Python plugin: Slide by Innovation in Motion
Lokonli
Post by Lokonli »
I've created a Python plugin for Slide by Innovation in Motion.
https://github.com/lokonli/slide-domoticz
heggink
Domoticz version: 12451
Re: Python plugin: Slide by Innovation in Motion
Post by heggink »
Great plugin. Installed and works :-). Do get a bunch of error messages which I posed as a bug on Github.
DASHTICZ πŸ™ƒ
P1 meter & solar panel
Lokonli
Post by Lokonli »
heggink wrote: ↑Thursday 12 December 2019 15:27 Great plugin. Installed and works :-). Do get a bunch of error messages which I posed as a bug on Github.
ok, I'll check.
What kind of system are you using?
heggink
Post by heggink »
Raspberry pi 3.
Sent from phone.
DASHTICZ πŸ™ƒ
Lokonli
Post by Lokonli »
ok, thanks.
To be clear:
The plugin is working correctly, you only see some unexpected messages in the Domoticz log?
Do you see any problem with the functionality?
mschut
Domoticz version: V3.5613
Post by mschut »
Thanks! Just needed this. I followed the instructions, however I cant see " Slide" . in the hardware list. What name should I look for (Slide I suppose)?
Lokonli
Post by Lokonli »
mschut wrote: ↑Friday 13 December 2019 14:21 Thanks! Just needed this. I followed the instructions, however I cant see " Slide" . in the hardware list. What name should I look for (Slide I suppose)?
The hardware name is 'Slide by Innovation in Motion'.
Did you restart Domoticz?
Is Python installed? Domoticz reports the Python version in the ''Settings'->about' window.
You might have to set the right access permissions for the folder and for plugin.py
mschut
Post by mschut »
Python Version: None
That explains ;)
Verstuurd vanaf mijn SM-A530F met Tapatalk
mschut
Post by mschut »
Fixed the Python issue, and my Slides are showing! Great!
Would be great if you could integrate the Zones as well. I am using my Slides in one zone, which would be great to control as well.
Lokonli
Post by Lokonli »
mschut wrote: ↑Friday 13 December 2019 22:08 Fixed the Python issue, and my Slides are showing! Great!
Good!
You can create groups in Domoticz.
I could create dummy devices for each slide zone.
Or create the group in Domoticz automatically.
I'll add it to the feature request list.
mschut
Post by mschut »
Thanks, I am trying hard to setup a switch to control my slides. I do have made a Dummy switch, and by Blocky events this switch controls the Slides in the zone.
However, I don't know how to setup this dummy switch to be controlled by my Zwave wall switch,
With a group I cant get it to work either. The slides are controlled by percentages, so a group will only switch to 0 or 100, I cant get it to work to open and close it by a group. And thus, with 1 switch I can only Open or Close my curtains. Still thinking about a way to use 1 button to Open and Close the curtains....
heggink
Post by heggink »
Lokonli wrote:ok, thanks.
To be clear:
So far only the messages in the log. I did run into another issue that I need to investigate: I added all the devices in a group in order to switch them all at once. That crashed Domoticz... Anyways, I'll investigate and get back on that.
Great to have the plugin though!
Sent from phone.
DASHTICZ πŸ™ƒ
mschut
Post by mschut »
I think I experienced that crash too ;)
By now I have a working setup, a bit complicated, but working.
Zwave switch -> Zwave plug -> Event triggered by plug -> Individual slides.
Happy as can be, with my built in wall switch I can control my curtains :D
Lokonli
Post by Lokonli »
mschut wrote: ↑Friday 13 December 2019 23:49 I think I experienced that crash too ;)
There seems to be a bug in Domoticz in handling the disconnect of the https connections.
As a partial patch(?) I've increased the polling rate to once per 40 seconds in the latest version. Hopefully this keeps the connection alive.
In one of the Domoticz commits I see a report of the error in combination with zwave. There might be a relation.
I have 4 slides in one Domoticz group without issues.
packetloss
Domoticz version: 4.11590
Post by packetloss »
Thanks Lokonli, works great!
For others: I had to do
sudo apt install libpython3-dev
and then restart domoticz.
Some day, in Domoticz, an other icon for curtains instead of blinds would be nice.
And using an API key instead of login/password would be nice. Not sure if Slide supports this.
Lokonli
Post by Lokonli »
packetloss wrote: ↑Sunday 22 December 2019 13:37 Thanks Lokonli, works great!
Thanks for the feedback!
I'll add this to the installation instructions.
RogerSch
Post by RogerSch »
Hello packetloss can you explain which problem was solved by installing libpython3-dev? I`m trying to use the Python plugin on my Synology NAS but I can`t get it to work. My Synology NAS doesn`t have this pyhton module installed.
@Lokonli: Would you be so kind to explain why this dev python module is needed and would it be possible to create a python version of Slide which wouldn`t need this dev python module?
Lokonli
Post by Lokonli »
RogerSch wrote: ↑Monday 23 December 2019 23:29
It's not needed for my plugin, but for the Domoticz plugin system in general.
Is python detected by Domoticz? Domoticz reports the python version in Settings->About.
If not: did you install the correct Domoticz version on your Synology?
See http://www.jadahl.com/
Install a version including Python
RogerSch
Post by RogerSch »
Lokonli wrote: ↑Tuesday 24 December 2019 0:07 It's not needed for my plugin, but for the Domoticz plugin system in general.
Yes Domotics recognize Python:
PluginSystem: Started, Python version '3.5.1'.
Which is the version I have activited in the package manager and from Jadahl I have donloaded the Pyhton version.
As soon as I instruct Domoticz to enable new sensors for 5 minutes the following erro message appears in the log file:
PluginList: Parsing '/usr/local/domoticz/var/plugins/slide-domoticz/', 'Error document empty.' at line 0 column 0 in XML ''.
plugin.py file in this folder has all the required rights...
Lokonli
Post by Lokonli »
I have no experience with Synology...
Maybe try the following:
On the hardware configurarion page set the debug info to all.
Then enable the hardware, without allowing new devices.
In the log file filter 'slide'. Do you see any result?
(I assume you filled in your email and password on the slide hardware configuration page)
