Is it possible to control a z-wave device in a script through OpenZwave node directly without using an assigned device in Domoticz?
See also this post:
https://www.domoticz.com/forum/viewtopi ... 50&t=30492
I can change device parameters in the Domoticz tab but I don't get any associated device (like an on/off switch).
In the OpenZWave control panel I can turn it on/off, is there any way I could use that to make a virtual switch in Domoticz or use in in a script?
Control z-wave device with OpenZWave
- Egregius
- Domoticz version: v2024.7
Re: Control z-wave device with OpenZWave
You can at least with PHP:
103 is the IDX of the node, 1 is the instance. False=Off, True=On.
Use the developer console of your browser to find the exact string that you need to post.
Could be that you first need to do something like this to get authenticated in OZWCP:
3 is the IDX of your z-wave hardware.
$ch=curl_init('http://127.0.0.1:8080/ozwcp/valuepost.html');
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, '103-SWITCH BINARY-user-bool-1-0=false');
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_HTTPHEADER, array('Content-Type: application/x-www-form-urlencoded'));
curl_exec($ch);
file_get_contents('http://127.0.0.1:8080/json.htm?type=openzwavenodes&idx=3',false);
Thank you!
