I'm a bit of a Domoticz newbie, but having been using it for about a year for basic stuff at a cabin that I own. I'm attempting to add a FortrezZ WWA02AA Temperature & Leak Sensor, but am running across an issue. Specifically, in Domoticz, the sensor shows up in the Z-wave device list as "FortrezZ Unknown: type=0063, id=010c", but it doesn't show up anywhere else in the UI.
I tried following the instructions at https://github.com/OpenZWave/open-zwave ... d-Version) to add the device, but even after adding it to the manufacturer_specific.xml file, it doesn't show up.
When looking in the manufacturer_specific.xml file, I see a WWA-02 sensor with type of 0021. According to the documentation at https://static1.squarespace.com/static/ ... ddress.pdf , the device with type 0021 is the European version of the sensor. I have the US version of the sensor, so I copied the line that exists for the European version, pasted it below, and changed the type to 0063, and the ID to 010c, to match what Domoticz is showing me.
I then tried to restart Domoticz, and even reboot the machine it is running on to see if Domoticz would "see" it and show me the temperature, but nothing is showing up.
Does anyone have any suggestions on things I might try to get this working?
FortrezZ WWA02AA Support
forbonicacid
