Two devices triggers + time  [Solved]
besix
Post by besix »
Hello
I have two small scripts they make light in the kitchen in the morning.
PIR1 - motion sensor
Light 1 - dummy switch
      devices = { ['PIR 1'] = {'between 06:30 and 08:00'}}
   execute = function(dz, item)
       if (item.state == 'On') then
	     dz.devices('Light led').switchOn()
	     dz.devices('Radio').switchOn().afterSec(10)
         dz.log ('Radio and LED = ON')
second script
      devices = { ['Light 1'] = {'between 06:30 and 08:00'}}
	     dz.devices('Light led').switchOff()
	     dz.log ('Main light kitchen = ON')
How to combine it into one script?
Re: Two devices triggers + time
besix wrote: Saturday 30 November 2019 22:26 I have two small scripts they make light in the kitchen in the morning.
Like this ? (not tested)
local motion = 'PIR 1'
local light = 'Light 1'
local morning = 'at 06:35-08:00'
return
    on =
        devices =
            [motion] = { morning },
            [light] = { morning },
   execute = function(dz)
        local isMotion = dz.devices(motion).active
        local lightOn = dz.devices(light).active
        local ledLight = dz.devices('Light led')
        if isMotion then
            dz.log ('Motion detected')
            if not(lightOn) then ledLight.switchOn().checkFirst() end
        if lightOn then
            dz.log ('Main light kitchen is On')
            ledLight.switchOff().checkFirst()
besix
Post by besix »
@waaren
This is very ok
Thank you very much. But I have a question thanks to this logic change, can I add a lux light sensor?
besix wrote: Sunday 01 December 2019 12:21 I have a question thanks to this logic change, can I add a lux light sensor?
Sure you can. The questions that need to be answered before implementing are
  • What should it control and when
  • Which controlling device take preference
besix
Post by besix »
@waaren
I added the lux sensor as you can see, it works
but did I do it right?
And how to make lux not controlling Radio?
local lux = 'External lux'
return
    on =
        devices =
        local LUX = dz.devices(lux).lux
        if isMotion and LUX < 20 then
        if lightOn then
I learn thanks to you
besix wrote: Sunday 01 December 2019 20:20 I added the lux sensor as you can see, it works
Is this what you want ?
return
    on =
        devices =
        local isDark = dz.devices(lux).lux < 20
        if isMotion then
            if isDark then
                dz.log ('It is dark')
        if lightOn then
besix
Re: Two devices triggers + time  [Solved]
Post by besix »
@waaren
Yes it is perfect. I have to understand how it works dark, but it's great Thank you
