i would like to control my sprinkler system (4 valves visible as switches in domoticz)
what would be best approach to create dummy switch controlled with dzventsreversephonelookup.onl/ curated.onl/nba-reddit/
i want to run (on switch)
1 valve (x min on then switch off)
2 valve (x min on then switch off)
3 valve (x min on then switch off)
4 valve (x min on then switch off)
it even possible to run script for so long?
problem is that i want to be able switch off at anytime and interrupt program and disable valves anytime....?
Dzvents as sprinkler controler
- waaren
Re: Dzvents as sprinkler controler
Sorry but I do not completely understand your requirements. Can you please explain with some more details ?Ramond wrote: Saturday 16 November 2019 22:23 Hello,
pvklink
- Domoticz version: latest b
@waaren made this irrigationsystem for me, works perfect.
Timers, all on/off stop, activate one or more, stop one or more etc.
Jablotron connection, Ikea
