Change brightness Hue Lamp  [Solved]
HighDangerr
Post by HighDangerr »
Goodevening,
Can anyone help me what i for code i need setting a brightness to a Hue lamp?
And where to put it in the code?
Re: Change brightness Hue Lamp  [Solved]
HighDangerr wrote: Sunday 24 November 2019 17:37 Goodevening,
You can use dimTo
Below an example.
		devices = {
			2640  -- change to the ID of a switch controlling the brightness of your hue light
		logging =
	    level = domoticz.LOG_DEBUG
	execute = function(dz, item )
	    _G.logMarker =  _G.moduleLabel
		local hueLight = dz.devices(156) -- change to ID of your huelight.
		local stepSize = 5  -- Adjust to the value you want
		if item.active then
		    hueLight.dimTo(math.min( hueLight.level + stepSize, 100 ))
            hueLight.dimTo(math.max( hueLight.level - stepSize, 0 ))
