I have a question:
I have Domoticz installed on my Raspberry Pi. Then I got 7x DS18B20 temperature sensors connected (1 wire). Now all the sensors already connected and I only know the 64-bit serial and the location where the sensor is mounted. However Domoticz I only see an ID number, which does not match the 64-bit serial code of the sensor.
Does anyone know how I can convert this?
Example of a 64-bit serial is: 28-000005f31786
Hopefully someone can help me.
Thank you.
regards,
Michiel
1 WIRE id code or 64bit code
- gizmocuz
Re: 1 WIRE id code or 64bit code
How about adding them one by one to know which sensor is which ?
there is a logic in the numbers somewhere
Toni
I also find this really difficult. Some 1-wire devices show up by HEX code (4 bytes, i.e. 8 characters), and some by a decimal number (2 bytes). For example the temperature sensors show up in decimal. The decimal code is just two of the address bytes in decimal format.
I think it would be much better if Domoticz would show the full 1-wire ID of the devices, but even if the ID's would be in HEX format instead of decimal, it would easy the setup a lot. I did this in my own private fork of Domoticz.
StratosHF
- Domoticz version: 2025.1
This is my first post. I installed Domoticz yesterday to see how it compared to my DIY python code that monitors my 18 1-wire sensors on my central heating with a db and cherrypy web page... and it's much better! I too struggled to work out which sensor was which until I noticed an odd pattern, the last four digits of the 1-wire ID were used in the Domoticz ID but as pairs that were switched....!???
e.g.
xx-xxxxxxxx1234 > 3412
28-00000703be3d > 3dbe
... this was true for all my sensors. I thought I'd share this information as it may save someone a little time when setting up.
Cheers,
Andy.
e.g.
Cheers,
Andy.
