Turn off switch after being on x minutes  [Solved]
peatmoss
Post by peatmoss »
I have a hot water recirculating pump that I control with Domoticz. We turn this on 15 minutes before taking a shower of when we want hot water at the faucet. Is there a way to turn off this switch after it has ben on for x minutes? I tried doing this in dzVents without luck. Here is what I have so far, 269 is the "hot water" switch id:
        devices = { 269 }
        if domoticz.devices(269).state == 'On' then
            domoticz.devices('hot water').switchOff().afterMin(30)
            domoticz.log('hot water is on, shutting down in 30 min')
This seems to be unreliable, it only works sometimes. Nothing shows in the logs why it fails. Also there does not seem to be a variable for time device has been on. Like 269.hasBeenOnFor
Best home automation system I have used. The most reliable, flexible and easy to use!
Pete
Re: Turn off switch after being on x minutes
peatmoss wrote: Wednesday 11 December 2019 23:14 Is there a way to turn off this switch after it has ben on for x minutes? I tried doing this in dzVents without luck. Here is what I have so far, 269 is the "hot water" switch id
I see nothing in your script that would prevent the hot water pump (device 269) to get switched off after 30 minutes if domoticz is not restarted in these 30 minutes.
if you use below script and inspect the logfile you should be able to see what happens.
return
    on =
        devices = { 269 },
        timer = {'every 5 minutes' },
    logging = { level = domoticz.LOG_DEBUG }, -- switch to LOG_ERROR when working as expected
    execute = function(dz, item)
        _G.logMarker =  _G.moduleLabel
        local hotWater = dz.devices(269)
        if item.isDevice then
            if item.state == 'On' then
            	item.cancelQueuedCommands()
                item.switchOff().afterMin(30)
                dz.log('hot water is on, shutting down in 30 min',dz.LOG_DEBUG)
                dz.log('hot water switched off',dz.LOG_DEBUG)
            dz.log('hot water state is ' .. hotWater.state .. '. Last update was ' .. hotWater.lastUpdate.secondsAgo .. ' seconds ago.' ,dz.LOG_DEBUG)
peatmoss
Post by peatmoss »
Thanks Waaren! I'll give this a try.
peatmoss
Post by peatmoss »
Its still not shutting off. After a closer look at the logs I think mqtt keeps updating the status and resets the off timer. I may have to fix this by setting a variable to keep track of the on time. Here are the logs:
2019-12-11 21:50:14.289 (MQTTDisco) 012/hot water: Topic: 'hot_water/tele/STATE 'Setting nValue: 1->1, sValue: ''->''
2019-12-11 21:50:14.532 Status: dzVents: Info: Handling events for: "hot water", value: "On"
2019-12-11 21:50:14.532 Status: dzVents: Info: ------ Start internal script: hot-water-off: Device: "hot water (MQTTDisco)", Index: 269
2019-12-11 21:50:14.533 Status: dzVents: Debug: Constructed timed-command: Off
2019-12-11 21:50:14.533 Status: dzVents: Debug: Constructed timed-command: Off AFTER 1800 SECONDS
2019-12-11 21:50:14.533 Status: dzVents: Debug: hot water is on, shutting down in 30 min
2019-12-11 21:50:14.533 Status: dzVents: Info: ------ Finished hot-water-off
2019-12-11 21:50:14.536 Status: EventSystem: Script event triggered: /opt/domoticz/dzVents/runtime/dzVents.lua
peatmoss wrote: Thursday 12 December 2019 6:53 Its still not shutting off. After a closer look at the logs I think mqtt keeps updating the status and resets the off timer. I may have to fix this by setting a variable to keep track of the on time.
I included the time trigger in the script to identify this kind of external influence. If you start logging to an OS file and inspect the log you might be able to see what is setting the hot water device.
Treve
Domoticz version: v4.11474
Post by Treve »
I’m using this simpel blocky to switch off my phone charger, it’s working flawless.
I’m using Domoticz version 4.11474
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Treve wrote: Thursday 12 December 2019 8:20 I’m using this simpel blocky to switch off my phone charger, it’s working flawless.
The issue here is not so much that the switchOff after xxx seconds is not working. The issue is that the switch state is not only controlled by the script that @peatmoss created for it but is switched on by another process, -script or mqtt. The blockly solution you propose will face that same issue.
So next step in finding the root cause is not to use another method to switch it off after some time but to identify what process, -script or mqtt is also changing the state of the hot water switch.
peatmoss
Post by peatmoss »
Yeah I should have mentioned it can be turned on by Alexa via fauxmo, the actual switch or Domoticz web. I'll look at logging to a file to debug.
peatmoss
Re: Turn off switch after being on x minutes  [Solved]
Post by peatmoss »
This seems to work. I used a user variable. Not the most elegant but...
return
    on =
        devices = { 269 },
        if item.isTimer then
                local hotWaterTime = domoticz.variables('hotwatertime').value
                if hotWaterTime > 5 then -- 6*5=30 min
                    domoticz.variables('hotwatertime').set(0)
                    domoticz.variables('hotwatertime').set(hotWaterTime + 1)
