I am on Domoticz version 4.11468 (beta)Thorgal789 wrote: Monday 04 November 2019 19:45 I have make a search on "Fatal signal 11" and it's something realy frequent, hard to find a special procedure.
https://www.domoticz.com/forum/viewtopi ... 11#p227513
https://www.domoticz.com/forum/viewtopi ... 11#p222058
https://www.domoticz.com/forum/viewtopic.php?t=27921
Wich one domoticz version are you using ATM ?
Have you try an older version ?
You haven't change your python version ?
You can too make a backup, reinstall a clean install of domoticz an restore the backup.
Or easier, if the problem is a right problem, just delete the plugin folder and reinstal it, you will loosse nothing (all the config is in deconz), you can just have device name problem (if you have changed device name in domoticz). But I don't think the problem was from here.
It started two update ago.
I cannot get it to work again.
Removed the Domoticz-deCONZ folder from the plugin folder.
All running fine, no errors in the Domoticz log.
Reinstalled the deCONZ plugin, created new API key, reboot.
Domoticz boots up fine, no errors.
Via Hardware added the deCONZ plugin with correct API key and debug on.
After that the log file shows that the deCONZ plugin has started followed by:
EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
That message shows 3 times and the web interface crashes.
The raspberry Pi is still accessible via Putty and WinSCP but the web interface, and Android app, does not access Domoticz.
Phoscon still working.
Sudo reboot in Pyutty will reboot the raspberry and Domoticz is starting again with the deCONZ removed as hardware from the Hardware tab.
Can add deCONZ again but with same result.
I think I have to start all ove ragain and setup Domoticz, deCONZ and Phoscon from stratch.
Hmmmmmmm
