Replace a character in a string  [Solved]
Number8
Domoticz version: 2022.1
Post by Number8 »
Hello
I'm running Domoticz 4.1214. Using dzVents: I'm trying to replace a character by another one in a string. Can anyone lead me towards the solution?Thank you
Debian buster on NUC and three RPi with buster.
Re: Replace a character in a string
Number8 wrote: Saturday 23 November 2019 10:57 I'm trying to replace a character by another one in a string. Can anyone lead me towards the solution ?
Have a look at this site
You will find something like below ( and a lot of other useful information on Lua)
local a = 'domoticz'
local b = a:gsub('d','D')
print(b) --> Domoticz
Number8
Post by Number8 »
Thanks a lot.
Number8
Post by Number8 »
As a matter of fact I need to replace a dot '.' by a comma ','. So far it does not work. Is the comma considered as a special character that I should declare another way?
zicht
Domoticz version: 2023.1+
Post by zicht »
you should escape it
Re: Replace a character in a string  [Solved]
Number8 wrote: Saturday 23 November 2019 11:51 As a matter of fact I need to replace a dot '.' by a comma ','. So far it does not work. Is the comma considered as a special character that I should declare another way?
You could do yourself a big favor by trying to use a search engine before asking here. The first hit when searching for 'special character Lua'
Shows this site where you can read how to escape these special chars.
> a = 'domoticz. dzVents'
b = a:gsub('%.',',')
print(b) --> domoticz, dzVents
Number8
Post by Number8 »
Thanks @waaren. This is what I did at the first place, I was indeed trying to search for escape in the tutorial without success.
