Zigbee Map is a Mess (iframe inside Machinon Theme)
josemi
Post by josemi »
I have scheduled a cron job to execute hourly the script that create zigbee map and I save it as html in www folder for being accessed by iframe inside Machinon Theme.
But I do not like the lines between the boxes because they are overwritten and you are not able to see where a box is connected.
Would you know how generate the map in other way more understandable?
m147
Re: Zigbee Map is a Mess (iframe inside Machinon Theme)
Post by m147 »
How did you generate the image?
By "dot" tool?
josemi
Post by josemi »
m147 wrote: Friday 22 November 2019 14:48 Hi,
By "dot" tool?
Look this:
https://github.com/Koenkk/zigbee2mqtt/issues/252
m147
Post by m147 »
josemi wrote: Monday 09 December 2019 0:31
By "dot" tool?
Look this:
My thought was you can generate image from graphviz with this command:
circo -Tsvg input.dot -o output.svg
Then you will get the map like this:
https://imgur.com/cfnMhZ2
josemi
Post by josemi »
It works very fine, thank you a lot.
Bravo!
m147 wrote: Thursday 12 December 2019 14:09
By "dot" tool?
Look this:
