Use value of different IDX in custom.js
Ierlandfan
Post by Ierlandfan »
How to get the variables of different idx:
How I now use it is like this but it scews up the probed block:
var deviceState='';
function getBlock_123(device, idx){
$('.block_'+idx);
if (device['Level']= 0) deviceState='Off';
else if (device['Lev[code]el']= 10) deviceState='CV';
else if (device['Level']= 20) deviceState='WW';
else window.deviceState='Error';
console.log("DeviceState inside function", deviceState); //It works
return deviceState;
function getBlock_456(device, idx){
console.log("DeviceState inside another function", deviceState); //It works
I will make it a feature request
Ierlandfan
Re: Use value of different IDX in custom.js
Thanx to Lokonli, i changed the code. No more block screw ups.
Example:
 var _idxvalues_238;
function getStatus_238(idx,value,device){
$('.block_'+idx);
_idxvalues_238 = Object(device);
console.log("Debug block 238:", _idxvalues_238);
return _idxvalues_238;
Now you do can things like:
function getBlock_239(device,idx){
console.log("Block 239 but text value from 238 =", _idxvalues_238);
I will post my full Toon thermostat example tomorrow.
Lokonli
Post by Lokonli »
Ierlandfan wrote: Tuesday 26 November 2019 0:18 Thanx to Lokonli, i changed the code. No more block screw ups.
Example:
 var _idxvalues_238;
$('.block_'+idx);
The device information is stored in a global variable 'alldevices'.
You can get specific device info via alldevices[idx]
You can access blocks[idx] as well.
Ierlandfan
[Can you spot the logical or grammatical error in this line of codes?
Brackets, if, else without or within brackets is not my strength (Any programing language)
if (levelNamesEncoded === true) names =  window.atob(_idxvalues_236['LevelNames']).split('|'); //Show the text level of idx236
        else names = _idxvalues_236['LevelNames'].split('|');
//Untill here it's working, vars are also tested and working
 /* Here is where the grammar and/or logic is not in sync, lots of code changes to try to make dashticz start so I lost track */
     for (a in names){
     if (a == parseFloat(device['Level'] ) // I use all the values
            if (_idxvalues_238['Level'] =='50' && _idxvalues_236['Level'] =='30'); //If this compare is true
                                html += '<div class="col-xs-6 col-data-thermostat">';
                                html += '<strong class="Title">' + Handmatig + _SetPoint +symbol_temp+'</strong><br />'; //Display this
                                        else if (_idxvalues_236['Level'] =='30');  //Else if this is true
                                html += '<strong class="title">' + Tijdelijk +names[a] +'</strong><br />'; //Display this
                                        else if (_idxvalues_236['Level'] =='20'); // Else if this is true
                                html += '<strong class="title">'+Scene_value+'</strong><br />'; //Display this
                                  else  console.log("Not defined"); //Catch all error, do we really need the "else" statement to close" ?
                                  // switch statement could also work here I guess
Last edited by Ierlandfan on Tuesday 26 November 2019 18:12, edited 1 time in total.
Ierlandfan wrote: Tuesday 26 November 2019 2:01 Brackets, if, else without or within brackets is not my strength (Any programing language)
not hindered by any js knowledge whatsoever but can you try this ?
     for (a in names)
clinkadink
Post by clinkadink »
There were quite a few errors; missing parenthesis, if statements not closed, etc. This is now valid JS, I will leave it to you to check the variable names, ids, etc. Cheers ;)
if (levelNamesEncoded === true) {
} else {
for (a in names){
    if (a == parseFloat(device['Level'] ) ) {
        if (_idxvalues_238['Level'] == '50' && _idxvalues_236['Level'] == '30') {
        } else if (_idxvalues_236['Level'] == '30') {
        } else if (_idxvalues_236['Level'] == '20') {
        } else {
