Calling a bash script  [Solved]
Olfer
Post by Olfer »
is it possible somehow to ca a bash script from DzVents? (location: script://home/piuser/domoticz/scripts/myscript.sh)
Background:
I want to TTS my Washingmachine and Dryer Status to Alexa via the alexa_remote script. Yes, I could do it with On and Off actions on a switch or using the http notification, but...
I use the http notification for notifying me via Microsoft Flow (don't hate me!) and I have already an Off Script running. So I think callit via dzvents would be a nice solution.Also it would be more flexible as this would not be limited to switches.
Cheers
Domoticz on RPi3 with Aeontec Z-Stick gen5. Beta.
Z-Wave, Zigbee, WiFi and MQTT (mainly Tasmota), Neo Cool Cam, Devolo, Fibaro, Shelly, Hue, Osram, Blitzwolf, TP-Link, Alexa. Latest: Somfy IO integration
Re: Calling a bash script
Olfer wrote: Sunday 10 November 2019 20:13 is it possible somehow to ca a bash script from DzVents? (location: script://home/piuser/domoticz/scripts/myscript.sh)
Something like this:
return
    on =
        timer = {'at 20:41'}, -- change to to tine to trigger
        devices = { 'MotionSensor' }, -- Change to name of your trigger device
    logging = { level = domoticz.LOG_DEBUG  },
    execute = function(dz, item)
        _G.logMarker =  _G.moduleLabel -- set logmarker to scrptname
        local function osCommand(cmd)
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            if commandOutput:find '::ERROR::' then     -- something went wrong
               dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
            else -- all is fine!!
                dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
        osCommand('bash -c /bashdir/test.sh') -- Full qualified /path/scriptname
Olfer
Re: Calling a bash script  [Solved]
Post by Olfer »
:D Thanks a LOT!
I'll try osCommand(...) as helper function until Wednesday.
It seems to be exactly what I'm looking for!
Olfer
Post by Olfer »
Thanks again waaren! Works like a charm!
