Hi Guys, i have an RFXcom on 433, i want a simple on/off light switch. No dimmer required just on and off that will work with RFXcom. I have just 2 wires in my switch no neutral.
i would like the switch to have the ability to be used as a switch manually and rfxcom to also use it when required
can someone point me in the right direction?
simple on/off light switch on 433
Re: simple on/off light switch on 433
Nexa WMR-252 will do the job if it's OK with a dimmer function as well.
