''<font color="red">Sonos: SONOS-HTTP-API is off-line</font>'')\nend \n\nif (playbackState == "STOPPED" or playbackState == "PAUSED_PLAYBACK") then\n switch_status_sonos = otherdevices["Sonos"]\n print(''Sonos Switch Status: '' ..switch_status_sonos)\n if otherdevices["Sonos"] == ''Pause'' then\n print(''Sonos Switch Status is correct, should be PAUSE: '' ..switch_status_sonos)\n else\n print(''Sonos Switch Status not correct, should be PAUSE: '' ..switch_status_sonos)\n commandArray[''UpdateDevice''] = ''16|10|10''\n end\nend \n\nif (playbackState == "PLAYING") then\n switch_status_sonos = otherdevices["Sonos"]\n print(''Sonos Switch Status: '' ..switch_status_sonos)\n if otherdevices["Sonos"] == ''Play'' then\n print(''Sonos Switch Status is correct, should be PLAY: '' ..switch_status_sonos)\n else\n print(''Sonos Switch Status not correct, should be PLAY: '' ..switch_status_sonos)\n commandArray[''UpdateDevice''] = ''16|0|0''\n end\nend \n\n\nreturn commandArray\n','\n',char(10)),0);
INSERT INTO EventMaster VALUES(2,'Toon_setpoint','dzVents','Device',replace('return {\n on = {\n devices = {\n ''Toon Thermostaat''\n }\n },\n execute = function(domoticz, device)\n domoticz.openURL(string.format(''http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s'', domoticz.variables(''UV_ToonIP'').value, device.setPoint*100))\n domoticz.log(''Setting Toon setpoint to ''.. device.setPoint)\n end\n}','\n',char(10)),1);
INSERT INTO EventMaster VALUES(3,'Toon_script','dzVents','Device',replace('\nreturn {\n logging = {\n level = domoticz.LOG_FORCE, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level\n marker = "-=# P1 Toon #=-"\n},\n on = {\n timer = {\n ''every minute''\n }\n },\n execute = function(domoticz)\n local ToonThermostat = domoticz.variables(''UV_ToonThermostat'').value -- Sensor showing current setpoint\n local ToonTemperature = domoticz.variables(''UV_ToonTemperature'').value -- Sensor showing current room temperature\n local ToonScenes = domoticz.variables(''UV_ToonScenes'').value -- Sensor showing current program\n local ToonAutoProgram = domoticz.variables(''UV_ToonAutoProgram'').value -- Sensor showing current auto program status\n local ToonProgramInformation = domoticz.variables(''UV_ToonProgramInformation'').value -- Sensor showing displaying program information status\n local ToonIP = domoticz.variables(''UV_ToonIP'').value\n local DomoticzIP = domoticz.variables(''UV_DomoticzIP'').value\n local ToonBurnerName = domoticz.variables(''UV_ToonBurnerName'').value\n\n-- Handle json\n local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux\n \n local handle = assert(io.popen(string.format(''curl http://%s/happ_thermstat?action=getThermostatInfo'', ToonIP)))\n local ThermostatInfo = handle:read(''*all'')\n handle:close()\n \n local jsonThermostatInfo = json:decode(ThermostatInfo)\n \n if jsonThermostatInfo == nil then\n return\n end\n\n-- Update the current temperature setpoint\n local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100\n local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100\n currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB]\n \n \n-- Update the current auto program\n local currentProgramState = tonumber(jsonThermostatInfo.programState)\n if currentProgramState == 0 then currentProgramState = 10 -- No\n elseif currentProgramState == 1 then currentProgramState = 20 -- Yes\n elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary \n end\n \n-- Update the current scene by state\n local currentActiveState = tonumber(jsonThermostatInfo.activeState)\n if currentActiveState == -1 then currentActiveState = 50 -- Manual\n elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort\n elseif currentActiveState == 1 then currentActiveState = 30 -- Home\n elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep\n elseif currentActiveState == 3 then currentActiveState = 10 -- Away\n end \n \n-- Update the current scene by temperature\n local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100\n if currentActiveTemp == 20.5 then currentActiveState = 40 -- Comfort\n elseif currentActiveTemp == 19.5 then currentActiveState = 30 -- Home\n elseif currentActiveTemp == 17 then currentActiveState = 20 -- Sleep\n elseif currentActiveTemp == 18.5 then currentActiveState = 10 -- Away\n else currentActiveState = 50 -- Manual\n end \n \n\n-- Update the thermostat sensor to current setpoint\n if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then\n domoticz.log(''Updating thermostat sensor to new set point: '' ..currentSetpoint)\n domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()\n end\n \n-- Update the temperature sensor to current room temperature\n if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then \n domoticz.log(''Updating the temperature sensor to new value: '' ..currentTemperature)\n domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)\n end\n \n-- Update the toon scene selector sensor to current program state\n if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed\n domoticz.log(''Updating Toon Scenes selector to: ''..currentActiveState)\n domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()\n end\n \n-- Updates the toon auto program switch \n if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed\n domoticz.log(''Updating Toon Auto Program selector to: ''..currentProgramState)\n domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()\n end\n \n\n \n-- Updates the toon program information text box\n local currentNextTime = jsonThermostatInfo.nextTime\n local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100\n \n if currentNextTime == 0 or currentNextSetPoint == 0 then\n ToonProgramInformationSensorValue = ''Op '' ..currentSetpoint.. ''°''\n else\n ToonProgramInformationSensorValue = ''Om '' ..os.date(''%H:%M'', currentNextTime).. '' op '' ..currentNextSetPoint.. ''°''\n end\n \n if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then\n domoticz.log(''Updating Toon Program Information to: ''..ToonProgramInformationSensorValue)\n domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)\n end\n end\n}\n\n','\n',char(10)),1);
INSERT INTO EventMaster VALUES(4,'ShowDoorCamToon','Blockly','All','<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_if" id="ol*8)E^20*A]`5TG*[Vc" x="2" y="3"><value name="IF0"><block type="logic_operation" id="b18|/#Y}Hh#O|;-^B=I^"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="0#2xR3s8i3G6ne:Mz~9P"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="2QcT|Q5h]rT3us/fWA7R"><field name="Switch">44</field></block></value><value name="B"><block type="logic_states" id=":JG$WZiDRr}kVy(g^4vt"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="b(S1E5){=_!P`-xjd-,8"><field name="OP">EQ</field><value name="A"><block type="uservariablesSZ" id="n9HM1O64=1vQT{4?`ADb"><field name="Variable">11</field></block></value><value name="B"><block type="text" id="@9(zWF*7}p=3Htz^6V^~"><field name="TEXT">0</field></block></value></block></value></block></value><statement name="DO0"><block type="logic_set" id="T,c!!%sa?AO4*^5RNh6T"><value name="A"><block type="uservariablesSZ" id="?,{$S@cob0|KI;/svN-|"><field name="Variable">12</field></block></value><value name="B"><block type="text" id="[vQDULO:(,)vQ_l2Q}#O"><field name="TEXT">200</field></block></value><next><block type="logic_set" id="Dx}}!wY?z-,i5Y,:BVxz"><value name="A"><block type="uservariablesSZ" id="S!LiZ7V7V4(^@QfV7}-("><field name="Variable">11</field></block></value><value name="B"><block type="text" id="2mvPMQNS:rISdo9I,wnj"><field name="TEXT">1</field></block></value><next><block type="logic_setafter" id="!@~4#j-]+/dbZbvX:2[`"><value name="A"><block type="uservariablesSZ" id="?c}GpY=$`6Q#9(Z#wi=]"><field name="Variable">12</field></block></value><value name="B"><block type="text" id="T74{?e#;L[Le_yKZHn}Z"><field name="TEXT">100</field></block></value><value name="C"><block type="math_number" id="0Lvv,g2LpK806+u#dBe?"><field name="NUM">30</field></block></value><next><block type="logic_setafter" id="(5qD@n8^rKEvaq|5d|/t"><value name="A"><block type="uservariablesSZ" id="2v6d3~.y_pCkvh]diSwN"><field name="Variable">11</field></block></value><value name="B"><block type="text" id="V,94g~bhk,SkKCB,no4V"><field name="TEXT">0</field></block></value><value name="C"><block type="math_number" id="Sj]Z[l-t/Ztl`mT788oR"><field name="NUM">30</field></block></value></block></next></block></next></block></next></block></statement></block></xml>',1);
COMMIT;
BEGIN TRANSACTION;
CREATE TABLE [EventRules] ([ID] INTEGER PRIMARY KEY, [EMID] INTEGER, [Conditions] TEXT NOT NULL, [Actions] TEXT NOT NULL, [SequenceNo] INTEGER NOT NULL, FOREIGN KEY (EMID) REFERENCES EventMaster(ID));
INSERT INTO EventRules VALUES(1,4,'(device[44] == "On" and variable[11] == "0")','commandArray[Variable:12]="200",commandArray[Variable:11]="1",commandArray[Variable:12]="100" AFTER 30",commandArray[Variable:11]="0" AFTER 30"',1);
COMMIT;- waaren
The Blockly system adds a _1 to the scriptName in the log when the Blockly gets triggered by a device.Xavier82 wrote: Thursday 12 December 2019 22:43 Event 1 I created with the export function in Domoticz on my Synology and used Import in Domoticz on my Rpi3B.
Xavier82
Is it an option to create Lua instead of Blockly script for this?
May I then get rid of this ghost trigger...
- waaren
Sure. Please let me know if you need helpXavier82 wrote: Sunday 15 December 2019 13:03 Is it an option to create Lua instead of Blockly script for this?
Xavier82
This is the Lua I got so far but I'm not a programmer:
So below the Blocky which I would like to have in lua.
I appriciate any help
if (deviceName=='Deurbel') then
if deviceValue == "On" and (uservariables["SendtoToon"] == "0") then
set uservariables["ShowDoorCamToon"] == "200" ) then
set uservariables["SendtoToon"] == "1" then
set uservariables["ShowDoorCamToon"] == "100" "AFTER 30"
set uservariables["SendtoToon"] == "0" "AFTER 30"
- Naamloos.png (27.89 KiB) Viewed 2066 times
- waaren
See below for the dzVents equivalentXavier82 wrote: Sunday 15 December 2019 13:22 So below the Blockly which I would like to have in Lua. I appreciate any help![]()
return
on =
devices =
'Deurbel',
logging =
level = domoticz.LOG_DEBUG,
marker = 'Deurbel',
execute = function(dz, item)
if item.active then
dz.log('Device ' .. item.name .. ' was pushed', dz.LOG_DEBUG)
local sendToToon = dz.variables('SendtoToon')
local showDoorCamToon = dz.variables('ShowDoorCamToon')
if sendToToon.value == '0' then
showDoorCamToon.set('200')
showDoorCamToon.set('100').afterSec(30)
sendToToon.set('1')
sendToToon.set('0').afterSec(30)
}Debian buster, bullseye on RPI-4, Intel NUC.
Xavier82
Thanks a lot Waaren.
dzVents seems to be working fine.
Now at my work so can't see what happens at home when doorbell rings.
Will check tonight. I activated the dzVents script and I have no "Ghost" trigger anymore.
Xavier82
Sorry for the late feedback.
Everything works like a charm now
