Hello. I have a little problem with adding Soil moisture sensor to Domoticz. Can You help me with it? I'm beginner with domoticz.
In attach I send some photos. I dont have any python scripts ;/
Luu888
- 75521895_1437497333072407_9040815504205283328_n.jpg (353.96 KiB) Viewed 722 times
- 74524877_693048294516481_7173414344389033984_n.jpg (54.99 KiB) Viewed 722 times
Kest
- Domoticz version: 2020.2
Re: Soil moisture sensor
How do you want to use it, Analog or digital? What is exactly the problem you are having?
snellejellep
please note that these sensors corrode really fast, you will need to replace them often. if you use the inductive ones you do not have to. using espeasy on a nodemcu is the easiest way to use them.
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
