As soon as I Active it, I ave no more anything in the logs, and Domotics is hang.
logs done with SVT in "debug-ALL"
INIT :
When I activate, the SVT hardware, The Only line I get in the log is :2019-11-09 15:29:38.058 Status: Domoticz V4.11474 (c)2012-2019 GizMoCuz
2019-11-09 15:29:38.063 Status: Build Hash: 12feb06f1, Date: 2019-11-08 16:33:53
2019-11-09 15:29:38.064 Status: Startup Path: /home/pi/domoticz/
2019-11-09 15:29:38.897 Status: PluginSystem: Started, Python version '3.4.2'.
2019-11-09 15:29:38.902 Status: Using 1-Wire support (kernel W1 module)...
2019-11-09 15:29:38.965 Status: WebServer(HTTP) started on address: :: with port 8080
2019-11-09 15:29:38.995 Status: WebServer(SSL) started on address: :: with port 443
2019-11-09 15:29:39.039 Status: TCPServer: shared server started...
2019-11-09 15:29:39.039 Status: RxQueue: queue worker started...
2019-11-09 15:29:41.053 Status: Hardware Monitor: Started
2019-11-09 15:29:41.072 Status: 1Wire: Added Device: 28-000005b62d2f
2019-11-09 15:29:41.972 Status: (Teleinfo) Teleinfo device uses serial port: /dev/ttyAMA0 at 1200 bauds
2019-11-09 15:29:41.973 Status: Darksky: Started...
2019-11-09 15:29:41.984 Status: (Teleinfo) CRC checks will be performed on incoming data
2019-11-09 15:29:41.985 Status: GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!
2019-11-09 15:29:41.991 Status: Kodi: Started
2019-11-09 15:29:41.993 Status: Wunderground: Worker started...
2019-11-09 15:29:41.994 Status: Netatmo: Worker started...
2019-11-09 15:29:41.997 Status: (Linky) Started.
2019-11-09 15:29:42.003 Status: Pinger: Worker started...
2019-11-09 15:29:42.045 Status: Sysfs GPIO: Startup - polling:no interrupts:no debounce:50msec inputs:0 outputs:1
2019-11-09 15:29:42.046 Status: (Ampli) Started.
2019-11-09 15:29:42.048 Status: EventSystem: reset all events...
2019-11-09 15:29:42.051 Status: EventSystem: reset all device statuses...
2019-11-09 15:29:42.353 Status: (Teleinfo) Teleinfo CRC check mode set to 1
2019-11-09 15:29:42.404 Status: PluginSystem: Entering work loop.
2019-11-09 15:29:42.503 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2019-11-09 15:29:43.104 Status: OpenZWave: Starting...
2019-11-09 15:29:43.104 Status: OpenZWave: Version: 1.6-943-gacce060e-dirty
2019-11-09 15:29:45.030 Status: (Linky) Entering work loop.
2019-11-09 15:29:45.032 Status: (Linky) Initialized version 1.2.0, author 'Barberousse'
2019-11-09 15:29:45.968 Status: Python EventSystem: Initalizing event module.
2019-11-09 15:29:45.993 Status: EventSystem: Started
2019-11-09 15:29:45.994 Status: EventSystem: Queue thread started...
2019-11-09 15:29:46.902 Status: (Ampli) Initialized version 2.0.2, author 'thomasvillagers'
2019-11-09 15:29:46.913 Status: (Ampli) Entering work loop.
2019-11-09 15:29:54.875 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
2019-11-09 15:29:54.876 Status: OpenZWave: Received unhandled notification type (30) from HomeID: 0, NodeID: 0 (0x00)
2019-11-09 15:29:54.876 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
2019-11-09 15:29:54.876 Status: OpenZWave: ManufacturerSpecificDB Ready
2019-11-09 15:29:55.271 Status: OpenZWave: Driver Ready
2019-11-09 15:29:55.282 Status: SendSwitchIfNotExists: Device '3.instance.1.index.0.commandClasses.38' (Level) with DeviceID '00000301' matches '3.instance.1.index.0.commandClasses.37' (Switch). Domoticz will use the Dimmer (and hide the Switch).
2019-11-09 15:29:55.365 Status: SendSwitchIfNotExists: Device '7.instance.1.index.0.commandClasses.38' (Level) with DeviceID '00000701' matches '7.instance.1.index.0.commandClasses.37' (Switch). Domoticz will use the Dimmer (and hide the Switch).
2019-11-09 15:29:59.300 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 3 (0x03)
2019-11-09 15:30:03.195 Status: Incoming connection from: 192.168.165.211
2019-11-09 15:30:03.746 Status: Incoming connection from: 192.168.165.200
2019-11-09 15:30:04.045 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 3 (0x03)
2019-11-09 15:30:07.839 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 4 (0x04)
2019-11-09 15:30:11.598 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:11.891 Status: Incoming connection from: 192.168.165.210
2019-11-09 15:30:12.014 GPIO: Optional connected Master Domoticz now updates its status
2019-11-09 15:30:12.403 Status: Sysfs GPIO: Update master devices
2019-11-09 15:30:14.735 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:17.871 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:20.875 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:23.879 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:26.882 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:29.890 Status: OpenZWave: Received timeout notification from HomeID: 3623020742, NodeID: 7 (0x07)
2019-11-09 15:30:30.575 Status: OpenZWave: Awake Nodes queried
And then notinig, everithing is crashed2019-11-09 15:31:22.724 Status: (SVT) Started.
