dzVents - inspecting all Pir sensors in the house
bertbigb
Post by bertbigb »
Dear All,
I started with dzVents just now and I want to translate my lua scripts to dzVents.
All my Pir / Motion sensors in the house are called Motion-<roomname>
Now I want to know if there is some movement in the house and if none of the sensors noticed motion in the house for the last hour I want to switch off the seperate / general Motion sensor.
From what I know about the subject I came to the following. But it doesn't work.
What did I do wrong and what to change in the scrip to make it work?
Your help is appreciated.
local active = 0
   logging = {
      level = domoticz.LOG_ERROR, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
      marker = "-=# Movement #=-"
		devices = {'Motion-*'},
		timer = {'every minute'},
	data = {},
	logger = {},
	execute = function(domoticz, triggeredItem)
		-- check all Motion / Pir sensors
		domoticz.devices().filter(function(device)
		    return (string.match('Motion-', device.name)~=nil)
		end).forEach(function(motion)
            if (domoticz.devices('Motion-', device.name).lastUpdate.minutesAgo <= 60) then
                active = active + 1
		end)
		if active == 0 then
		    domoticz.devices('Motion').switchOff()
		    domoticz.devices('Motion').switchOn()
    	print('Aantal actieve devices = ' .. active)
Best regards Bert
Synology DS1517+ - DSM 6.2
Re: dzVents - inspecting all Pir sensors in the house
bertbigb wrote: Wednesday 13 November 2019 15:53 All my Pir / Motion sensors in the house are called Motion-<roomname>
What to change in the script to make it work?
This should do it.
return
    on =
   logging =
    execute = function(dz, item)
        local active = 0
        local motionActive = dz.devices('Motion')
        -- loop over all devices
        dz.devices().forEach(function(dv)
            -- check names / lastUpdate
            if (dv.name):match('Motion%-') and dv.lastUpdate.minutesAgo <= 60 then
                active = active + 1
                dz.log(dv.name .. '; status ==>> ' .. dv.state .. '; last Updated: ' .. dv.lastUpdate.rawDate ..', ' ..dv.lastUpdate.rawTime ,dz.LOG_FORCE)
        end)
        if active == 0 then
            motionActive.switchOff().checkFirst()
            motionActive.switchOn().checkFirst()
        dz.log('Aantal actieve devices = ' .. active,dz.LOG_FORCE)
Or this..
return
    on =
   logging =
        local active = 0
        -- filter devices on name
        dz.devices().filter(function(dv)
            return (dv.name):match('Motion%-')
        -- filter result on lastUpdate
        end).filter(function(dv)
            return dv.lastUpdate.minutesAgo <= 60
        -- act on result
        end).forEach(function(dv)
            active = active + 1
        end)
        if active == 0 then
bertbigb
Post by bertbigb »
Hi Waaren,
First off all many thanks for these examples and your quick reply, both scripts are doing what I expected and I could see what you did different compared to my first attempt so also a learning experience.
One thing I don't get and probably you can explain a bit:
In the first script there is a line with:
How does that match? Motion%- since the sensors are called Motion-<roomname>, so the position of the wildcard is confusing me.
Also in the second script you provided:
I would have expected something like Motion-% but when I change it that way I get an error
malformed pattern (ends with '%')
Hope you can give a little bit of explanation so I can understand why it is like this.
Again many thanks
Bert
Best regards Bert
bertbigb wrote: Thursday 14 November 2019 12:25 I would have expected something like Motion-% but when I change it that way I get an error
The % is not a wildcard character in Lua. In patterns % is used in combination with a letter to define a character class
  • %a --> all letters
  • %c --> control characters
  • %d --> digits
  • %l --> lower case letters
  • %p -- > punctuation characters
  • %s --> space characters
  • %u --> upper case letters
  • %w --> alphanumeric characters
  • %x --> hexadecimal digits
  • %z --> the character with representation 0
An upper case version of any of those classes represents the complement of the class. For instance, '%A' represents all non-letter characters.
Some characters, called magic characters, have special meanings when used in a pattern. The magic characters are
The character `%´ works as an escape for those magic characters. So, '%-' matches a -;
For more detailed information look at the free Lua manual: Programming in Lua
bertbigb
Post by bertbigb »
Hi Waaren,
Thanks again for your response. Now I understand.
Best regards Bert
Superdeboer
Domoticz version: 2021.1
Post by Superdeboer »
For future reference:
I used this script for more than a year without any problems. After updating Domoticz (and with it dzVents), it suddenly wasn't working like it should. In viewtopic.php?f=59&t=36202 you can find a solution to the problem that I experienced. The problem has to do with an issue in dzVents regarding lastUpdate, that was fixed, but broke this script.
rezzalex
Post by rezzalex »
I am trying to check all my PIR sensors, but the match function is not working at all
I have DZ almost latest Beta version.
		devices = {
			'Test'
	logging = {
		level = domoticz.LOG_FORCE,
		marker = 'test',
        domoticz.devices().forEach(function(dv)
            if (dv.name):match('DETECT%-') then
--        end).filter(function(dv)
--            return dv.lastUpdate.minutesAgo <= 1
            -- act on result
--            end).forEach(function(dv)
                domoticz.log(dv.name .. '; status ==>> ' .. dv.state .. '; last Updated: ' .. dv.lastUpdate.rawDate ..', ' ..dv.lastUpdate.rawTime , domoticz.LOG_FORCE)
        end)
I tried to enter 1 full name of a device, replacing DETECT%- by "DETECT_MOUV_salle-a-manger", still not working ...
willemd
Domoticz version: 2026.3
Post by willemd »
I have no experience defining functions within DzVents, but when I read and compare your script to the original in this thread, I see that the original is making a call to the defined function and you are not.
You could also try to add a "else" part to the if-statement to check whether that part of the code is executed at all.
Kedi
Domoticz version: latest
Post by Kedi »
Should not this be the motion sensors?
		devices = {
			'Test'
rezzalex
Post by rezzalex »
Kedi wrote: Friday 05 January 2024 12:17 Should not this be the motion sensors?
		devices = {
			'Test'
No, it is a dummy device to test.
the real context of my script si to check all PIR when Alarm is set automatically, to check on any remaining presence at home like kids or guests
rezzalex
Post by rezzalex »
willemd wrote: Friday 05 January 2024 11:49 I have no experience defining functions within DzVents, but when I read and compare your script to the original in this thread, I see that the original is making a call to the defined function and you are not.
The "else" is working, meaning the match function doesn't
willemd
Post by willemd »
rezzalex wrote: Friday 05 January 2024 14:11
And the dv.name that you are printing to the log is as expected?
rezzalex
Post by rezzalex »
OK, I think this is working, except the name of the devices I want to check have a special characters in the middle.
I have tried with my "presence" device, and only works for the 2 more recents, the 2 olders are not recogised by the match, despite the begining of their names are exactly the same ...
rezzalex
Post by rezzalex »
having a quick look at LUA string livrairy, not sure If I can easily use a "begin by" function for strings...
rezzalex
Post by rezzalex »
OK, now it works, sorry for disturing...
